OS4.1 Booting from CD failed
Calgor
Re: OS4.1 Booting from CD failed
Post by Calgor »
Interesting. Maybe it was your firmware version or settings then. Good to hear you no longer have the problem.
Who upgraded your CSPPC for you?
Flare
Post by Flare »
stachu did it
DarrenHD
Post by DarrenHD »
Flare wrote:problem solved... ;)
someone did an upgrade from my csppc to 366 mhz cpu and scsi problem is also gone.. :D
im happy now..
thx for help
You are very lucky your SCSI still works reliably under OS 4.x after upgrading your PPC cpu. I had stachu upgrade mine as well, probably to the same CPU as yours, and now my SCSI locks under OS 4.x. It was an older CS PPC revision I gave to him - perhaps I should have given him a newer one to do. There were several revisions of the CSPPC board and some of the chips on it that are not documented very well or even visible to see.
