Sam440ep Linux
Re: Sam440ep Linux
@cara
Remember if you follow this you could lose your current linux installation if things go wrong.
I do think that apart from the possible colour issue my new installers for Debian and Lubuntu are better than what you have now.
Only 1 partition. 2 GB SFS/00. This is works as a boot or emergency boot partition for Linux.
The 20 GB should not be partitioned but left as free space preferably at the end of your hard drive.
If you want to keep your original linux installation and it is already the last 2 or 3 partitions on the hard drive
then leave the free space in front of this
If you dont have any free space on your hard drive then you will need to create some by deleting or resizing an existing partition.
If you do this you will need to back up these partitions before you delete or resize .
To be safe you should also back up all the other partitions in case something goes wrong.
Once you make any changes to the partitions on your hard drive you will change the partition numbers so the Linux bootstrap will
no longer point to the correct root partition. you will not be able to correct it on the linux side because you wont be able to boot linux.
This is where the emergency boot partition comes in. Before you do any partition changes you need to copy 2 files from the linux
/boot partition to a fat32 formatted thumb drive. Assuming that you are using parthenope as your bootloader these files are
uImage and menu.lst.Once you have created the 2 Gb SFS/00 bootable partition under AmigaOS 4.1 copy the menu.lst file to it.Then make a directory named boot on that partition. copy the uImage file to it.
Next you will have to work out the partition number of your Linux using media toolbox. Select Edit partitions and file systems for your harddrive. Locate the Linux root partition it should be Named dxh Filesystem EXT\03 .
Count the partitions from the start starting from 1. dont count any unpartitioned space in front of this partition.
so if it is partition 11 the your linux root partion is dev/sda11 .
Once you have worked out the partition number of your linux root partition edit the menu.lst file on the SFS/00 linux boot partition .
all you need to change for the old kernel is the sdaXX part to point to your linux root partition.
For my 3.13.0 kernels you need to add the radeon.dpm=0.
lines with # in front are disabled. Once you get linux booting this way you can adjust the menu.lst on the linux LNX\00 /boot partition to
point to the correct Linux root partition and use this to boot by disabling the emergency boot menu on the SFS/00 partition by adding
the # to the beginning of the lines in the menu.lst file on that partition.
You can use this method to install multiple versions of linux.
default 0
delay 5
title Debian Emergency Boot
kernel /boot/uImage radeon.dpm=0 root=/dev/sda11 console=ttyS0,115200 console=tty0
#title Install wheezy Sam440ep-Flex
#kernel /boot/uImage radeon.dpm=0 console=ttyS0,115200 console=tty0 flex
#initrd /boot/uRamdiskWheezy_CD
(114.47 KiB) Downloaded 242 times
Cara
Re: Sam440ep Linux
Post by Cara »
@ Spectre660
Thank you for the very detailed reply, I understand the process now and feel confident enough to now try it next week.
Best Regards
Re: Sam440ep Linux
Parthenope Bootloader
(67.94 KiB) Downloaded 170 times
Re: Sam440ep Linux
Under the hood .
sudo lshw
Hidden Text - Click to Show :
sam440ep
description: Computer
product: acube,sam440ep
width: 32 bits
*-core
description: Motherboard
physical id: 0
capabilities: acube_sam440ep
*-cpu
description: CPU
product: 440EP Rev. C
physical id: 1
bus info: cpu@0
version: 24.212 (pvr 4222 18d4)
*-cache
description: L1 Cache
physical id: 0
*-memory
description: System memory
physical id: 2
*-bridge UNCLAIMED
description: Bridge
product: IBM
vendor: IBM
physical id: 0
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: bridge pm bus_master cap_list
configuration: latency=0
*-pci:0
description: PCI bridge
product: PCI to PCI Bridge
vendor: Pericom Semiconductor
physical id: a
bus info: pci@0000:00:0a.0
version: 02
slot: 0, chassis 0
width: 32 bits
clock: 66MHz
capabilities: pci pm slotid normal_decode bus_master cap_list
resources: memory:b8000000-b80fffff
*-multimedia
description: Multimedia audio controller
product: Crystal CS4281 PCI Audio
vendor: Cirrus Logic
physical id: 4
bus info: pci@0000:01:04.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_cs4281 latency=32 maxlatency=24 mingnt=4
resources: irq:27 memory:b8010000-b8010fff memory:b8000000-b800ffff
*-usb:0
description: USB controller
product: OHCI USB Controller
vendor: NEC Corporation
physical id: 5
bus info: pci@0000:01:05.0
version: 43
width: 32 bits
clock: 33MHz
capabilities: pm ohci bus_master cap_list
configuration: driver=ohci-pci latency=32 maxlatency=42 mingnt=1
resources: irq:29 memory:b8011000-b8011fff
*-usb:1
physical id: 5.1
bus info: pci@0000:01:05.1
version: 43
width: 32 bits
clock: 33MHz
resources: irq:29 memory:b8012000-b8012fff
*-usb:2
product: uPD72010x USB 2.0 Controller
physical id: 5.2
bus info: pci@0000:01:05.2
version: 04
width: 32 bits
clock: 33MHz
capabilities: pm ehci bus_master cap_list
configuration: driver=ehci-pci latency=32 maxlatency=34 mingnt=16
resources: irq:29 memory:b8013000-b80130ff
*-pci:1
product: PEX8112 x1 Lane PCI Express-to-PCI Bridge
vendor: PLX Technology, Inc.
physical id: c
bus info: pci@0000:00:0c.0
version: aa
width: 64 bits
clock: 66MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
resources: memory:b8280000-b828ffff ioport:1000(size=4096) memory:b8100000-b81fffff memory:a0000000-b7ffffff
*-display
description: VGA compatible controller
product: Turks XT [Radeon HD 6670/7670]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:02:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:25 memory:a0000000-afffffff memory:b8100000-b811ffff ioport:1000(size=256) memory:b0000000-b001ffff
*-multimedia UNCLAIMED
description: Audio device
product: Turks/Whistler HDMI Audio [Radeon HD 6000 Series]
physical id: 0.1
bus info: pci@0000:02:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
resources: memory:b8120000-b8123fff
*-storage
description: Mass storage controller
product: SiI 3114 [SATALink/SATARaid] Serial ATA Controller
vendor: Silicon Image, Inc.
physical id: e
bus info: pci@0000:00:0e.0
version: 02
width: 32 bits
clock: 66MHz
capabilities: storage pm bus_master cap_list rom
configuration: driver=sata_sil latency=32
resources: irq:26 ioport:2010(size=8) ioport:2020(size=4) ioport:2018(size=8) ioport:2024(size=4) ioport:2000(size=16) memory:b8290000-b82903ff memory:b8200000-b827ffff
*-scsi:0
physical id: 3
logical name: scsi0
capabilities: emulated
*-cdrom
description: DVD-RAM writer
product: DRW-24B3ST c
vendor: ASUS
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/cdrom
logical name: /dev/sr0
version: 1.01
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-scsi:1
physical id: 4
logical name: scsi3
*-disk
description: ATA Disk
product: WDC WD5000AAKS-0
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@3:0.0.0
logical name: /dev/sda
version: 01.0
serial: WD-WCAYU3766732
configuration: ansiversion=5 sectorsize=512
*-network:0
description: Ethernet interface
physical id: 1
logical name: eth1
serial: 00:50:c2:80:d2:8d
capacity: 100Mbit/s
capabilities: ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=ibm_emac driverversion=3.54 duplex=half link=no multicast=yes port=MII speed=10Mbit/s
*-network:1 DISABLED
physical id: 2
logical name: dummy0
serial: e6:58:16:f1:20:6b
configuration: broadcast=yes
*-network:2
physical id: 3
logical name: eth0
serial: 00:50:c2:80:d2:8c
capacity: 100Mbit/s
configuration: autonegotiation=on broadcast=yes driver=ibm_emac driverversion=3.54 duplex=full ip=192.168.1.4 link=yes multicast=yes port=MII speed=100Mbit/s
Re: Sam440ep Linux
Linux powerpc Sam440ep-flex AMCC440ep processor.
Boot log of failed boot of Sam440ep-flex with a Radeon HD7750.
Text console only after exiting the debugger.
Card also wont boot under AmigaOS 4.1
U-Boot 1.3.1e (Jul  5 2012 - 19:02:53)
CPU:   AMCC PowerPC 440EP Rev. C at 799.999 MHz (PLB=133, OPB=66, EBC=66 MHz)
       I2C boot EEPROM enabled
       Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
       Internal PCI arbiter enabled, PCI async ext clock used
       32 kB I-Cache 32 kB D-Cache
Board: Sam440ep-flex
I2C:   ready
DRAM:  1024 MB
PCI:   Bus Dev VenId DevId Class Int
        01  04  1013  6005  0401  00
        01  05  1033  0035  0c03  00
        01  05  1033  00e0  0c03  00
        00  0a  12d8  8150  0604  00
        02  00  1002  683f  0300  ff
        02  00  1002  aab0  0403  ff
        00  0c  10b5  8112  0604  00
        00  0e  1095  3114  0180  00
In:    serial
Out:   serial
Err:   serial
Net:   ppc_4xx_eth0, ppc_4xx_eth1
SM502: not found
VGA:   1
VESA:  OK
CPU clock-frequency <- 0x2faf07f8 (800MHz)
CPU timebase-frequency <- 0x2faf07f8 (800MHz)
/plb: clock-frequency <- 7f28154 (133MHz)
/plb/opb: clock-frequency <- 3f940aa (67MHz)
/plb/opb/ebc: clock-frequency <- 3f940aa (67MHz)
/plb/opb/serial@ef600300: clock-frequency <- 54c563 (6MHz)
/plb/opb/serial@ef600400: clock-frequency <- 54c563 (6MHz)
/plb/opb/serial@ef600500: clock-frequency <- 54c563 (6MHz)
/plb/opb/serial@ef600600: clock-frequency <- 54c563 (6MHz)
Memory <- <0x0 0x0 0x3ffff000> (1023MB)
ENET0: local-mac-address <- 00:50:c2:80:d2:8c
ENET1: local-mac-address <- 00:50:c2:80:d2:8d
zImage starting: loaded at 0x00800000 (sp: 0x0df84028)
Allocating 0x8e0414 bytes for kernel ...
gunzipping (0x00000000 <- 0x0080e000:0x00fb0048)...done 0x791900 bytes
Linux/PowerPC load: root=/dev/sda15 console=ttyS0,115200 console=tty0
Finalizing device tree... flat tree at 0xfbd160
Using Sam440ep machine description
Initializing cgroup subsys cpu
Linux version 3.15.6-Sam440ep (root@julian-VirtualBox) (gcc version 4.8.2 (Ubuntu 4.8.2-16ubuntu3) ) #1 PREEMPT Fri Jul 18 14:22:48 AST 2014
bootconsole [udbg0] enabled
setup_arch: bootmem
arch: exit
Zone ranges:
  DMA      [mem 0x00000000-0x2fffffff]
  Normal   empty
  HighMem  [mem 0x30000000-0x3fffefff]
Movable zone start for each node
Early memory node ranges
  node   0: [mem 0x00000000-0x3fffefff]
MMU: Allocated 1088 bytes of context maps for 255 contexts
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260607
Kernel command line: root=/dev/sda15 console=ttyS0,115200 console=tty0
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Sorting __ex_table...
Memory: 964424K/1048572K available (5860K kernel code, 232K rwdata, 1436K rodata, 212K init, 1337K bss, 84148K reserved, 262140K highmem)
Kernel virtual memory layout:
  * 0xfffcf000..0xfffff000  : fixmap
  * 0xffc00000..0xffe00000  : highmem PTEs
  * 0xffa00000..0xffc00000  : consistent mem
  * 0xff9fe000..0xffa00000  : early ioremap
  * 0xf1000000..0xff9fe000  : vmalloc & ioremap
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:512 nr_irqs:512 16
UIC0 (32 IRQ sources) at DCR 0xc0
UIC1 (32 IRQ sources) at DCR 0xd0
clocksource: timebase mult[1400000] shift[24] registered
Console: colour dummy device 80x25
console [tty0] enabled
bootconsole [udbg0] disabled
Zone ranges:
  Normal   empty
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
devtmpfs: initialized
xor: measuring software checksum speed
   8regs     :   592.000 MB/sec
   8regs_prefetch:   540.000 MB/sec
   32regs    :   776.000 MB/sec
   32regs_prefetch:   688.000 MB/sec
xor: using function: 32regs (776.000 MB/sec)
NET: Registered protocol family 16
PCI host bridge /plb/pci@ec000000 (primary) ranges:
 MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
  IO 0x00000000e8000000..0x00000000e800ffff -> 0x0000000000000000
4xx PCI DMA offset set to 0x00000000
4xx PCI DMA window base to 0x0000000000000000
DMA window size 0x0000000080000000
PCI: Probing PCI hardware
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
pci_bus 0000:00: root bus resource [mem 0xa0000000-0xbfffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
PCI: Hiding 4xx host bridge resources 0000:00:00.0
pci 0000:00:0a.0: PCI bridge to [bus 01]
pci 0000:00:0c.0: PCI bridge to [bus 02]
pci 0000:00:0c.0: BAR 15: assigned [mem 0xa0000000-0xb7ffffff pref]
pci 0000:00:0a.0: BAR 14: assigned [mem 0xb8000000-0xb80fffff]
pci 0000:00:0c.0: BAR 14: assigned [mem 0xb8100000-0xb81fffff]
pci 0000:00:0e.0: BAR 6: assigned [mem 0xb8200000-0xb827ffff pref]
pci 0000:00:0c.0: BAR 0: assigned [mem 0xb8280000-0xb828ffff 64bit pref]
pci 0000:0D0:0c.0: BAR 13: assigned [io  0x1000-0x1fff]
pci 0000:00:0e.0: BAR 5: assigned [mem 0xb8290000-0xb82903ff]
pci 0000:00:0e.0: BAR 4: assigned [io  0x2000-0x200f]
pci 0000:00:0e.0: BAR 0: assigned [io  0x2010-0x2017]
pci 0000:00:0e.0: BAR 2: assigned [io  0x2018-0x201f]
pci 0000:00:0e.0: BAR 1: assigned [io  0x2020-0x2023]
pci 0000:00:0e.0: BAR 3: assigned [io  0x2024-0x2027]
pci 0000:01:04.0: BAR 1: assigned [mem 0xb8000000-0xb800ffff]
pci 0000:01:04.0: BAR 0: assigned [mem 0xb8010000-0xb8010fff]
pci 0000:01:05.0: BAR 0: assigned [mem 0xb8011000-0xb8011fff]
pci 0000:01:05.1: BAR 0: assigned [mem 0xb8012000-0xb8012fff]
pci 0000:01:05.2: BAR 0: assigned [mem 0xb8013000-0xb80130ff]
pci 0000:00:0a.0:   bridge window [mem 0xb8000000-0xb80fffff]
pci 0000:02:00.0: BAR 0: assigned [mem 0xa0000000-0xafffffff 64bit pref]
pci 0000:02:00.0: BAR 2: assigned [mem 0xb8100000-0xb813ffff 64bit]
pci 0000:02:00.0: BAR 6: assigned [mem 0xb0000000-0xb001ffff pref]
pci 0000:02:00.1: BAR 0: assigned [mem 0xb8140000-0xb8143fff 64bit]
pci 0000:02:00.0: BAR 4: assigned [io  0x1000-0x10ff]
pci 0000:00:0c.0:   bridge window [io  0x1000-0x1fff]
pci 0000:00:0c.0:   bridge window [mem 0xb8100000-0xb81fffff]
pci 0000:00:0c.0:   bridge window [mem 0xa0000000-0xb7ffffff pref]
raid6: int32x1    144 MB/s
raid6: int32x2    175 MB/s
raid6: int32x4    183 MB/s
raid6: int32x8    117 MB/s
raid6: using algorithm int32x4 (183 MB/s)
raid6: using intx1 recovery algorithm
vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
vgaarb: bridge control possible 0000:02:00.0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource timebase
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
futex hash table entries: 256 (order: -1, 3072 bytes)
bounce pool size: 64 pages
ntfs: driver 2.1.30 [Flags: R/W].
fuse init (API version 7.23)
msgmni has been set to 1502
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0xef600300 (irq = 16, base_baud = 347222) is a 16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0xef600400 (irq = 17, base_baud = 347222) is a 16550A
serial8250.0: ttyS2 at MMIO 0xef600500 (irq = 18, base_baud = 347222) is a 16550A
serial8250.0: ttyS3 at MMIO 0xef600600 (irq = 19, base_baud = 347222) is a 16550A
Zone ranges:
  Normal   empty
pci 0000:00:0c.0: BAR 13: assigned [io  0x1000-0x1fff]
pci 0000:02:00.0: BAR 2: assigned [mem 0xb810000o0-0xb813ffff 64bit]
vgaarb: loaded
ef600300.serial: ttyS0 at MMIO 0xef600300 (irq = 16, base_baud = 347222) is a 16550
ef600400.serial: ttyS1 at MMIO 0xef600400 (irq = 17, base_baud = 347222) is a 16550
ef600500.serial: ttyS2 at MMIO 0xef600500 (irq = 18, base_baud = 347222) is a 16550
ef600600.serial: ttyS3 at MMIO 0xef600600 (irq = 19, base_baud = 347222) is a 16550
Generic non-volatile memory driver v1.1
brd: module loaded
loop: module loaded
sata_sil 0000:00:0e.0: Applying R_ERR on DMA activate FIS errata fix
scsi0 : sata_sil
scsi1 : sata_sil
scsi2 : sata_sil
scsi3 : sata_sil
ata1: SATA max UDMA/100 mmio m1024@0xb8290000 tf 0xb8290080 irq 26
ata2: SATA max UDMA/100 mmio m1024@0xb8290000 tf 0xb82900c0 irq 26
ata3: SATA max UDMA/100 mmio m1024@0xb8290000 tf 0xb8290280 irq 26
ata4: SATA max UDMA/100 mmio m1024@0xb8290000 tf 0xb82902c0 irq 26
PPC 4xx OCP EMAC driver, version 3.54
MAL v1 /plb/mcmal, 4 TX channels, 2 RX channels
ZMII /plb/opb/emac-zmii@ef600d00 initialized
/plb/opb/emac-zmii@ef600d00: bridge in RMII mode
eth0: EMAC-0 /plb/opb/ethernet@ef600e00, MAC 00:50:c2:80:d2:8c
eth0: found Generic MII PHY (0x18)
eth1: EMAC-1 /plb/opb/ethernet@ef600f00, MAC 00:50:c2:80:d2:8d
eth1: found Generic MII PHY (0x19)
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
NET: Registered protocol family 24
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-pci 0000:01:05.2: EHCI Host Controller
ehci-pci 0000:01:05.2: new USB bus registered, assigned bus number 1
ehci-pci 0000:01:05.2: irq 29, io mem 0xb8013000
ehci-pci 0000:01:05.2: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.15.6-Sam440ep ehci_hcd
usb usb1: SerialNumber: 0000:01:05.2
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ppc-of-ohci ef601000.usb: OF OHCI
ppc-of-ohci ef601000.usb: new USB bus registered, assigned bus number 2
ppc-of-ohci ef601000.usb: irq 38, io mem 0xef601000
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OF OHCI
usb usb2: Manufacturer: Linux 3.15.6-Sam440ep ohci_hcd
usb usb2: SerialNumber: PPC-OF USB
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci-pci: OHCI PCI platform driver
ohci-pci 0000:01:05.0: OHCI PCI host controller
ohci-pci 0000:01:05.0: new USB bus registered, assigned bus number 3
ohci-pci 0000:01:05.0: irq 29, io mem 0xb8011000
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
ata1.00: ATAPI: ASUS    DRW-24B3ST   c, 1.01, max UDMA/100
ata1.00: configured for UDMA/100
scsi 0:0:0:0: CD-ROM            ASUS     DRW-24B3ST   c   1.01 PQ: 0 ANSI: 5
usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: OHCI PCI host controller
usb usb3: Manufacturer: Linux 3.15.6-Sam440ep ohci_hcd
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
usb usb3: SerialNumber: 0000:01:05.0
cdrom: Uniform CD-ROM driver Revision: 3.20
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
sr 0:0:0:0: Attached scsi generic sg0 type 5
ohci-pci 0000:01:05.1: OHCI PCI host controller
ohci-pci 0000:01:05.1: new USB bus registered, assigned bus number 4
ohci-pci 0000:01:05.1: irq 29, io mem 0xb8012000
usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: OHCI PCI host controller
usb usb4: Manufacturer: Linux 3.15.6-Sam440ep ohci_hcd
usb usb4: SerialNumber: 0000:01:05.1
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
rtc-m41t80 1-0068: chip found, driver version 0.05
rtc-m41t80 1-0068: rtc core: registered m41t80 as rtc0
ibm-iic ef600700.i2c: using standard (100 kHz) mode
ibm-iic ef600800.i2c: using standard (100 kHz) mode
device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
usbcore: registered new interface driver ushc
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
no UART detected at 0x1
ipip: IPv4 over IPv4 tunneling driver
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
Btrfs loaded
rtc-m41t80 1-0068: setting system clock to 2014-07-20 07:25:07 UTC (1405841107)
ALSA device list:
  No soundcards found.
ata2: SATA link down (SStatus 0 SControl 310)
usb 3-1: new low-speed USB device number 2 using ohci-pci
ata3: SATA link down (SStatus 0 SControl 310)
usb 3-1: New USB device found, idVendor=04f2, idProduct=0116
usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 3-1: Product: USB Keyboard
usb 3-1: Manufacturer: CHICONY
input: CHICONY USB Keyboard as /devices/pci0000:00/0000:00:0a.0/0000:01:05.0/usb3/3-1/3-1:1.0/0003:04F2:0116.0001/input/input0
hid-generic 0003:04F2:0116.0001: input,hidraw0: USB HID v1.10 Keyboard [CHICONY USB Keyboard] on usb-0000:01:05.0-1/input0
ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
ata4.00: ATA-8: WDC WD5000AAKS-00UU3A0, 01.03B01, max UDMA/133
ata4.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 0/32)
ata4.00: configured for UDMA/100
scsi 3:0:0:0: Direct-Access     ATA      WDC WD5000AAKS-0 01.0 PQ: 0 ANSI: 5
usb 4-1: new full-speed USB device number 2 using ohci-pci
sd 3:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
sd 3:0:0:0: Attached scsi generic sg1 type 0
sd 3:0:0:0: [sda] Write Protect is off
sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
 sda: RDSK (512) sda1 (SFS^@)(res 2 spb 1) sda2 (SFS^@)(res 2 spb 1) sda3 (DOS^A)(res 2 spb 1) sda4 (SFS^B)(res 2 spb 1) sda5 (SFS^B)(res 2 spb 1) sda6 (SFS^B)(res 2 spb 1) sda7 (NTFS)(res 2 spb 2) sda8 (LNX^@)(res 2 spb 1) sda9 (EXT^C)(res 2 spb 1) sda10 (SWP^@)(res 2 spb 1) sda11 (LNX^@)(res 2 spb 1) sda12 (EXT^C)(res 2 spb 1) sda13 (SWP^@)(res 2 spb 1) sda14 (LNX^@)(res 2 spb 1) sda15 (EXT^C)(res 2 spb 1) sda16 (SWP^@)(res 2 spb 1)
sd 3:0:0:0: [sda] Attached SCSI disk
EXT3-fs (sda15): mounted filesystem with ordered data mode
kjournald starting.  Commit interval 5 seconds
VFS: Mounted root (ext3 filesystem) readonly on device 8:15.
devtmpfs: mounted
Freeing unused kernel memory: 212K (c0723000 - c0758000)
usb 4-1: New USB device found, idVendor=046d, idProduct=c52b
usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 4-1: Product: USB Receiver
usb 4-1: Manufacturer: Logitech
input: Logitech USB Receiver as /devices/pci0000:00/0000:00:0a.0/0000:01:05.1/usb4/4-1/4-1:1.0/0003:046D:C52B.0002/input/input1
hid-generic 0003:046D:C52B.0002: input,hidraw1: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:05.1-1/input0
input: Logitech USB Receiver as /devices/pci0000:00/0000:00:0a.0/0000:01:05.1/usb4/4-1/4-1:1.1/0003:046D:C52B.0003/input/input2
hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:05.1-1/input1
hid-generic 0003:046D:C52B.0004: hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:05.1-1/input2
random: nonblocking pool is initialized
systemd[1]: systemd 204 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ)
systemd[1]: Set hostname to <Sam440ep>.
systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Starting Remote File Systems (Pre).
systemd[1]: Reached target Remote File Systems (Pre).
systemd[1]: Starting Syslog Socket.
systemd[1]: Listening on Syslog Socket.
systemd[1]: Starting Delayed Shutdown Socket.
systemd[1]: Listening on Delayed Shutdown Socket.
systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
systemd[1]: Starting Encrypted Volumes.
systemd[1]: Reached target Encrypted Volumes.
systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
systemd[1]: Starting Journal Socket.
systemd[1]: Listening on Journal Socket.
systemd[1]: Starting Syslog.
systemd[1]: Reached target Syslog.
systemd[1]: Mounting POSIX Message Queue File System...
systemd[1]: Starting Apply Kernel Variables...
systemd[1]: Starting Journal Service...
systemd[1]: Started Journal Service.
systemd[1]: Starting udev Kernel Socket.
systemd[1]: Listening on udev Kernel Socket.
systemd[1]: Starting udev Control Socket.
systemd[1]: Listening on udev Control Socket.
systemd[1]: Starting udev Coldplug all Devices...
systemd[1]: Mounting Debug File System...
systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
systemd[1]: Mounted Huge Pages File System.
systemd[1]: Starting Create static device nodes in /dev...
systemd[1]: Starting Load Kernel Modules...
systemd[1]: Started Set Up Additional Binary Formats.
systemd[1]: Expecting device dev-disk-by\x2duuid-fcc653fd\x2d50d9\x2d4f69\x2db5cf\x2d00b8525c16c1.device...
systemd[1]: Starting File System Check on Root Device...
systemd[1]: Expecting device dev-disk-by\x2duuid-685dafc6\x2dcd47\x2d452d\x2da1b1\x2d53b648af4d01.device...
systemd[1]: Mounted POSIX Message Queue File System.
systemd[1]: Started Apply Kernel Variables.
systemd[1]: Mounted Debug File System.
systemd-udevd[948]: starting version 204
EXT3-fs (sda15): using internal journal
Linux agpgart interface v0.103
[drm] Initialized drm 1.1.0 20060810
[drm] radeon kernel modesetting enabled.
[drm] initializing kernel modesetting (VERDE 0x1002:0x683F 0x1545:0x7750).
[drm] register mmio base: 0xB8100000
[drm] register mmio size: 262144
ATOM BIOS: C44501
radeon 0000:02:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
radeon 0000:02:00.0: GTT: 1024M 0x0000000040000000 - 0x000000007FFFFFFF
[drm] Detected VRAM RAM=1024M, BAR=256M
[drm] RAM width 128bits DDR
[TTM] Zone  kernel: Available graphics memory: 384734 kiB
[TTM] Zone highmem: Available graphics memory: 515804 kiB
[TTM] Initializing pool allocator
[TTM] Initializing DMA pool allocator
[drm] radeon: 1024M of VRAM memory ready
[drm] radeon: 1024M of GTT memory ready.
[drm] Loading VERDE Microcode
[drm] radeon/VERDE_mc2.bin: 31500 bytes
[drm] Internal thermal controller with fan control
[drm] probing gen 2 caps for device 10b5:8112 = 24c11/0
[drm] radeon: dpm initialized
[drm] GART: num cpu pages 262144, num gpu pages 262144
Adding 850532k swap on /dev/sda16.  Priority:-1 extents:1 across:850532k FS
[drm] PCIE GART of 1024M enabled (table at 0x0000000000276000).
radeon 0000:02:00.0: WB enabled
radeon 0000:02:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00 and cpu addr 0xc4dc9c00
radeon 0000:02:00.0: fence driver on ring 1 use gpu addr 0x0000000040000c04 and cpu addr 0xc4dc9c04
radeon 0000:02:00.0: fence driver on ring 2 use gpu addr 0x0000000040000c08 and cpu addr 0xc4dc9c08
radeon 0000:02:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c and cpu addr 0xc4dc9c0c
radeon 0000:02:00.0: fence driver on ring 4 use gpu addr 0x0000000040000c10 and cpu addr 0xc4dc9c10
radeon 0000:02:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0xf1835a18
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] Driver supports precise vblank timestamp query.
[drm] radeon: irq initialized.
[drm:r600_ring_test] *ERROR* radeon: ring 0 test failed (scratch(0x850C)=0xCAFEDEAD)
radeon 0000:02:00.0: disabling GPU acceleration
[drm] Radeon Display Connectors
[drm] Connector 0:
[drm]   HDMI-A-1
[drm]   HPD4
[drm]   DDC: 0x6570 0x6570 0x6574 0x6574 0x6578 0x6578 0x657c 0x657c
[drm]   Encoders:
[drm]     DFP1: INTERNAL_UNIPHY2
[drm] Connector 1:
[drm]   DVI-I-1
[drm]   HPD2
[drm]   DDC: 0x6560 0x6560 0x6564 0x6564 0x6568 0x6568 0x656c 0x656c
[drm]   Encoders:
[drm]     DFP2: INTERNAL_UNIPHY
[drm]     CRT1: INTERNAL_KLDSCP_DAC1
[drm] fb mappable at 0xA0477000
[drm] vram apper at 0xA0000000
[drm] size 8294400
[drm] fb depth is 24
[drm]    pitch is 7680
Console: switching to colour frame buffer device 240x67
cfg80211: Calling CRDA to update world regulatory domain
cfg80211: World regulatory domain updated:
cfg80211:  DFS Master region: unset
cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Vector: 700 (Program Check) at [c40fbaa0]
    pc: f15c56e4: radeon_sa_bo_new+0x34/0x430 [radeon]
    lr: f157d9a4: radeon_ib_get+0x30/0xe4 [radeon]
    sp: c40fbb50
   msr: 29000
  current = 0xc4001020
    pid   = 1905, comm = Xorg
kernel BUG at drivers/gpu/drm/radeon/radeon_sa.c:321!
enter ? for help
[c40fbc10] f157d9a4 radeon_ib_get+0x30/0xe4 [radeon]
[c40fbc30] f16123d0 radeon_vm_clear_bo+0xa0/0x134 [radeon]
[c40fbcc0] f1613584 radeon_vm_init+0xd4/0xf8 [radeon]
[c40fbce0] f1557e8c radeon_driver_open_kms+0x6c/0x1b8 [radeon]
[c40fbd10] f1315038 drm_open+0x1f0/0x428 [drm]
[c40fbd40] f1315350 drm_stub_open+0xe0/0x114 [drm]
[c40fbd60] c00ce954 chrdev_open+0x19c/0x1c0
[c40fbd90] c00c8d4c do_dentry_open.isra.16+0x1cc/0x26c
[c40fbdb0] c00c8e18 finish_open+0x2c/0x48
[c40fbdc0] c00d7584 do_last.isra.61+0x85c/0xa10
[c40fbe20] c00d7954 path_openat+0x21c/0x580
[c40fbe80] c00d8b94 do_filp_open+0x30/0x78
[c40fbf00] c00c9f24 do_sys_open+0x178/0x204
[c40fbf40] c000b3d0 ret_from_syscall+0x0/0x3c
--- Exception: c01 (System Call) at 1ff67bc8
SP (bfbdd6e0) is in userspace
mon> x
radeon 0000:02:00.0: fb0: radeondrmfb frame buffer device
radeon 0000:02:00.0: registered panic notifier
------------[ cut here ]------------
Oops: Exception in kernel mode, sig: 5 [#1]
PREEMPT Sam440ep
Modules linked in: cfg80211 radeon(+) cfbfillrect cfbimgblt cfbcopyarea i2c_algo_bit drm_kms_helper ttm drm snd_cs4281 snd_ac97_codec agpgart ac97_bus snd_opl3_lib snd_hwdep snd_seq_device
CPU: 0 PID: 1905 Comm: Xorg Not tainted 3.15.6-Sam440ep #1
task: c4001020 ti: c40fa000 task.ti: c40fa000
NIP: f15c56e4 LR: f157d9a4 CTR: 00000001
REGS: c40fbaa0 TRAP: 0700   Not tainted  (3.15.6-Sam440ep)
MSR: 00029000 <CE,EE,ME>  CR: 24000484  XER: 00000006
GPR00: f157d9a4 c40fbb50 c4001020 efbba000 efbbb080 c40fbc40 00001040 00000100
GPR08: 00000004 00000001 00040004 c40fbc30 24000422 206beff4 206c5970 206c596c
GPR16: 00000000 00000026 00000000 efbba000 00000001 00000000 f1340000 c40fbf08
GPR24: c4044b90 c403c140 c4044b80 00001040 00000800 c40fbc40 00000100 efbbb080
NIP [f15c56e4] radeon_sa_bo_new+0x34/0x430 [radeon]
LR [f157d9a4] radeon_ib_get+0x30/0xe4 [radeon]
Call Trace:
[c40fbb50] [efbba5d8] 0xefbba5d8 (unreliable)
[c40fbc10] [f157d9a4] radeon_ib_get+0x30/0xe4 [radeon]
[c40fbc30] [f16123d0] radeon_vm_clear_bo+0xa0/0x134 [radeon]
[c40fbcc0] [f1613584] radeon_vm_init+0xd4/0xf8 [radeon]
[c40fbce0] [f1557e8c] radeon_driver_open_kms+0x6c/0x1b8 [radeon]
[c40fbd10] [f1315038] drm_open+0x1f0/0x428 [drm]
[c40fbd40] [f1315350] drm_stub_open+0xe0/0x114 [drm]
[c40fbd60] [c00ce954] chrdev_open+0x19c/0x1c0
[c40fbd90] [c00c8d4c] do_dentry_open.isra.16+0x1cc/0x26c
[c40fbdb0] [c00c8e18] finish_open+0x2c/0x48
[c40fbdc0] [c00d7584] do_last.isra.61+0x85c/0xa10
[c40fbe20] [c00d7954] path_openat+0x21c/0x580
[c40fbe80] [c00d8b94] do_filp_open+0x30/0x78
[c40fbf00] [c00c9f24] do_sys_open+0x178/0x204
[c40fbf40] [c000b3d0] ret_from_syscall+0x0/0x3c
--- Exception: c01 at 0x1ff67bc8
    LR = 0x20533be4
Instruction dump:
7c0802a6 bdc10078 900100c4 7c731b78 7c9f2378 7cbd2b78 7cdb3378 7cfe3b78
81240070 7d274810 7d294910 7d2900d0 <0f090000> 81240058 7d264810 7d294910
[drm] Initialized radeon 2.38.0 20080528 for 0000:02:00.0 on minor 0
eth0: link is up, 100 FDX, pause enabled
eth1: link is down
IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Disabling lock debugging due to kernel taint
---[ end trace 8e548b5ea61cdfbf ]---
Re: Sam440ep Linux
Spectre660 wrote:Boot log of failed boot of Sam440ep-flex with a Radeon HD7750.
I2C:   ready
DRAM:  1024 MB
In:    serial
Out:   serial
Err:   serial
SM502: not found
VGA:   1
VESA:  OK
setup_arch: bootmem
arch: exit
Zone ranges:
  Normal   empty
Zone ranges:
  Normal   empty
vgaarb: loaded
Zone ranges:
  Normal   empty
vgaarb: loaded
brd: module loaded
loop: module loaded
scsi0 : sata_sil
scsi1 : sata_sil
scsi2 : sata_sil
scsi3 : sata_sil
Btrfs loaded
ALSA device list:
devtmpfs: mounted
ATOM BIOS: C44501
[drm] Connector 0:
[drm]   HDMI-A-1
[drm]   HPD4
[drm]   Encoders:
[drm] Connector 1:
[drm]   DVI-I-1
[drm]   HPD2
[drm]   Encoders:
[drm] size 8294400
[drm]    pitch is 7680
    sp: c40fbb50
   msr: 29000
enter ? for help
mon> x
PREEMPT Sam440ep
Call Trace:
    LR = 0x20533be4
Instruction dump:
eth1: link is down
Thanks for testing!
Re: Sam440ep Linux
Some Radeon HD7750 do work with Amiga OS 4.1 but this model does not or does not work with a Sam440ep-Flex
and PCIe to PCI adapter . (The card itself appears to be the issue)
http://www.newegg.com/Product/Product.a ... 6814129263
http://hdrlab.org.nz/projects/amiga-os- ... atibility/
xeno74 wrote:]
Thanks for testing![/quote]
