Network-Penetrationtests & Network-Streaming Problem
Re: Network-Penetrationtests & Network-Streaming Problem
What line do you use to mount your NAS on AmigaOS4?
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
run <>NIL: smbfs WORKGROUP=x-surf USER=robert Service=///NAS-2TB/volume_1/ SERVER=NAS-2TB VOLUME Flac-2TB CACHE=2000000
Should I use the IP of my NAS instad the Name NAS-2TB ?
C:Run >NIL: smbfs:smbfs WORKGROUP="Razielim" QUIET DEVICE=SMBFB: VOLUME=Fritz.NAS: CACHE=200 TRANSLATE="L:FileSystem_Trans/INTL.crossdos" SERVICE=//192.168.178.1/FB7390/StoreJet-Transcend-01/zappa2009 wrote:run <>NIL: smbfs WORKGROUP=x-surf USER=robert Service=///NAS-2TB/volume_1/ SERVER=NAS-2TB VOLUME Flac-2TB CACHE=2000000
This is my line which works flawlessly
And no, if your NAS is available you don't need to use the IP address, if your system know your NAS by name it's fine
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
Thanks i will try it.
Report soon
Report soon
So its better speed but its is not constant! Is flips from 0 up to 512kb/s bevor it flips from 0 tp 327kb/s.
I copy the Audio to the Internal HDD and use the NAS as Backup.
Still a Problem with Big (70MB!!!!) Files right !
SOLVED!
I change my old NAS (D-Link_DNS313) to a newer one (Netgear ReadyNAS 102) , an what can I say : The Network is stable now.
I Download a CD.iso and copied is back. Work without Freeze. The setup was done with Odessy1.23r3
- trevordick
- A-Eon Technology
Good to hear!zappa2009 wrote:SOLVED!
TrevorD
I'm just Breezin'
