Sometimes the X1000 doesn't boot [SOLVED]
Christopher Follett
AmigaKit
AmigaKit
Re: Sometimes the X1000 doesn't boot
Post by Christopher Follett »
328gts wrote:@ xeno74
ok thanks for the info.
let's start:
- turn off power to PSU
- remove plug from PSU
- remove power connector to NEMO
- take out one ram card (leave only one to the right of PA6T i.e closest to back of case)
- plug power connector back on NEMO
- connect PSU power & switch on PSU
- turn on X1000
if X1000 boots up to WB, press and hold the power button for 3-5 seconds & it should shut off.
Thats on the button, :). Can we sticky this, :).
Or add it to wiki under trouble shooting?
Resolute and Industrious
__________________
New Products
Rigo
Post by Rigo »
Adding it to the wiki is probably better, as this thread is a bit too long to be "sticky". The solution isn't obvious when browsing the thread until the end. It could be edited to be precise for the wiki.
Simon
ssolie
Post by ssolie »
Christopher Follett wrote:Thats on the button, :). Can we sticky this, :).
There is a place on the wiki here:
http://wiki.amigaos.net/index.php/AmigaOne_X1000
If there is anything wrong please let me know.
Step 4 says we should remove a RAM stick. Does this mean you have to run with a single RAM stick from that point on?
@ssolie
While trying some changes to my monitor settings, I discovered another minor boot problem. I backed up my monitor driver inside the DEVS:Monitors directory by cloning the monitor files as "Radeon HD 5450-bak" and "Radeon HD 5450.info-bak". Afterward my system warm booted (AmigaOS) into a default 640x480 mode, threw up an Intuition requester and then changed to the correct screenmode. Since I habitually back up files in place by adding a suffix like "-bak" with no problems, it took me quite a while to discover that the backup monitor files were the source of the problem. Getting rid of the backup files fixed the problem. You might want to remember this problem (or add it to the wiki) in case someone else encounters this boot problem.
328gts
Post by 328gts »
Hi Steven, I'll update the Wiki soon.
btw, no for your step 4 question. This is the initial test I did to get my X booting properly. Once it was working ok I added my other stick and all has been fine since. I'll update to clarify this on the wiki.
Phantom
Post by Phantom »
What happens if you have only one module of 2GB RAM installed? Do you have to unplug it and plug it again in the same slot or in a different one?
Christopher Follett
AmigaKit
AmigaKit
Phantom wrote:What happens if you have only one module of 2GB RAM installed? Do you have to unplug it and plug it again in the same slot or in a different one?
Try removing it, then putting it back into same slot, if still playing up, remove it and put in another slot.
__________________
New Products
Locked
