OS4.1 and IDE-Fix Express, hardly ever reboots okay
Re: OS4.1 and IDE-Fix Express, hardly ever reboots okay
I only ever used a regular IDEfix, not the Express. And that was a looong time ago.
Are you absolutely sure the Express is supposed to work with OS4 as well?
JurassicC
Post by JurassicC »
The IDE fix express does work with 4.1, well at least the one i have from the new batch that was produced a few years ago does.
Have you tried with the timing jumper removed ?
rvo
Post by rvo »
Yes, I have. Well for now I can live with it. Its too much hassle to get this working. But in case anyone wonders, be prepared for similar troubles. OS4.1 is worth it, though.. ;)
btw: thanks everyone, for your replies. I dont have much time for my Amiga these days, so sorry for the very late reply.
Amiga 1200 Kickstart 3.1 (40.68), Elbox Power/Winner tower, BlizzardPPC 603e+ @240mhz & 060 @50mhz, 256MB 60ns, BlizzardvisionPPC, IDE-fix Express, IndivisionAGA, 120GB IDE, cd, dvd, Cocolino, Micronik Keycase, PCMCIA Ethernet
