Void Linux
Re: Void Linux
Hi.
Is there a root password in Void?
thanks
Peter
Re: Void Linux
musa wrote: Wed Nov 16, 2022 3:31 pm Hi.
thanks
Peter
Peter,
You can change the root password with “sudo passwd”.
Have a nice day.
Re: Void Linux
Hi Christian
Peter
Re: Void Linux
Please note: Void PPC is EOL so we have to be careful with installing and updating of packages.
Re: Void Linux
FYI
Wicknix wrote: Better hurry and install the packages you want. The void ppc repo could get taken offline any day now. Even the old ppc maintainer doesnt know the exact date as its not his server. Otherwise it really is a nice OS. Install octo-xbps for a gui package installer. Makes finding stuff much easier.
Re: Void Linux
The latest Void disk image has a boot and a root partition. I was able to mount the root partition from the disk image and copy it to a new disk image with the following commands:
tar zxvf void-live-powerpc-20220129.img.tar.gz
ls -ltr
Output:
-rw-r--r-- 1 christian christian 8036285952 29. Jan 2022  void-live-powerpc-20220129.img
fdisk -lu void-live-powerpc-20220129.img
Output:
Disk void-live-powerpc-20220129.img: 7,48 GiB, 8036285952 bytes, 15695871 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xd0a60bb8
Device                          Boot  Start      End  Sectors  Size Id Type
void-live-powerpc-20220129.img1        2048   473087   471040  230M  6 FAT16
void-live-powerpc-20220129.img2      473088 15693823 15220736  7,3G 83 Linux
Calculate the offset from the start of the image to the partition start
Sector size * Start = (in the case) 512 * 473088 = 242221056
bc
bc 1.07.1
Copyright 1991-1994, 1997, 1998, 2000, 2004, 2006, 2008, 2012-2017 Free Software Foundation, Inc.
This is free software with ABSOLUTELY NO WARRANTY.
For details type `warranty'.
512 * 473088
242221056
quit
Mount it on /dev/loop0 using the offset.
sudo losetup -o 242221056 /dev/loop0 void-live-powerpc-20220129.img
sudo fsck -fv /dev/loop0
Output:
fsck from util-linux 2.38.1
e2fsck 1.46.6-rc1 (12-Sep-2022)
Pass 1: Checking inodes, blocks, and sizes
Inode 30261 extent tree (at level 2) could be narrower.  Optimize<y>? yes
Inode 30322 extent tree (at level 2) could be narrower.  Optimize<y>? yes
Inode 30660 extent tree (at level 2) could be narrower.  Optimize<y>? yes
Inode 30695 extent tree (at level 2) could be narrower.  Optimize<y>? yes
Inode 30739 extent tree (at level 2) could be narrower.  Optimize<y>? yes
Inode 30785 extent tree (at level 1) could be narrower.  Optimize<y>? yes
Inode 30874 extent tree (at level 1) could be narrower.  Optimize<y>? yes
Inode 30903 extent tree (at level 1) could be narrower.  Optimize<y>? yes
Inode 30907 extent tree (at level 1) could be narrower.  Optimize<y>? yes
Inode 30908 extent tree (at level 1) could be narrower.  Optimize<y>? yes
Inode 153472 extent tree (at level 1) could be shorter.  Optimize<y>? yes
Pass 1E: Optimizing extent trees
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
void: ***** FILE SYSTEM WAS MODIFIED *****
      175735 inodes used (36.94%, out of 475776)
         288 non-contiguous files (0.2%)
          27 non-contiguous directories (0.0%)
             # of inodes with ind/dind/tind blocks: 0/0/0
             Extent depth histogram: 163035/24/5
     1476045 blocks used (77.58%, out of 1902592)
           0 bad blocks
           1 large file
      134534 regular files
       13777 directories
           0 character device files
           0 block device files
           0 fifos
         690 links
       27415 symbolic links (12663 fast symbolic links)
           0 sockets
      176416 files
sudo mount /dev/loop0 /mnt
ls /mnt
Output:
bin  boot  dev  etc  home  lib  lib32  lost+found  media  mnt  opt  proc  root  run  sbin  sys  tmp  usr  var
sudo umount /mnt
sudo dd if=/dev/loop0 of=void-live-powerpc-20230317.img
Output:
15222783+0 Datensätze ein
15222783+0 Datensätze aus
7794064896 Bytes (7,8 GB, 7,3 GiB) kopiert, 83,3552 s, 93,5 MB/s
/sbin/fsck.ext4 void-live-powerpc-20230317.img
Output:
void: clean, 175735/475776 files, 1476045/1902592 blocks
I increased the Void root disk image:
qemu-img resize void-live-powerpc-20230317.img +5G
/sbin/fsck.ext4 -f void-live-powerpc-20230317.img
Output:
void: 175735/475776 files (0.2% non-contiguous), 1476045/1902592 blocks
resize2fs void-live-powerpc-20230317.img
Output:
resize2fs 1.46.6-rc1 (12-Sep-2022)
Resizing the filesystem on void-live-powerpc-20230317.img to 3213567 (4k) blocks.
The filesystem on void-live-powerpc-20230317.img is now 3213567 (4k) blocks long.
We have copied the root partiton from the Void disk image to a new image and increased it.
Re: Void Linux
I was able to update Void in the root disk image yesterday. I think, this is the last Void disk image. Please change to Fienix in the future.
  • Noboot disk image (image without boot partition)
  • Fbdev is pre-configured
  • Renamed the libglamoregl.so to libglamoregl.so.bak
  • Yaru themes
  • Arctic Fox 40.1
  • Pale Moon 31.2
Download: void-live-powerpc-20230317.img.tar.gz (md5sum: 9e663d6045ffc24e58b7adbd4b9c9629)
If you want to enable hardware acceleration manually, then edit the file /etc/X11/xorg.conf. Change the "driver" from fbdev to radeon.
Re: Void Linux
Configure the language (locales) in Void PPC
  1. Choose your language:
    sudo vim /etc/default/libc-locales
    sudo xbps-reconfigure -f glibc-locales
  2. Replace the locale with yours in the file /etc/locale.conf
  3. Logout and then login again
BTW, here is a screenshot of the Void Installer in action:
Re: Void Linux
Important:
TRIM will not be activated automatically if Void runs on an SSD.
SSD TRIM enables an operating system to inform a NAND flash solid-state drive (SSD) which data blocks it can erase because they are no longer in use. The use of TRIM can improve the performance of writing data to SSDs and contribute to longer SSD life.
I tested fstrim manually today and it works.
I installed cronie and created a cron job for fstrim.
Screenshot with further information:
Thanks to Roland for the hint.
Re: Void Linux
There isn't a TV card software available for Void PPC. Therefore I created a TVtime package for Void PPC today.
Download: TVtime_1.0.11_linux-powerpc.tar.gz
Installation:
  1. Unpack the package and create the directory /usr/share/tvtime with the following command:
    sudo mkdir /usr/share/tvtime
  2. After that copy the font tvtimeSansBold.ttf to the directory /usr/share/tvtime/ with the following command:
    sudo cp usr/share/tvtime/tvtimeSansBold.ttf /usr/share/tvtime/
  3. Then you can start TVtime with ./tvtime.
