Kernel 4.19
Re: Kernel 4.19
Skateman wrote:RC7 running on my X5000 :-)
Thanks for testing the RC7. :-)
Re: Kernel 4.19
RC8 Up and Running on my X5000. :-)
This time using an Acer USB to Ethernet dongle.
asix : ASIX AX8817X based USB 2.0 Ethernet Devices
usbnet : USB network driver framework
Re: Kernel 4.19
Skateman wrote:RC8 Up and Running on my X5000. :-)
Many thanks for testing the RC8! :-)
Re: Kernel 4.19
RC8 and MESA installed and working fine. Thank you.
Re: Kernel 4.19
acefnq wrote:RC8 and MESA installed and working fine. Thank you.
Re: Kernel 4.19
xeno74 wrote: I compiled and tested the new RC8 ... kernel 4.19 and the new Mesa 18.2.2 on my X5000 and X1000 today. Both work without any problems.
PLEASE test them.
It's not clear to me what is good about Mesa or if it would even work with my X5000 setup, but I seem to have version 18.0.5 already, whether it actually does anything or not, so I downloaded the new one. But googling for how to install it gave me virtually nothing (install PPA?? Surely not). Any hints on why and how?
Re: Kernel 4.19
kilaueabart wrote: It's not clear to me what is good about Mesa or if it would even work with my X5000 setup, but I seem to have version 18.0.5 already, whether it actually does anything or not, so I downloaded the new one. But googling for how to install it gave me virtually nothing (install PPA?? Surely not). Any hints on why and how?
Here you are. :-)
Installation instructions:
  1. Code: Select all
    sudo cp -R mesa-18.2.2 /usr/local/
  2. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/r600_dri.so.bak
  3. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0.bak
  4. Code: Select all
    sudo cp /usr/local/mesa-18.2.2/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-18.2.2/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
Re: Kernel 4.19
Thanks, Christian. That sure made it easy.
The results of googling Mesa suggested to me that it is something especially good for gamers. I don't seem to have any games on 16.04.5 where I just now installed Mesa, although I think there are an incredible 54 of them in Remix!
Re: Kernel 4.19
kilaueabart wrote:Thanks, Christian. That sure made it easy.
Yes, you’re right. It’s for gamers.
