PartitionWizard broken?
I'm trying to run Partition Wizard (upd6 + all updates) but it won't come up again.
No window, no crash, no nothing.
Does it still work for someone?
If it works for anyone it might be a problem with catweasel (right now i'm having a disk jockey session to backup some games)
If not, then there seems to be a regression
ZeroG
Re: PartitionWizard broken?
Post by ZeroG »
The same here. (X1000 upd6 + all updates)
kas1e
Post by kas1e »
Works for me on peg2 and all latest beta files. Through it still have bugs anyway (memguard hits on exit, which already reported and noted in BZ). But as i say have no probs to run it on peg2.
ssolie
Post by ssolie »
I don't believe Partition Wizard is supported on the X1000. We haven't found a solution to this problem yet.
lazi
Post by lazi »
I have no X1000 (yet), but lost PartitionWizard on all of my machines (Peg2, uA1).
I don't know when it worked last time, but definitively used it before.
It seems that others has the same problem:
http://amigaworld.net/modules/newbb/vie ... 0&forum=14
Has PW any known issue or some other system components are broken?
Tried to roll back a lot of updates, but did not helped.
Christopher Follett
AmigaKit
AmigaKit
Post by Christopher Follett »
ssolie wrote:I don't believe Partition Wizard is supported on the X1000. We haven't found a solution to this problem yet.
I think your correct. I have to be fair, I have never used partition wizard though.
I just use the preset options in MediaToolBox and setup from there.
Resolute and Industrious
__________________
New Products
Christopher Follett wrote:I think your correct. I have to be fair, I have never used partition wizard though.
Partition Wizard has nothing to do with setting up partitions.
It is a disk salvage, repair and recovery tool.
In other words, Partition Wizard is a media toolbox, whereas Media Toolbox is a partition wizard.
Go figure ...
I can't believe it's that difficult for Joerg to remove/adjust his hardware-locking. Same goes for powerpc.library which has the same "feature".
Christopher Follett
AmigaKit
AmigaKit
Go figure ...
Your right, I was thinking of post install screen. Network wizard, Doh.
__________________
New Products
