Fienix - New PowerPC Distro
kilaueabart wrote: Sat Aug 08, 2020 10:58 pm
caseycullen wrote: Wed Jul 29, 2020 5:50 am If you want to try out the new theme and tell me what you think, I packaged a "draft candidate" .deb that you can download here. After you install it, go to Control Center, Appearance, and select "Fienix Default".
I guess that's what I am using now, but only notice minor differences.
caseycullen
Post by caseycullen »
kilaueabart wrote: Sat Aug 08, 2020 12:40 am Curiouser and curiouser. Today I found gnucash-4.1.tar.bz2 in Downloads, but have no idea how it got there, since Synaptic refuses to send it. I did unarchive it and try unsuccessfully to figure out a way to run it from /Downloads/gnucash-4.1/, but utterly baffled.
Today I was successful at refreshing synaptic and upgrading. Then just for the heck of it I tried downloading gnucash-common and gnucash-docs, ignoring gnucash itself, and I was successful in installing them, or at least so Synaptic informs me. I haven't really tried to find out where they might be on my disk yet. Probably no real point in doing so, without the main program.
Made one more try at gnucash without success, but when I check its Properties on Synaptic, I get Status: [!] Broken. So now I am starting to wonder if there is something wrong with the package at Synaptic and not something broken on my own computer.
I hope I will be forgiven for copying this over from an ArcticFox board to this more appropriate one.
It looks like I probably missed some dependencies. I'll take a look.
-Casey
Clicking "Properties" at gnucash in Synaptic gets me this, as Depends, italicized:
libboost-regex1.71.0-icu67
(I have 1.71.0-6+b2. -icu67 not listed at Synaptic. Googling "libboost-regex1.71.0-icu67" gets me "libboost-regex1.71.0_1.71.0-6+b2_amd64.deb," and a couple similar, looking a lot like what I already have.)
perl:any
(I reportedly have perl already. libboost-regex1.71.0-icu67 would presumably be part of it.)
Replaces: gnucash-common (<1:2.4.8-1~)
caseycullen
Cave Story is a platform-adventure game that received widespread critical acclaim, and is now available in the Fienix software repository.
Thanks to EXL, the developer of the open-source NXEngine, for committing changes so it builds on PowerPC. Both the engine and the game data (released by Studio Pixel as freeware) are in the repository. Just install the package "cavestory", and if you experience any issues please let me know!
-Casey
caseycullen
xeno74 wrote: Mon Aug 10, 2020 1:38 pm Hi Casey,
I updated Fienix today. Unfortunately "mate-screenshot" doesn't work anymore. Could you please test it?
It works for me...
caseycullen
kilaueabart wrote: Fri Aug 14, 2020 1:38 am Clicking "Properties" at gnucash in Synaptic gets me this, as Depends, italicized:
perl:any
Could you please post the result of "apt-get install gnucash"?
Thanks.
caseycullen wrote: Fri Aug 14, 2020 4:43 am It works for me...
This dialog box works on my Fienix too but it doesn’t create any screenshots. I use mtPaint instead currently.
caseycullen wrote: Fri Aug 14, 2020 4:48 am Could you please post the result of "apt-get install gnucash"?
Thanks.
Sure. I wish everything were so easy.
root@Fienix:/home/fienix# apt-get install gnucash
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libbytes-random-secure-perl : Depends: libcrypt-random-seed-perl but it is not installable
                               Depends: libmath-random-isaac-perl but it is not installable
 libdatetime-format-strptime-perl : Depends: libdatetime-locale-perl (>= 1:1.23) but it is not going to be installed
                                    Depends: libdatetime-timezone-perl (>= 1:2.09) but it is not going to be installed
                                    Depends: libparams-validationcompiler-perl but it is not installable
                                    Depends: libspecio-perl but it is not installable
 libdatetime-perl : Depends: libdatetime-locale-perl (>= 1:1.06) but it is not going to be installed
                    Depends: libdatetime-timezone-perl (>= 1:2.02) but it is not going to be installed
                    Depends: libparams-validationcompiler-perl (>= 0.26) but it is not installable
 libgwenhywfar79 : Depends: libgnutls30 (>= 3.6.14) but 3.6.13-4 is to be installed
E: Unable to correct problems, you have held broken packages.
caseycullen
kilaueabart wrote: Sat Aug 15, 2020 10:58 pm Sure. I wish everything were so easy.
Please retry "apt-get install gnucash".
Casey
I did so immediately and the results were letter for letter the same as previously. Then I tried an apt-get update and repeated the apt-get install gnucash. At first glance it seemed like the same result, but no, curiously different:
 libgnutls30 : Depends: libhogweed6 (>= 3.4.1~rc1) but it is not installable
               Depends: libnettle8 (>= 3.4.1~rc1) but it is not installable
 libparams-validationcompiler-perl : Depends: libeval-closure-perl but it is not installable
                                     Depends: libexception-class-perl but it is not installable
                                     Recommends: libclass-xsaccessor-perl but it is not going to be installed
 libspecio-perl : Depends: libdevel-stacktrace-perl but it is not installable
                  Depends: libmro-compat-perl but it is not installable
                  Depends: libxstring-perl but it is not installable
                  Recommends: libref-util-perl but it is not installable
On a side note, when I tried to Preview the above, the Interweb had quit working. I Restarted but after 11 minutes of Stop jobs I clicked the machine and rebooted. No internet. Restarted again, ditto. So I reluctantly came to Ubuntu. I often get up to five Stop jobs when closing fienix, but the most common one is something like For User Manager ID 1000, which usually ends in less than two minutes.
