Arctic Fox
YouTube videos in HD with ViewTube and Arctic Fox
Installation instructions for ubuntu MATE 16.04.6 PowerPC
  1. Install VLC and the VLC browser plugin with the following command:
    sudo apt-get install browser-plugin-vlc
  2. Start Arctic Fox and install the add-on Greasemonkey version 3.31.4
  3. Restart Arctic Fox
  4. After that, add the ViewTube script to Greasemonkey
  5. Then you have to activate the VLC plugin. You can activate it via Menu Tools - Add-ons - Plugins.
Image[/quote]
Arctic Fox 27.9.17 has been released.
Download: github.com/wicknix/Arctic-Fox
Change Log: github.com/wicknix/Arctic-Fox/releases/tag/v27.9.17
I released Arctic Fox 27.9.17 for old Linux PowerPC distributions like Ubuntu 10.04 or higher today.
Download: arcticfox-27.9.17-ubuntu10.04-powerpc.tar.bz2
For Ubuntu 10.04: You need to install the GCC 4.8 and the libatomic1 via the repository 'ppa:ubuntu-toolchain-r/test'.
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update; sudo apt-get install gcc-4.8 g++-4.8
For Ubuntu 12.04: You need the libatomic1 package. Download: libatomic-ubuntu12.04-powerpc.tar.bz2
Please copy the file 'libatomic.so.1' to '/usr/lib/powerpc-linux-gnu/' with the following command:
sudo cp libatomic.so.1 /usr/lib/powerpc-linux-gnu/
Screenshot of Arctic Fox 27.9.17 on Ubuntu 10.04.4 LTS PowerPC:
I released Arctic Fox 27.9.17 64-bit for openSUSE Tumbleweed PPC64 and for Fedora PPC64 today.
Download: arcticfox-27.9.17.linux-powerpc64.tar.bz2
Arctic Fox 27.9.17 64-bit on Fedora Server PPC64:
sailorMH
Post by sailorMH »
good work Xeno74!
it runs out of the box also with Debian 8, toolchain, gcc version 4.9.2 (Debian 4.9.2-10+deb8u1)
sailorMH wrote:good work Xeno74!
Do you use the 64-bit or the 32-bit version of Debian 8?
sailorMH
Post by sailorMH »
xeno74 wrote: Do you use the 64-bit or the 32-bit version of Debian 8?
64 bit
tata@amigaone:~/arcticfox$ lscpu
Architektura:          ppc64
Operační režim(y) CPU:32-bit, 64-bit
Pořadí bajtů:       Big Endian
Počet CPU:            2
Seznam zapnutých CPU: 0,1
Vláken na jádro:     1
Jader na patici:       1
Patic:                 2
Model:                 pasemi,nemo
L1d keš:              64K
L1i keš:              64K
64 bit
Architektura:          ppc64
Počet CPU:            2
Vláken na jádro:     1
Jader na patici:       1
Patic:                 2
Model:                 pasemi,nemo
L1d keš:              64K
L1i keš:              64K
Great! Do you use the 64-bit package of Arctic Fox for openSUSE Tumbleweed PPC64 and Fedora Server PPC64 on Debian?
Could you please post the output of file arcticfox and ldd arcticfox?
sailorMH
Post by sailorMH »
xeno74 wrote: Great! Do you use the 64-bit package of Arctic Fox for openSUSE Tumbleweed PPC64 and Fedora Server PPC64 on Debian?
No, I am used 32-bit ubuntu version (arcticfox-27.9.17-ubuntu10.04-powerpc.tar.bz2), as ubuntu is basicaly debian
I will test the also 64-bit OpenSUSE and Fedora version on weekend, and post results.
sailorMH wrote: No, I am used 32-bit ubuntu version (arcticfox-27.9.17-ubuntu10.04-powerpc.tar.bz2), as ubuntu is basicaly debian
Thank you! :-) You need a 64-bit version of Debian (64-bit kernel + 64-bit userland) for testing the 64-bit version of Arctic Fox.
sailorMH
Post by sailorMH »
Hi, here is
arcticfox 32bit version outputs:
tata@amigaone:~/arcticfox$ file arcticfox
arcticfox: ELF 32-bit MSB executable, PowerPC or cisco 4500, version 1 (SYSV), dynamically linked, interpreter /lib/ld.so.1, for GNU/Linux 2.6.15, BuildID[sha1]=671a51aae13c091e03580de87d16989b66314bc7, stripped
tata@amigaone:~/arcticfox$ ldd arcticfox
	linux-vdso32.so.1 (0x00100000)
	libpthread.so.0 => /lib/powerpc-linux-gnu/libpthread.so.0 (0x0ffc5000)
	libatomic.so.1 => /usr/lib/powerpc-linux-gnu/libatomic.so.1 (0x0ff9e000)
	libdl.so.2 => /lib/powerpc-linux-gnu/libdl.so.2 (0x0ff7a000)
	librt.so.1 => /lib/powerpc-linux-gnu/librt.so.1 (0x0ff51000)
	libstdc++.so.6 => /usr/lib/powerpc-linux-gnu/libstdc++.so.6 (0x0fe05000)
	libm.so.6 => /lib/powerpc-linux-gnu/libm.so.6 (0x0fd30000)
	libgcc_s.so.1 => /lib/powerpc-linux-gnu/libgcc_s.so.1 (0x0fcfa000)
	libc.so.6 => /lib/powerpc-linux-gnu/libc.so.6 (0x0fb58000)
	/lib/ld.so.1 (0x2047c000)
