SliTaz PPC Linux
Re: SliTaz PPC Linux
xeno74 wrote:[
Here is my CFE entry for SliTaz:
Thank you it works. But I have no icons in SliTaz. I do not think it's all being loaded. I only have a shell
musa wrote: Thank you it works. But I have no icons in SliTaz. I do not think it's all being loaded. I only have a shell
SliTaz is a very lightweight Linux distribution. That means there isn't an applications menu or something like that. You can start X11 programs via the xterm. You can also start X11 programs with the dialog box Execute a File via the Workbench menu.
Hi Christian
I only get mouse
I get this error ungrabbing evdev keyboard device failed: bad file descriptor
i try with event0 and event 1 .
Event0 give no mouse and no keyboard
Event1 give mouse and no keyboard
musa wrote: Hi Christian
I only get mouse
Are there any other devices available for example event2 etc etc?
Hi
Yes event2 but that only give me mouse.
Strange because I tried SliTaz for a while ago and I got keyboard and mouse there. I have not changed anything in my setup since then. I use an IBM acces usb keyboard with mouse via the USB port on the keyboard.
musa wrote: Hi
Yes, that's strange. Maybe you have to use another device file for /dev/input/mice.
I try mouse0 and nothing news in that. I got mouse. :(
I will take a break and maybe try to make some room on my hd so I can try Suse
Thank for your help
Fogg_80
Post by Fogg_80 »
Ciao Christian,
this distro is only for X1000 or even for X5000 ?
Fogg_80 wrote:
Fri Apr 24, 2020 11:49 pm
Ciao Christian,
I haven't tried it on a X5000 yet but in my point of view it should also work on a X5000. SliTaz isn't a normal desktop distribution. It's more for tinkering.
Fogg_80
Post by Fogg_80 »
in case I want to try with the X5000, what I need and what commands I have to give. Since I have problems with USB ports I tried to burn a cd with the kernel and the dtb inside and can read it without problems with "load scsi". Any suggestions ?
P.S. I have downloaded slitaz25 from your site.
