Lubuntu 14.04
Re: Lubuntu 14.04
I've added my Sam to the Ubuntu PPC hardware database: https://wiki.ubuntu.com/Lubuntu/Testing ... re#preview :)
Re: Lubuntu 14.04
Spectre660 wrote:Second Version of Kernel 3.13.1.
Added back some elements in Bus configuration and scrolling seems faster to me with my Radeon HD 6670.
https://dl.dropboxusercontent.com/u/542 ... 1-2.tar.gz
Your new kernel works on my Sam440ep Flex with the Radeon 9250 PCI. But my sound doesn't work. Do you have any suggestions of solving my sound issues? I've uploaded your new kernel: Sam440ep-3.13.1-2.tar.gz. Thank you very much. :)
Re: Lubuntu 14.04
In Lubuntu you have to add audio to your user group.
From the menu
System Tools
Users and Groups
Then from the User Settings Dialog
Manage Groups
Select
audio
Prroperties
select the dialog box in front of your name so that the tickmark appears
Select ok and do the authentification.
You need to reboot.
Test the audio by playing something in Audacious
Re: Lubuntu 14.04
Spectre, you're great! It works! Sorry, I do forget again and again that I have to add my user to the group "audio" and "video".
sudo usermod -aG audio christian
sudo usermod -aG video christian
Your MPlayer works very well on my Sam440ep Flex. :-)
(232.03 KiB) Downloaded 394 times
Re: Lubuntu 14.04
@ Xeno74
Mplayer works for audio under Lubuntu. not getting video to work .
May have to recompile the Lubuntu version.
I did this one under Debian Wheezy and both audio and video work in Debian .
Re: Lubuntu 14.04
Can you try this mplayer please .
It is Mplayer2 compiled under Lubuntu 14.04.
https://dl.dropboxusercontent.com/u/542 ... b7f.tar.gz
copy the mplayer file in the archive to /usr/local/bin
install smplayer and run. (sudo apt-get install smpalyer)
Select options and then preferences from the Smplayer menu.
use the mplayer executable: option to set the mplayer used to /user/local/bin/mplayer .
Select audio.
change the output driver to alsa (0,0 - Cirrus Logic CS4281).
Click on Apply then ok
Drag and drop an audio file or Video file into the Smplayer window.
(651.99 KiB) Downloaded 366 times
Re: Lubuntu 14.04
New Sam440ep Lubuntu 14.04 installer boot iso.
Kernel 3.13.1 . Colour issue on Radeon 9250 fixed. :D
https://dl.dropboxusercontent.com/u/542 ... Boot-3.iso
You also need to download the Lubuntu 14.04 PowerPC alternate installer iso if you have not already done so.
http://cdimage.ubuntu.com/lubuntu/daily ... owerpc.iso
after booting your Sam with the boot CD and getting the Language Selection screen remove the boot CD and replace it with the alternate installer CD.
Re: Lubuntu 14.04
Hi Spectre660,
Your new MPlayer can play my videos. Thanks a lot! I've uploaded your ISO and the new MPlayer. :-)
Downloads:
Lubuntu_14.04_Sam440ep-CD-Boot-3.iso
mplayer2-2.0-701-gd4c5b7f.tar.gz
Re: Lubuntu 14.04
Kernel 3.14-rc1 Sam440ep .
(312.49 KiB) Downloaded 332 times
vox
Re: Lubuntu 14.04
Post by vox »
Spectre660 wrote:New Sam440ep Lubuntu 14.04 installer boot iso.
Does it work on SAM460 or you have to make a separate release?
