Sam460ex Linux
javierdlr
Re: Sam460ex Linux
Post by javierdlr »
javierdlr wrote:Where can I find/download #3 or/and #4 of SAM460ex's ubuntu 12.04 netinstall ISOs?
Look here: http://www.supertuxkart-amiga.de/amiga/sam.html
Ok, thx, but I can only see #1 and #2:
Ubuntu_12.04_Sam460ex_Netinstall.iso
Ubuntu_12.04_Sam460ex_Netinstall-2.iso
no #3 and #4 or are they "renamed"? #1 --> #3 and #2 --> #4
#3 worked fine, but you must use/attach a second monitor on SM502 output and #4 shows all output on ATI HD Radeon (no need for a 2nd monitor).
Re: Sam460ex Linux
Re: Sam460ex Linux
Re: Sam460ex Linux
Spectre660 wrote:Updated CD based installer for Lubuntu 14.04 . Kernel 3.13-rc7 (version # 2)
This is a light version of Ubuntu and runs very well on a Sam460ex.
This Sam460ex boot ISO just boots the Sam460ex installation .
You can also boot the installation from hard drive by making a small bootable SFS/00 partition of about 2GB and copying
the contents of the Sam460ex boot ISO to it .
Once you reboot your Sam you will see the Option to Install Lubuntu as an item in the boot menu.
With both methods You also need to download a Ubuntu14.04 Alternate installer ISO if you have not done so already . See down load link below .
Once the Install menu comes up remove the boot CD and replace it with the Ubuntu14.04 Alternate installer CD
This method saves time and bandwidth if you end up doing multiple installs like me.
At the partitioning menu you must chose to unmount the mounted partitions when asked.
Select the option for Ubuntu Desktop when you reach the menu for software to install.
Once The installation is done and you reboot into it you can ad more apps like Libreoffice etc.
Sam460ex Boot ISO
https://dl.dropboxusercontent.com/u/542 ... Boot-2.iso
http://cdimage.ubuntu.com/lubuntu/daily ... owerpc.iso
I've uploaded the boot ISO: Lubuntu_14.04_Sam460ex-CD-Boot-2.iso :)
Re: Sam460ex Linux
Re: Sam460ex Linux
Re: Sam460ex Linux
Re: Sam460ex Linux
javierdlr
Re: Sam460ex Linux
Post by javierdlr »
Tried ISO and installed without problems Debian on my SAM460ex!!!
GREAT!!!!
Re: Sam460ex Linux
