UBoot update for AmigaOne
Hypex
Re: UBoot update for AmigaOne
Post by Hypex »
IIRC the board was imported from overseas.
The timer was some boot countdown, and seeing it on screen it looked as if the seconds were stored as an ASCII string, because the timer was off by a decimal digit. From some boot delay. I can find out Sunday just out of interest.
stricq
Post by stricq »
afxgroup wrote:i think i'm the only one (or with other 2-3) that has that uboot version installed and i assure you that you will not have hany new benefit from it except the graphic menu.
So forget UBoot for A1. I think there are other most important things to work on at moment..
I had that version installed. Not sure if I still do or not. Will find out soon.
