since Update 1, it seems that DTConvert/main.c
dst_dt = IDataTypes->NewDTObject(NULL,
DTA_SourceType, DTST_RAM,
DTA_BaseName, base_name,
PDTA_DestMode, PMODE_V43,
TAG_END);
failed, at least for picture type.
Could it be related to this change ?
datatypes.library 54.7
FIXED
o Using DTST_MEMORY objects could lead to a crash;
o SaveDTObject() in conjunction with DTST_RAM did not create
correct icons;
But after update 1 installation, my SYS:Libs/datatypes.library is 54.6 (08/01/2016) and NOT 54.7.
Typo error or not the correct one shipped ?
edit : Reverted to datatypes.library 53.4 (FE update 0) makes it work again.
DTM_WRITE feature requests
Re: DTM_WRITE feature requests
- salass00
Yes, it does look like the wrong version was included in the update.
Versions 54.4 to 54.6 had a bug in the DTST_RAM handling but this was fixed in version 54.7 which was supposed to be the version shipped with 4.1 FE update 1.
Thank you for your reply.
Therefore, If I understand well, the v54.7 still works with DST_RAM ?
As I use DST_RAM in my FastView program, I just have to wait for an AmiUpdate delivery ?
Right ?
thx
Right ?
thx
Hope so too. The bug fix turaround was so much faster with AmiUpdate releases than the 2 year wait for update1.zzd10h wrote:Thank you for your reply.
Right ?
@Salass00
Thanks for the clarifications
@zz10dh,xenic
Sadly , but that will not be amiupated, you probably have to wait another update
No, I can't believe that.
It's a bug and, overall, a mistake in the delivery !
Wait, it's OS4... Right, I trust you
