openSUSE Tumbleweed
Re: openSUSE Tumbleweed
Problem solved. It was a network error:)
I was able to upgrade openSUSE Tumbleweed today. Before I had to modify the URLs of the repositories. I changed the protocol to 'https' except the packman repository. You can modify the repository URLs with YaST2 (Command yast as root - Software - Software Repositories - Select the repository - Edit - (x) Edit Complete URL - Change the protocol of the URL to https - [OK].
https://download.opensuse.org/ports/ppc/tumbleweed/repo/oss
https://download.opensuse.org/ports/ppc/tumbleweed/repo/non-oss
https://download.opensuse.org/ports/ppc/tumbleweed/repo/debug
http://packman.inode.at/suse/openSUSE_Tumbleweed
zypper dup
(dist-upgrade)
Unfortunately I get some kernel panics (wicedd Not tainted 5.2.0-rc1 .....). I will test more.
I deleted the systemd links to wicedd and after that it works including network.
openSUSE Tumbleweed 20190521 PPC64 on an AmigaOne X1000:
Image Image
Hi Christian.
Today I wanted to start SUSE but the upstart froze with what you can see in the picture. Do you have a suggestion on how to proceed.
xeno74 wrote:I deleted the systemd links to wicedd and after that it works including network.
How do you do that?
Thanks in advance
musa wrote:Hi Christian.
xeno74 wrote: How do you do that?
Thanks in advance
I booted ubuntu MATE 16.04.6 LTS and mounted the openSUSE partition. I removed all symbolic links to network and wicedd targets in the systemd directory "/etc/systemd/system". After that I configured the network device with YaST2.
I installed the NetworkManager with "zypper install NetworkManager" and after that I configured the network device with YaST2 and the NetworkManager. Additionally I installed LightDM. I will upload a new image.
Hi Christian. I am in and start upgrading. Then I get this :Could not resolve host: download.opensuse.org.
Where did I find the repository files. (Ysat2 cant be startet now )
Here you are:
Jo Christia5 i mean local files . I had edit them manual
musa wrote:Jo Christia5 i mean local files . I had edit them manual
I am sorry I don't know. I edited with YaST (terminal version). Maybe here: "/etc/zypp/repos.d".
