Sam460ex Linux
Re: Sam460ex Linux
seventhwonder
Re: Sam460ex Linux
Currently installing on Sam460 with RadeonHD6570...I chose minimal + LXDE desktop. Everything seems ok at the moment.Spectre660 wrote:https://dl.dropboxusercontent.com/u/542 ... tall-4.iso
On the AmigaOS 4.1 side you need to install ub2b as the bootloader using Media Toolbox for dualboot of Linux.
Remember that your AmigaOS 4.1 boot partition must be SFS/00 format to boot with ub2b .
ub2lb is included on the install ISO,
Btw I am installing Linux on my second SSD connected to Sil3512 PCI card. First SSD contains AmigaOS4.x Beta files.
Is it possible to choose AmigaOS4 or Linux from Uboot using this setup ? (2 seperate HDs I mean)
EDIT: Installing finished and I am writing from Mozilla Firefox on Ubuntu on Sam460+RadeonHD 6570
Since I installed ub2b on my 2nd SSD with Linux, UBoot only sees Ubuntu. Should I put ub2b on my 1st HD running AmigaOS4.1 Beta, so that I can boot OS4 too ?
AmigaOS4 Beta-Tester
Re: Sam460ex Linux
Re: Sam460ex Linux
Re: Sam460ex Linux
Re: Sam460ex Linux
Re: Sam460ex Linux
- javierdlr
Re: Sam460ex Linux
I think it doesn't exists such CONFIG_ASFS_FS option.Spectre660 wrote:Dont see the CONFIG_ASFS_FS option in kernel 3.12.6 configuration .
- http://freecode.com/projects/asfs_linuxdriver
- http://home.elka.pw.edu.pl/~mszyprow/programy/asfs/
-In kernel configuration check these options (http://moobunny.dreamhosters.com/cgi/mb ... and/135897):
CONFIG_AMIGA_PARTITION=y
CONFIG_AFFS_FS=m (or Y)
CONFIG_ASFS_FS=m (or Y) gives SFS support, useful aswell
After booting with the new kernel, it's just matter of sudo mount -t affs /dev/foo /mnt/bar
I'm trying to build such module .ko (using sources from http://home.elka.pw.edu.pl/~mszyprow/programy/asfs/) and then try to add it, will tell something ASAP.
Or can you add/merge to the kernel 3.13 such sources from http://home.elka.pw.edu.pl/~mszyprow/programy/asfs/ ?
Re: Sam460ex Linux
Re: Sam460ex Linux
