OK, I am looking forward to your test results! Thanks!
Kernel 5.15
Re: Kernel 5.15
Re: Kernel 5.15
FYI:
Link to the thread: Add Apple M1 support to PASemi i2c driverI wrote: On 27 September 2021 at 07:39 am, Sven Peter wrote:
> Hi Christian,
> Thanks already for volunteering to test this!
Hello Sven,
Damien (Hypex) has successfully tested the RC3 of kernel 5.15 with your modified i2c driver on his Nemo board yesterday. [1]
@Darren
Could you also please check Sven's i2c modifications? He has also modified your source code a little bit. [2]
@Olof
Are these i2c modifications OK? Do these work on your P.A. Semi board?
[1] viewtopic.php?p=54098#p54098
[2] https://lists.ozlabs.org/pipermail/linu ... 53195.html
[3] Further information about the Nemo board: https://en.wikipedia.org/wiki/AmigaOne_X1000
[4] Kernel patches for the Nemo board: https://lists.ozlabs.org/pipermail/linu ... 67288.html
Re: Kernel 5.15
Hi Hypex,
Could you please post the output of the following commands with the default and with the modified RC3?
i2cdetect -l
Maybe you need to install "i2cdetect" with the command "apt install i2c-tools".
uname -a -
dmesg | grep -i i2c -
i2cdetect -l
i2cdetect -l
i2c-0 i2c Radeon i2c bit bus 0x90 I2C adapter
i2c-1 i2c Radeon i2c bit bus 0x91 I2C adapter
i2c-2 i2c Radeon i2c bit bus 0x92 I2C adapter
i2c-3 i2c Radeon i2c bit bus 0x93 I2C adapter
i2c-4 i2c Radeon i2c bit bus 0x94 I2C adapter
i2c-5 i2c Radeon i2c bit bus 0x95 I2C adapter
i2c-6 i2c Radeon i2c bit bus 0x96 I2C adapter
i2c-7 i2c Radeon i2c bit bus 0x97 I2C adapter
i2c-8 i2c card0-DP-1 I2C adapter
i2c-9 i2c card0-DP-2 I2C adapter
Re: Kernel 5.15
Hypex,
Sven can credit you with a Tested-by tag if you want.Sven wrote: Thanks a lot, that's great to hear!
If he wants to I can credit him with a Tested-by tag in the commit message,
see e.g. https://www.kernel.org/doc/html/latest/ ... -and-fixes.
Best,
Sven
Re: Kernel 5.15
I released the RC4 of kernel 5.15 for the X1000 and X5000 today.
- Linux 5.15-rc4 Released - The Kernel Is Looking "Pretty Normal"-- phoronix.com
- 5.15-rc4 announcement
- Linux Git log
- Phoronix articles, reviews and news stories covering Linux 5.15
Re: Kernel 5.15
Okay I got it!
I spot a potential issue. See for results.
Default:
Modified:
Default:
ienix@Fienix:~$ uname -a
Linux Fienix 5.15.0-rc3_A-EON_X1000_Nemo #1 SMP PREEMPT Mon Sep 27 08:03:51 CEST 2021 ppc64 GNU/Linux
fienix@Fienix:~$ dmesg | grep -i i2c
[ 5.526679] i2c_dev: i2c /dev entries driver
[ 5.851683] i2c i2c-8: Detected TI TMP423 chip at 0x4c
fienix@Fienix:~$ sudo i2cdetect -l
sudo: unable to resolve host Fienix: No address associated with hostname
[sudo] password for fienix:
i2c-8 i2c PA Semi SMBus adapter at 0x800200 I2C adapter
i2c-9 i2c PA Semi SMBus adapter at 0x800240 I2C adapter
i2c-10 i2c PA Semi SMBus adapter at 0x800280 I2C adapter
fienix@Fienix:~/Development/i2c-tools$ uname -a
Linux Fienix 5.15.0-rc3_A-EON_X1000_Nemo-00330-g0d8385b378c1-dirty #1 SMP PREEMPT Mon Sep 27 16:51:03 CEST 2021 ppc64 GNU/Linux
fienix@Fienix:~/Development/i2c-tools$ dmesg | grep -i i2c
[ 5.692849] i2c_dev: i2c /dev entries driver
[ 6.119582] i2c i2c-8: Detected TI TMP423 chip at 0x4c
fienix@Fienix:~/Development/i2c-tools$ sudo i2cdetect -l
i2c-8 i2c PA Semi SMBus adapter at 0x(____ptrval____) I2C adapter
i2c-9 i2c PA Semi SMBus adapter at 0x(____ptrval____) I2C adapter
i2c-10 i2c PA Semi SMBus adapter at 0x(____ptrval____) I2C adapterRe: Kernel 5.15
Thanks. There is an error in the archive. There is a vmlinux5.14 file but it looks for be the right version.
ienix@Fienix:~$ grep -a "Linux version 5" '/home/fienix/Downloads/vmlinux-5.14'
Linux version 5.15.0-rc4_A-EON_X1000_Nemo ([email protected]) (powerpc-linux-gnu-gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP PREEMPT Mon Oct 4 05:30:46 CEST 2021
Re: Kernel 5.15
OK, I see it. I will report the issue to Sven. Many thanks for testing! You helps me a lot.
Re: Kernel 5.15
It was my fault. It is the correct kernel with unfortunately the wrong name. It was to early in the morning for compiling a kernel.Hypex wrote: Mon Oct 04, 2021 10:42 am Thanks. There is an error in the archive. There is a vmlinux5.14 file but it looks for be the right version.Code: Select all
ienix@Fienix:~$ grep -a "Linux version 5" '/home/fienix/Downloads/vmlinux-5.14' Linux version 5.15.0-rc4_A-EON_X1000_Nemo ([email protected]) (powerpc-linux-gnu-gcc (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP PREEMPT Mon Oct 4 05:30:46 CEST 2021
Re: Kernel 5.15
Hi Hypex,
I reported the issue to Sven today.
Link: Add Apple M1 support to PASemi i2c driver
Thanks a lot for your help!
