Kernel 5.5
Re: Kernel 5.5
I tested 5.5rc5 with my Dawicontrol SCSI board... It works now with 8 GB Ram !!!-)
I also digged up a RTL 8169 SCSI board which had the same problem... Works now, too!
What has been changed in 5.5 to make this miracle possble...?-)
Re: Kernel 5.5
acefnq wrote:5.5RC5 up and running fine.
Hi Ace,
Many thanks for testing the RC5!
Re: Kernel 5.5
Roland wrote:I tested 5.5rc5 with my Dawicontrol SCSI board... It works now with 8 GB Ram !!!-)
Hi Roland,
Great news! :-) Many thanks for testing! I’d like to figure out which patch solved the issue with your PCI cards. Could you also please test the alpha1 kernels?
  • X5000/20 and X5000/40: Default kernel (uImage-5.5) with the CoreNet DMA patch by Mike Rapoport
  • X5000/20 and X5000/40: Additional kernel (uImage-5.5-dma) with the latest DMA updates and with the memblock patch by Christoph Hellwig
  • X5000/20 and X5000/40: both kernels: CONFIG_SCSI_SYM53C8XX_DMA_ADDRESSING_MODE=1
Re: Kernel 5.5
xeno74 wrote: Great news! :-) Many thanks for testing! I’d like to figure out which patch solved the issue with your PCI cards. Could you also please test the alpha1 kernels?
Both uImage-5.5 and uImage-5.5-dma worked with my SCSI (tested a HD and a scanner) and RTL 8169 cards. uImage-5.5 gave an error message concerning some applet before it loaded the desktop completely, but after canceling it I was able to access a SCSI disk and internet normally.
Re: Kernel 5.5
Hi Roland,
Thanks a lot for testing! Now, we know that your SCSI cards work since the alpha1 of kernel 5.5. Could you update and close the bug report?
Re: Kernel 5.5
xeno74 wrote: Thanks a lot for testing! Now, we know that your SCSI cards work since the alpha1 of kernel 5.5. Could you update and close the bug report?
Done.
Re: Kernel 5.5
Roland wrote: Done.
Thank you! :-)
Re: Kernel 5.5
Here is the RC6 of kernel 5.5 for testing.
Download: linux-image-5.5-rc6-X1000_X5000.tar.gz
Re: Kernel 5.5
Kernel 5.5 RC6 up and running !
Big picture http://www.skateman.nl/wp-content/uploa ... 204252.png
Re: Kernel 5.5
5.5 RC6 working also here... (Couldn't resist, Alina !-).
