gordini21 wrote: Thu Feb 23, 2023 3:00 pm Hello,
First thanks for all the kernels.
the 6.1 works well on my X5000/20 but the latest 6.2 doesn't
boot i have this mesage "...cannot load kernel bad crc error"
any idea ?
Also thanks for the no-altivec version of Artic Fox :)
Did you test the final kernel 6.2?
@Skateman
Do you also have the bad crc error?
gordini21
Post by gordini21 »
yes the latest
i have the same error with the 6.3 kernel
My way of working :
I extract the archive on morphos and after i replace the dtb and the uimage on fienix-boot with the 2 new files
gordini21 wrote: Thu Feb 23, 2023 4:13 pm yes the latest
My way of working :
OK, could you also please test the RC8 of kernel 6.2?
gordini21
Post by gordini21 »
bad data crc same error
i have note installed the latest version of Fienix but i don't think that it is the issue
Please load the uImage to the address 4000000.
For example:
  1. Code: Select all
    X5000> usb reset
    Output: ... scaning usb for storage devices... 1 Storage Device(s) found ...
  2. Code: Select all
    X5000> ls usb 0:1
  3. Code: Select all
    X5000> setenv bootargs root=LABEL=void rootdelay=5
  4. Code: Select all
    X5000> fatload usb 0:1 4000000 uImage-6.2
  5. Code: Select all
    X5000> iminfo 4000000
  6. Code: Select all
    X5000> fatload usb 0:1 1c00000 cyrus_p5020.dtb
  7. Code: Select all
    X5000> fatload usb 0:1 2000000 uinitrd-5.10
  8. Code: Select all
    X5000> bootm 4000000 2000000 1c00000
gordini21
Post by gordini21 »
ok i will try that
I have add the boot script to the "linux button" a long time ago and i don't remenber how can i edit and modifiy the script into the Uboot
Do you have a link or a process to do that ?
thanks
Here you are: klick
gordini21
Post by gordini21 »
thanks
gordini21
Post by gordini21 »
it works :)
thanks a lot
and i took the opportunity to remind myself on the uboot commands. after my heart operation i forgot a lot of things.
Thanks again for your help and the great job
I have the same bad data crc error if I use an uInitrd.
X5000> bootm 1000000 2000000 1c00000
It boots if I don't use an uInitrd. I think the address 1c00000 is too low for the dtb file because the uImage uses this address too.
X5000> bootm 1000000 2000000 1d00000 -> Works!
The kernel has grown in recent months so the address 1c00000 is too low.
