Kernel 5.1
Re: Kernel 5.1
I released the stable kernel 5.1.16 today.
  • X1000: pcmcia patch for solving the issues with new CF cards connected to the onboard CompactFlash Card Slot (Thanks to Darren)
  • X1000: Enabled the kernel config options CONFIG_PATA_PCMCIA, CONFIG_PCMCIA, and CONFIG_ELECTRA_CF for the pcmcia patch
  • X5000 and X1000: vgaarb patch for solving the issue with two graphics cards in an AmigaOne. Bug report: Bug 109345 - drm-next-2018-12-14 -Linux PPC
Download: linux-image-5.1.16-X1000_X5000.tar.gz
CF cards test thread
@SailorMH
Please test the kernels with your CF cards.
@Allan (Ace)
Please test the kernels with your two installed graphics cards and with your Logitech wireless USB mouse. Can you switch with CTRL-ALT-F1 (F2, F3, F4 etc) to another terminal after booting with the xorg.conf?
@Mechanic
Please test the kernels with your JMB363 card.
