Second movie is Spongebob from my daughter. Yeah i like it
Strange commercial DVD behaviours for me on x1000 - SOLVED
- tommysammy
Re: Strange commercial DVD behaviours for me on x1000
Looking Avatar over my original Avatar DVD. It works great here. Now we need overlay.
- Attachments
- (146.61 KiB) Downloaded 1442 times
- (153.29 KiB) Downloaded 1443 times
- tommysammy
Here one more original DVD movie. Sucker Punch. It is an insider Tip. If you loves Quentin Tarantino movies, you will like this movie.
This movie is from Zack Snyder.
- Attachments
- (138.18 KiB) Downloaded 1431 times
Hello TommySammy,
Did you have to use regionset to watch your movies ?
- tommysammy
Yes but only to show me the region code from my DVD drive. It was on Region2, i don^t have to change it.zzd10h wrote:Hello TommySammy,
All my DVD movies works well, i have tried a lot of them and I looked a few
- Hans
My drive's region is set to "none," yet my DVDs still play. These DVDs are encrypted, and should be region 1 (I bought them in Canada). These are several years old though, but region locking was normal back then too.ChrisH wrote:You seem to be overlooking the different DVD drives on your X1000 & Pegasos. Specifically, I wonder whether your Peg's DVD drive has had it's region set (which is typically required by commercial DVDs), but your X1000's hasn't. You can check what your Peg's is set to, and set it on your X1000 if necessary using the following tool:zzd10h wrote:I can't read them on my X1000 under amigaOS4 but they are OK on my Pegasos2 (AmigaOS4, too)
I use same DVPlayer, libdvdcss, avcodec to read them on both computer.
http://os4depot.net/index.php?function= ... ionset.lha
What I'd like to know is what VLC does on Linux to play the DVD without setting the drive's region. Geographic region locking is explicitly excluded from New Zealand copyright law (Copyright Act 1994, section 226(b)), so there is no issue with circumventing it (at least, where I live).
EDIT: After looking around a bit, I think that updating DvPlayer's DVD CSS plugin with the latest libdvdcss would solve the problem. I don't know what version is in the current plugin, but the latest one handles newer RPC2 drives.
Hans
- trevordick
- A-Eon Technology
Re: Strange commercial DVD behaviours for me on x1000 - SOLV
I added SOLVED to zzd10h original post.
Trevor
Trevor
I'm just Breezin'
Thank
