sailorMH
Post by sailorMH »
Please, what kernel version do you use for daily work ?
With old distributions ( Debian 8, old wheezy-based MinPPC ) I am using kernel 5.5
I have it plan to use with newer distros ( Fienix, Debian 12/Sid, new MintPPC ) kernel 6.1. But I found there, that it has some booting issues with X1000.
I tested 6.1 and it has very strange behaviour. It boots mostly OK, but sometimes on login screen I cannot wrote login or passsword. ;-) Reset often not helps, but off/on yes.
And my X1000 has another boot issue. This time it is not connected with any kernel.
I have in CFE env variables for boot menu. If I select any linux ( old or new distro ), it show reading kernel, but then stucks.
BUT: if I interrupt CFE menu with "F" and go to commandline, then I type "menu" and return to the same menu what I interrupted before, I can normally select any menu item, and it boots without issues ;-)
sailorMH wrote: Wed May 17, 2023 7:04 pm Please, what kernel version do you use for daily work ?
The stable longterm kernel 5.10.
sailorMH
Post by sailorMH »
Thanks!
I released the RC3 of kernel 6.4 for the X1000 and X5000 today.
Download: linux-image-6.4-rc3-X1000_X5000.tar.gz
Please test,
The developers changed the values of ARCH_FORCE_MAX_ORDER.
Link: powerpc fix 6.4-3
X1000: CONFIG_ARCH_FORCE_MAX_ORDER=9 -> CONFIG_ARCH_FORCE_MAX_ORDER=12
X5000: CONFIG_ARCH_FORCE_MAX_ORDER=13 -> CONFIG_ARCH_FORCE_MAX_ORDER=12
Hi
Debianppc 64 bookworm and Fienix start with kernel vmlinux-6.4_rc3 without error
Have a nice day
musa wrote: Tue May 30, 2023 10:52 pm Hi
Have a nice day
Here is the RC4 of kernel 6.4 for testing.
Download: linux-image-6.4-rc4-X1000_X5000.tar.gz
Please test,
Hi
Linux6.4_rc4 boot Fienix but give me kernel panic on Debian 64 and debain 32 . Will try again later
Have a nice day
