X1000 Wiki Page
ssolie
X1000 Wiki Page
Post by ssolie »
I wanted to let everyone know that we started an X1000 wiki page a while ago to capture the common issues and solutions discussed in this forum.
Go to http://wiki.amigaos.net/wiki/AmigaOne_X1000
If you see questions or fixes for common problems repeated here then we can capture that information on the wiki.
If anyone would like to volunteer to help keep the wiki up to date then please email me. Many hands make light work.
danbeaver
Location: On the edge of the Equator in hot & humid Guam
Re: X1000 Wiki Page
Post by danbeaver »
Thank you and praise the Lord!
It solved a pesky problem I had been having and was a good read too :-)
vox
Re: X1000 Wiki Page
Post by vox »
ssolie wrote:I wanted to let everyone know that we started an X1000 wiki page a while ago to capture the common issues and solutions discussed in this forum.
Go to http://wiki.amigaos.net/index.php/AmigaOne_X1000
Great!
TempDocky started to scream on my machine after one week of use in cold weather.
It has been discussed, its limits should be raised up, but since it only tool that indicate this problem under OS4
should I perform this?
X1000 CPU temperatures are rising
Clean both fan filters on the front fan openings.
Clean the fan filter UNDER the power supply unit.
Future MOS user pon SAM460ex
prowler
Re: X1000 Wiki Page
Post by prowler »
Nice. This should turn out to be a good asset to the community over time.
On a personal note, one of things I would like to see is a step by step guide on how to create an up to date installation ISO.
danbeaver
Re: X1000 Wiki Page
Post by danbeaver »
Here is a good one: I had intermittent on-off problems where the motherboard sometime would not turn off or turn on using the soft switch; the problem turned to be a semi-loose PCI card. Go figure!
vox
Re: X1000 Wiki Page
Post by vox »
danbeaver wrote:Here is a good one: I had intermittent on-off problems where the motherboard sometime would not turn off or turn on using the soft switch; the problem turned to be a semi-loose PCI card. Go figure!
My X1000 doesnt soft reboot from Linux to boot screen or from AmigaPuff with Hard Reset.
On things that should go to X1000 Wiki page
CFE can only handle FAT16 drives USB drives I believe and they should be inserted after you enter CFE.
For Linux install OS partition must be EXT3 during install.
zappa2009
Re: X1000 Wiki Page
Post by zappa2009 »
For PowerOFF and Hard-Reboot get the X1000-LinuxKernel 3.12.5 and AmigaPOFF
Use USB-Sticks with Ext2 or Fat32
Use CF-Cards in the X1000-CF-SLot with Fat32 or Ext2. Ext2 ist recommend for install a Rescue-Linux on the CF! (And yes i tried it and works for me ;) )
Use a FFS (Dos/3) Partition for Transfering Data between Linux and AmigaOS4.1.6. Linux can mount a FFS Partition ;) Mount -t affs /dev/sdx /home/amiga use makedir /home/amiga first
danbeaver
Re: X1000 Wiki Page
Post by danbeaver »
While the Debian installation document mentions using a hub to support the key board and booting from a USB stick on port 0, it appears the hub can confuse the boot sequence and, in my case, freezes the early gray A-Eon screen with no further progress. Removing the hub fixes the problem. It seems that the SAM's suffer the same fate (per Christopher at Amigakit).
Severin
Re: X1000 Wiki Page
Post by Severin »
prowler wrote:Nice. This should turn out to be a good asset to the community over time.
Done.
Done.
@Vox & zappa2009
I'm not adding anything linux there. I think that should have it's own page if it doesnm't already (not looked).
Re: X1000 Wiki Page
There are two typos in one headline
X1000 fails to boot, "Failed to load aigaboot.of: Insufficient memeory"
That oughta be "amigaboot.of" and memory"
People are dying.
How dare you!
– Greta Thunberg
