The lazy binding feature is still a work in progress and is not active by default. You can safely ignore it.my_pc_is_amiga wrote: WBL o.k. = Lock("Help",SHARED)
WBL o.k. = Examine("Help")
ENV/env-handler 52.2 FAIL = Lock("ENVARC:ELF.LazyBinding",SHARED)
SYS:System/Help program Issue
Re: SYS:System/Help program Issue
my_pc_is_amiga
Thanks ssolie. It looks like a different issue now after I did a kernal dump. A GrimReaper GUI doesn't come up but looks like a DSI crash. No new program will come up on WB but the shell will still work if the console window was already open. Is there any clues in the dump that could be causing this?
my_pc_is_amiga
I started my amiga with the classic 3.5" boot floppy disk and booted from the CDROM with 4.1 Update 2. System/Help still crashes even then--so I'm pretty sure now this is not an software installation problem.
