autostart should be set to yes instead of "on" (at least that's what i got on my XE)
Check if you got bootmethod=boota and you should be ready to go...
Installed but now only have insert floppy animation
Re: Installed but now only have insert floppy animation
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
themamboman
So, added "serial" at the end of bootargs in the uboot settings. What debug level is recommended? with 0, i only saw the ide device list, so I changed to 1 and this is the only output I got:
U-Boot 1.1.1 (Oct 4 2004 - 16:42:03), Build: 10/04/04
CPU: 750FX v2.2 @ 800 MHz
Board: AmigaOne
DRAM: 512 MB
FLASH: 0 kB
VGA: 0 ..
In: serial
Out: serial
Err: serial
a1ide.device 52.1 (09.12.2006)
Running on new memory system
Config forced in $a1ide_conf : 2100
Xfer modes forced in $a1ide_xfer : 1111
Running on AmigaOne
Found chip #0
---> Port 0
IOBase 000001F0, AltBase 000003F6
bmcr_base 0000CC00
MMIOBase 00000000
Config forced, no scan
2 device(s) on port
0 Master : 'ATAPI'
1 Slave : 'ATA'
Starting 'a1ide.device - chip 0 port 0' task
Trying to configure unit 0
Adjusting unit 0 to xfer mode 12
Unit configured, flags $011D
Trying to configure unit 1
multi_count 16
Adjusting unit 1 to xfer mode 12
Unit configured, flags $0185
Port 0 task started
---> Port 1
IOBase 00000170, AltBase 00000376
bmcr_base 0000CC08
MMIOBase 00000000
0 device(s) on port
All done
it8212ide.device 52.1 (09.12.2006)
Running on AmigaOne
Nothing started, bailing out
lsi53c8xx.device 52.1 (09.12.2006)
Running on AmigaOne
sii0680ide.device 52.1 (09.12.2006)
Running on AmigaOne
sii3112ide.device 52.1 (09.12.2006)
Running on AmigaOne
sii3114ide.device 52.1 (09.12.2006)
Running on AmigaOne
sii3512ide.device 52.1 (09.12.2006)
Running on AmigaOne
Board: AmigaOne
DRAM: 512 MB
FLASH: 0 kB
VGA: 0 ..
In: serial
Out: serial
Err: serial
Running on AmigaOne
Found chip #0
---> Port 0
bmcr_base 0000CC00
MMIOBase 00000000
2 device(s) on port
0 Master : 'ATAPI'
1 Slave : 'ATA'
multi_count 16
Port 0 task started
---> Port 1
bmcr_base 0000CC08
MMIOBase 00000000
0 device(s) on port
All done
Running on AmigaOne
Running on AmigaOne
Running on AmigaOne
Running on AmigaOne
Running on AmigaOne
Running on AmigaOne
5 is the default and should be sufficient.
iirc you can go upto 20, which will print every fart the hardware does
Edit: Your HDD and CD are properly detected
The "bailing out" parts mean there were no other ide chips (sil and such) detected and being skipped
There is nothing at all after that on the serial?
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
themamboman
I changed the debuglevel to 20 and also changed the pci_irqa to something else because it had the same value as pci_irqc.
The log is here:
http://pastebin.com/paKGcBUQ
The last line shows that LoadWB is the last thing called (the DH0 partition is named AmigaOS4.0:) and then nothing.
Any ideas?
thanks!
The log is here:
Any ideas?
thanks!
@Themambomam
Your log doesn't looks like log from debug kernel, but rather than log from user's kernel. All those "debug level" works fully (i mean to how all kind of info) only when you on debug kernel, not on user kernel. And when you will have debug level set to 20, your system boot will be many minutes, just because of thousands lines of output. And level 5 will be more than enough, just you should be on debug one, not on user one if you want to know all possible details.
themamboman
So, how do I get the debug kernel then?
Thanks!
Thanks!
I don't think he should mess with debug vs normal kernel right now...he's not even reaching workbench.kas1e wrote:@Themambomam
@themamboman
I just pulled out my OS4.0 CD...you DID read the OS4 Install guide, didn't you? (OS4-InstallGuide.html)
Do you maybe have a possibility to show it on a second computer and let the guide...errm, guide you through the installation process?
There's a slight chance that you are missing something completely easy no one of us thinks about.
Plus there's nice instruction to the UBoot menu, which might make things easier for all of us
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
themamboman
Is that the same as this webpage?
http://homepage.ntlworld.com/c.moppett/
I did follow that. I will look again though in case I missed something. About to change the cables and move the HDD to the other internal IDE header as master instead of slave too.
Thanks!
Thanks!
Yup, thats it...themamboman wrote:Is that the same as this webpage?
Thanks!
Too bad you are having such a hard time running OS4...keep on
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
@Raziel
Through its all seems just bad install in end, and better to not worry with kernels and debug levels then at all.
Kernel is the first piece of code which loads by bootloader , so does not matter if he reach wb or not, debug kernel can be used to have more info just from very first bytes of loading. Its just you suggest to increase debug levels, and i says that it make no big sense to play with debug levels on user kernel : it will show almost nothing, while debug one will throw all kind of info.I don't think he should mess with debug vs normal kernel right now...he's not even reaching workbench.
