smbfs 1.74 and network card based upon RTL8139D chipset.
I tried a single 1GB file. Will try with several small files.
smbfs for large datas freezes my X1000 - SOLVED
Re: smbfs for large datas freezes my X1000 (works on Peg2)
AmigaOne XE/G4
AmigaOne XE/G4
Thank for your tests Abalaban,
For me,
in RAM: big or lot of files work,
in JXFS partition, only big files are working
In SFS2:, neither big nor small files work, it stalled at around 700-800 mb of download.
When the x1000 stalled, network activity is 0 (seen with SysMon), i can move windows but no actions are possible.
Hoping that the small files works for you.
For me,
Inadvertently I have copied a huge directory from my NAS to my x1000 and now it works !!!
I remade the tests who were failing before and all works.
Since the beginning of this post, I change
-AOS 4.1.5 to 4.1.6
-Radeon HD5570 to HD6670
-Sound card CMI8738 to SB Live 5.1 SB0220 (really better)
I don't know which element made smbfs failed for me,
but now, I'm happy to be able to use again confidently smbfs
-AOS 4.1.5 to 4.1.6
- trevordick
- A-Eon Technology
Good news.
I will add Solved to the title.
Trevor
Trevor
I'm just Breezin'
