newlib's realloc() is using vast quantities of RAM
Re: newlib's realloc() is using vast quantities of RAM
Hmm, ReallocVec() doesn't seem to work at all.
#include <stdio.h>
#include <stdlib.h>
#include <proto/exec.h>
#define ALLOC_MAX 100 * 1024 *1024
#define ALLOC_STEP 64
int main(void)
	int i = ALLOC_STEP;
	void *memptr = NULL;
	int temp = 0;
	memptr = IExec->AllocVec(i, MEMF_PRIVATE);
	while(i < ALLOC_MAX) {
		i += ALLOC_STEP;
		temp = IExec->ReallocVec(memptr, i, 0);
		if(temp != i) break;
	printf("freeing %ld bytes\n", i);
	IExec->FreeVec(memptr);
	return 0;
The first call to ReallocVec() always returns 0. Unless the documentation is wrong, that means it can't even realloc a 64 byte area to a 128 byte area.
abalaban
Post by abalaban »
I think ReAllocVec stopped working after the introduction of the new memory managing system. I don't remember if it was supposed to be only temporary and get forgotten or if it was definitive and the autodocs were not updated accordingly...
AmigaOne XE/G4
ssolie
Post by ssolie »
chris wrote:Hmm, ReallocVec() doesn't seem to work at all.
Don't use it. It was never implemented.
OK, I won't. Can we get newlib's realloc fixed then please? Or at least somebody admitting it has a problem will be a start.
Any attempts to link in my own replacement functions just results in a crash-fest, either directly in those functions (if I try to replace globally) or subtly in something that is poking around in that memory (probably because my versions don't conform exactly to C standards). Something as critical as memory allocation needs to work properly and I'm not willing to waste any more of my time trying to work around a bug in newlib that I've already isolated and produced a testcase for.
salass00
Post by salass00 »
chris wrote:I was trying that already as a workaround, however my free() is just crashing - I think because newlib has allocated the memory somewhere else (in a shared object?) and the freeing is using my code. I can't test further until I get that sorted (which requires some jiggling of my buildsystem to get the static libs updated)
Have you tried replacing realloc() like this:
#include <stdlib.h>
#include <string.h>
void *my_malloc(size_t size) {
    void *ptr = malloc(sizeof(size_t) + size);
    if (ptr) {
        *(size_t *)ptr = size;
        ptr = (size_t *)ptr + 1;
    return ptr;
void my_free(void *ptr) {
    if (ptr) {
        ptr = (size_t *)ptr - 1;
        free(ptr);
#ifndef MIN
#define MIN(a,b) ((a)<(b)?(a):(b))
#endif
void *my_realloc(void *optr, size_t nsize) {
	size_t osize = optr ? *((size_t *)optr - 1) : 0;
    void *nptr = my_malloc(nsize);
    if (nptr) memcpy(nptr, optr, MIN(osize,nsize));
    if (optr) my_free(optr);
    return nptr;
#define malloc(size) my_malloc(size)
#define realloc(ptr,size) my_realloc(ptr,size)
#define free(ptr) my_free(ptr)
ssolie
Post by ssolie »
Any attempts to link in my own replacement functions just results in a crash-fest...
You should read the man pages for realloc() and make sure to implement it correctly. For example, if the pointer is null then realloc() acts like malloc().
I would like to see if a simple realloc() replacement fixes the problem before going any further.
I added salass00's realloc replacement to my original test code, and it seems to be behaving itself.
ssolie
Post by ssolie »
chris wrote:I added salass00's realloc replacement to my original test code, and it seems to be behaving itself.
Does that mean you have a valid workaround while we work on a fix?
salass00
Post by salass00 »
A somewhat simpler replacement realloc implementation (not tested):
#include <stdlib.h>
#include <string.h>
#ifndef MIN
#endif
    size_t osize = optr ? malloc_usable_size(optr) : 0;
    void *nptr = malloc(nsize);
    if (optr) free(optr);
    return nptr;
I haven't tried it as part of a bigger project, but I suspect I'll get the same (crashing) problems as before - given that malloc, realloc and free are only three of the available memory allocation related functions in the c library, there's no guarantee that these are the only ones being used.
