PCI SATA Raid Cards on A1200/Mediator
Re: PCI SATA Raid Cards on A1200/Mediator
JurassicC wrote:Cool...
Might be a good idea to copy back the kickstart drawer from your native IDE disk to your sata sys: partition.
I say this as update 3 will no doubt install new kickstart modules to sys:kickstart
Once update 3 is installed you'll need to copy the contents of sys:kickstart to your native ide disk kickstart drawer.
An easier and more permanent solution might be "makelink DH0:Kickstart BOOT:Kickstart soft force".
Also if any other files on your native ide partition are superseeded by newer versions in update 3 then they will also require updating too eg:- startup-sequence bootloader etc.
This, however, is true and cannot be handled with my makelink solution.
