This is a newbie question (I'm a X1000 newbie).
Out of the box, my X1000 open a Workbench screen with 1024x768 RGBA resolution, and this is fine.
But if I try any higher resolution with screenmodes, the screens are bigger than my monitor display.
Is this something to be fixed in a next release of the HD drivers ? Or something I have to tweak myself ?
screen sizes to fit monitor (SOLVED)
- LyleHaze
Re: screen sizes to fit monitor
From prefs/screenmode, select the monitors tab, then either select "Detect Settings automatically" or enter the min and max sync rates for your monitor. This should allow your system to better suit your monitor.
LyleHaze
LyleHaze
Thanks again !LyleHaze wrote: [...] or enter the min and max sync rates for your monitor. This should allow your system to better suit your monitor.
I thought my monitor, stamped with "HD TV 26MA33" was able to display up to 1920x1080, but checking the spec., it can not.
Anyway, all the available screen sizes do fit my monitor now.
