During the startup of your x1000,
is the A-EON screen looks nice like the picture attachment that Trevor post in the first page of this thread ?
For me, the boing ball is not really nice.
Thank
Radeon HD 6850 in X1000
Re: Radeon HD 6850 in X1000
- trevordick
- A-Eon Technology
You mean the image is lower resolution, right?
That is because the developers only have a small amount of memory available for the boot image and have reduced the resolution to fit. Also it depends on your monitor size/display.
Trevor
Trevor
I'm just Breezin'
Yes, it's exactly that.
I thought that it could be another symptom of my HD5450'problem, but no, it's normal.
Thank
Thank
Yes, it is/was the same for me.ddni wrote:@mbrantley
I just installed a 6850 in my X1000. The monitors tab in screenmode prefs is greyed out. Is it the same for you?
And...... something wierd/else.
Due to these old eyes, I found the best screenmode was 1366x768 on the 4850 card that came with my X1000. When I installed the 6850 it was no longer available (RATS!) I renamed the monitor icon in Devs/Monitors to Radeon HD 68 and POP! there it was 1366x768. Rename back to Radeon HD 6 and it's gone. Radeon HD 68,,, it's back. Nice.
So I went a little further and changed to the following setting under the 'Icon' heading of the Icon Information "BOARDNAME=Radeon HD 6800", as reported by Ranger, and now the Monitors tab works for Screenmode prefs.
