seventhwonder
Post by seventhwonder »
Dear Spectre
Unfortunately this one crashes too :(
Here is the serial output from my Sam460
Hidden Text - Click to Show :
U-Boot 2010.06.05 (Apr 14 2011 - 10:54:55)
CPU: AMCC PowerPC 460EX Rev. B at 1150 MHz (PLB=230 OPB=115 EBC=115)
No Security/Kasumi support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
Internal PCI arbiter enabled
32 kB I-Cache 32 kB D-Cache
Board: Sam460ex, PCIe 4x + PCIe 1x
I2C: ready
DRAM: 2 GiB (ECC not enabled, 460 MHz, CL4)
PCI: Bus Dev VenId DevId Class Int
00 04 1095 3512 0104 00
00 06 126f 0501 0380 00
PCIE0: successfully set as root-complex
03 00 1412 1724 0401 ff
02 00 1b21 1080 0604 00
PCIE1: successfully set as root-complex
05 00 1002 68da 0300 ff
Net: ppc_4xx_eth0
FPGA: Revision 03 (2010-10-07)
SM502: found
VGA: 1
VESA: OK
** 61 printk messages dropped ** IO 0x0000000f80000000..0x0000000f8000ffff -> 0x0000000000000000
4xx PCI DMA offset set to 0x00000000
4xx PCI DMA window base to 0x0000000000000000
DMA window size 0x0000000080000000
PCIE1: Checking link...
PCIE1: Device detected, waiting for link...
PCIE1: link is up !
PCI host bridge /plb/pciex@d20000000 (primary) ranges:
MEM 0x0000000e80000000..0x0000000effffffff -> 0x0000000080000000
MEM 0x0000000f00100000..0x0000000f001fffff -> 0x0000000000000000
IO 0x0000000f80010000..0x0000000f8001ffff -> 0x0000000000000000
PCI host bridge /plb/pci@c0ec00000 (primary) ranges:
MEM 0x0000000d80000000..0x0000000dffffffff -> 0x0000000080000000
MEM 0x0000000c0ee00000..0x0000000c0eefffff -> 0x0000000000000000
IO 0x0000000c08000000..0x0000000c0800ffff -> 0x0000000000000000
PCI: Probing PCI hardware
PCI host bridge to bus 0000:40
pci_bus 0000:40: root bus resource [io 0xfffc0000-0xfffcffff] (bus address [0x0000-0xffff])
pci_bus 0000:40: root bus resource [mem 0xe00000000-0xe7fffffff] (bus address [0x80000000-0xffffffff])
pci_bus 0000:40: root bus resource [mem 0xf00000000-0xf000fffff] (bus address [0x00000000-0x000fffff])
pci_bus 0000:40: root bus resource [bus 40-ff]
PCI: Hiding 4xx host bridge resources 0000:40:00.0
pci 0000:40:00.0: PCI bridge to [bus 41-7f]
pci 0000:41:00.0: bridge configuration invalid ([bus 02-02]), reconfiguring
pci 0000:41:00.0: PCI bridge to [bus 42-ff]
PCI host bridge to bus 0001:80
pci_bus 0001:80: root bus resource [io 0xfffe0000-0xfffeffff] (bus address [0x0000-0xffff])
pci_bus 0001:80: root bus resource [mem 0xe80000000-0xeffffffff] (bus address [0x80000000-0xffffffff])
pci_bus 0001:80: root bus resource [mem 0xf00100000-0xf001fffff] (bus address [0x00000000-0x000fffff])
pci_bus 0001:80: root bus resource [bus 80-ff]
PCI: Hiding 4xx host bridge resources 0001:80:00.0
pci 0001:80:00.0: PCI bridge to [bus 81-bf]
PCI host bridge to bus 0002:00
pci_bus 0002:00: root bus resource [io 0x0000-0xffff]
pci_bus 0002:00: root bus resource [mem 0xd80000000-0xdffffffff] (bus address [0x80000000-0xffffffff])
pci_bus 0002:00: root bus resource [mem 0xc0ee00000-0xc0eefffff] (bus address [0x00000000-0x000fffff])
pci_bus 0002:00: root bus resource [bus 00-ff]
pci 0000:40:00.0: BAR 7: assigned [io 0xfffc1000-0xfffc1fff]
pci 0000:41:00.0: BAR 7: assigned [io 0xfffc1000-0xfffc1fff]
pci 0000:42:00.0: BAR 1: assigned [io 0xfffc1000-0xfffc107f]
pci 0000:42:00.0: BAR 0: assigned [io 0xfffc1080-0xfffc109f]
pci 0000:41:00.0: PCI bridge to [bus 42]
pci 0000:41:00.0: bridge window [io 0xfffc1000-0xfffc1fff]
pci 0000:40:00.0: bridge window [io 0xfffc1000-0xfffc1fff]
pci 0001:80:00.0: BAR 9: assigned [mem 0xe80000000-0xe8fffffff 64bit pref]
pci 0001:80:00.0: BAR 8: assigned [mem 0xe90000000-0xe900fffff]
pci 0001:80:00.0: BAR 7: assigned [io 0xfffe1000-0xfffe1fff]
pci 0001:81:00.0: BAR 0: assigned [mem 0xe80000000-0xe8fffffff 64bit pref]
pci 0001:81:00.0: BAR 2: assigned [mem 0xe90000000-0xe9001ffff 64bit]
pci 0001:81:00.0: BAR 6: assigned [mem 0xe90020000-0xe9003ffff pref]
pci 0001:81:00.1: BAR 0: assigned [mem 0xe90040000-0xe90043fff 64bit]
pci 0001:81:00.0: BAR 4: assigned [io 0xfffe1000-0xfffe10ff]
pci 0001:80:00.0: bridge window [io 0xfffe1000-0xfffe1fff]
pci 0001:80:00.0: bridge window [mem 0xe90000000-0xe900fffff]
pci 0001:80:00.0: bridge window [mem 0xe80000000-0xe8fffffff 64bit pref]
pci 0002:00:06.0: BAR 0: assigned [mem 0xd80000000-0xd83ffffff]
pci 0002:00:06.0: BAR 1: assigned [mem 0xd84000000-0xd841fffff]
pci 0002:00:04.0: BAR 6: assigned [mem 0xd84200000-0xd8427ffff pref]
pci 0002:00:04.0: BAR 5: assigned [mem 0xd84280000-0xd842801ff]
pci 0002:00:04.0: BAR 4: assigned [io 0x1000-0x100f]
pci 0002:00:04.0: BAR 0: assigned [io 0x1010-0x1017]
pci 0002:00:04.0: BAR 2: assigned [io 0x1018-0x101f]
pci 0002:00:04.0: BAR 1: assigned [io 0x1020-0x1023]
pci 0002:00:04.0: BAR 3: assigned [io 0x1024-0x1027]
vgaarb: device added: PCI:0001:81:00.0,decodes=io+mem,owns=none,locks=none
vgaarb: loaded
vgaarb: bridge control possible 0001:81:00.0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource timebase
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Could not remap bcsr
genirq: Setting trigger mode 3 for irq 45 failed (uic_set_irq_type+0x0/0x210)
futex hash table entries: 256 (order: -1, 3072 bytes)
msgmni has been set to 1490
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
aer: probe of 0000:40:00.0:pcie02 failed with error -22
aer: probe of 0001:80:00.0:pcie02 failed with error -22
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0x4ef600300 (irq = 23, base_baud = 691200) is a U6_16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x4ef600400 (irq = 24, base_baud = 691200) is a U6_16550A
** 66 printk messages dropped ** PCIE1: Checking link...
PCIE1: link is up !
vgaarb: loaded
4ef600300.serial: ttyS0 at MMIO 0x4ef600300 (irq = 23, base_baud = 691200) is a 16550
4ef600400.serial: ttyS1 at MMIO 0x4ef600400 (irq = 24, base_baud = 691200) is a 16550
brd: module loaded
sm501 0002:00:06.0: enabling device (0004 -> 0006)
sm501 0002:00:06.0: incorrect device id c0000105
sata_sil 0002:00:04.0: Applying R_ERR on DMA activate FIS errata fix
scsi host0: sata_sil
scsi host1: sata_sil
ata1: SATA max UDMA/100 mmio m512@0xd84280000 tf 0xd84280080 irq 22
ata2: SATA max UDMA/100 mmio m512@0xd84280000 tf 0xd842800c0 irq 22
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ppc-of-ehci 4bffd0400.ehci: OF EHCI
ppc-of-ehci 4bffd0400.ehci: new USB bus registered, assigned bus number 1
ppc-of-ehci 4bffd0400.ehci: irq 32, io mem 0x4bffd0400
ppc-of-ehci 4bffd0400.ehci: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OF EHCI
usb usb1: Manufacturer: Linux 3.17.0-Sam460ex ehci_hcd
usb usb1: SerialNumber: PPC-OF USB
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
rtc-m41t80 0-0068: rtc core: registered m41t80 as rtc0
ibm-iic 4ef600700.i2c: using standard (100 kHz) mode
ibm-iic 4ef600800.i2c: using standard (100 kHz) mode
ad7414 0-0048: chip found
ad7414 0-0048: ad7414_probe unable to read config register.
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
usbcore: registered new interface driver ushc
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 17
rtc-m41t80 0-0068: setting system clock to 2014-10-09 21:18:07 UTC (1412889487)
ALSA device list:
No soundcards found.
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
ata1.00: ATA-8: Corsair CSSD-F40GB2, 2.0, max UDMA/133
ata1.00: 78161328 sectors, multi 16: LBA48 NCQ (depth 0/32)
usb 1-1: new high-speed USB device number 2 using ppc-of-ehci
ata1.00: configured for UDMA/100
scsi 0:0:0:0: Direct-Access ATA Corsair CSSD-F40 2.0 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 78161328 512-byte logical blocks: (40.0 GB/37.2 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: RDSK (512) sda1 (SFS^B)(res 2 spb 2) sda2 (SFS^@)(res 2 spb 2) sda3 (SFS^@)(res 2 spb 2) sda4 (DOS^G)(res 2 spb 2)
sd 0:0:0:0: [sda] Attached SCSI disk
usb 1-1: New USB device found, idVendor=0424, idProduct=2517
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 7 ports detected
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
ata2.00: ATA-8: TEAM A1 SSD 30GB, S5FAM030, max UDMA/100
ata2.00: 62533296 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata2.00: configured for UDMA/100
scsi 1:0:0:0: Direct-Access ATA TEAM A1 SSD 30GB M030 PQ: 0 ANSI: 5
sd 1:0:0:0: [sdb] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdb: RDSK (512) sdb1 (LNX^@)(res 2 spb 1) sdb2 (EXT^C)(res 2 spb 1) sdb3 (SWP^@)(res 2 spb 1)
sd 1:0:0:0: [sdb] Attached SCSI disk
kjournald starting. Commit interval 5 seconds
EXT3-fs (sdb2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) readonly on device 8:18.
Freeing unused kernel memory: 208K (c055c000 - c0590000)
usb 1-1.1: new full-speed USB device number 3 using ppc-of-ehci
usb 1-1.1: New USB device found, idVendor=046d, idProduct=c52b
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.1: Product: USB Receiver
usb 1-1.1: Manufacturer: Logitech
input: Logitech USB Receiver as /devices/plb/4bffd0400.ehci/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C52B.0001/input/input0
hid-generic 0003:046D:C52B.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-PPC-OF USB-1.1/input0
input: Logitech USB Receiver as /devices/plb/4bffd0400.ehci/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C52B.0002/input/input1
hid-generic 0003:046D:C52B.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-PPC-OF USB-1.1/input1
hid-generic 0003:046D:C52B.0003: device has no listeners, quitting
random: init urandom read with 30 bits of entropy available
usb 1-1.7: new high-speed USB device number 4 using ppc-of-ehci
usb 1-1.7: New USB device found, idVendor=0424, idProduct=2240
usb 1-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.7: Product: Ultra Fast Media
usb 1-1.7: Manufacturer: Generic
usb 1-1.7: SerialNumber: 000000225001
usb-storage 1-1.7:1.0: USB Mass Storage device detected
scsi host2: usb-storage 1-1.7:1.0
scsi 2:0:0:0: Direct-Access Generic Ultra HS-COMBO 1.68 PQ: 0 ANSI: 0
sd 2:0:0:0: [sdc] 3911680 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 2:0:0:0: [sdc] Write Protect is off
sd 2:0:0:0: [sdc] No Caching mode page found
sd 2:0:0:0: [sdc] Assuming drive cache: write through
sdc: RDSK (512) sdc1 (SFS^@)(res 2 spb 2)
sd 2:0:0:0: [sdc] Attached SCSI removable disk
radeon 0001:81:00.0: ppc4xx_setup_msi_irqs: fail mapping irq
Unable to handle kernel paging request for data at address 0x0f9f5d9c
Faulting instruction address: 0xc020f0a0
Canyonlands
Modules linked in: radeon(+) cfbfillrect cfbimgblt cfbcopyarea i2c_algo_bit drm_kms_helper ttm drm agpgart
CPU: 0 PID: 1342 Comm: systemd-udevd Not tainted 3.17.0-Sam460ex #1
task: ef0ff860 ti: ef3d6000 task.ti: ef3d6000
NIP: c020f0a0 LR: c0014388 CTR: 00000001
REGS: ef3d7af0 TRAP: 0300 Not tainted (3.17.0-Sam460ex)
MSR: 00021000 <CE,ME> CR: 24248484 XER: 20000000
DEAR: 0f9f5d9c ESR: 00000000
GPR00: c001a068 ef3d7ba0 ef0ff860 0f9f5d98 ffefffff 00000001 00000002 00000002
GPR08: 00000020 00000001 1ffffff8 00000000 24248424 1005504c 00000050 c0069350
GPR16: 00000000 00000124 eec627c8 f98dd9c4 eec62800 00000001 c059729c eec627c0
GPR24: 00000000 ef8c0c00 c06be578 ef8c0fc8 00000000 ef059360 fffffff4 00029000
NIP [c020f0a0] __reg_op+0xd0/0x130
LR [c0014388] msi_bitmap_free_hwirqs+0x38/0x50
Call Trace:
[ef3d7ba0] [00000002] 0x2 (unreliable)
[ef3d7bb0] [c001a068] ppc4xx_setup_msi_irqs+0x108/0x130
[ef3d7bf0] [c023bfe8] pci_enable_msi_range+0x1c8/0x320
[ef3d7c30] [f97c19f0] radeon_irq_kms_init+0x150/0x1d0 [radeon]
[ef3d7c40] [f980eb28] evergreen_startup+0x12c8/0x2270 [radeon]
[ef3d7c70] [f980fda0] evergreen_init+0x1f0/0x3b0 [radeon]
[ef3d7c80] [f978b46c] radeon_device_init+0x66c/0xb20 [radeon]
[ef3d7ca0] [f978e2b8] radeon_driver_load_kms+0x88/0x160 [radeon]
[ef3d7cc0] [f94aa5e4] drm_dev_register+0xd4/0x140 [drm]
[ef3d7ce0] [f94ad420] drm_get_pci_dev+0xc0/0x1c0 [drm]
[ef3d7d00] [c0229df8] pci_device_probe+0x98/0x100
[ef3d7d20] [c02838e4] really_probe+0x84/0x270
[ef3d7d40] [c0283c48] __driver_attach+0xc8/0xd0
[ef3d7d60] [c0281918] bus_for_each_dev+0x68/0xc0
[ef3d7d90] [c0282f18] bus_add_driver+0x178/0x250
[ef3d7db0] [c0284428] driver_register+0x88/0x140
[ef3d7dc0] [c00016a0] do_one_initcall+0xa0/0x200
[ef3d7e30] [c006c314] load_module+0x18c4/0x1da0
[ef3d7ee0] [c006c990] SyS_finit_module+0x80/0xb0
[ef3d7f40] [c000c208] ret_from_syscall+0x0/0x3c
--- interrupt: c01 at 0xfe1a5b0
LR = 0xfefc08c
Instruction dump:
38600001 4e800020 60000000 60000000 2f850000 419effa4 7ca903a6 554a103a
394afffc 7c8420f8 7c635214 60000000 <85230004> 7d292038 91230000 4200fff4
---[ end trace f181d8ff94488feb ]---
AmigaOS4 Beta-Tester
Thanks for testing.
Looks like I am stuck with the 3.17 line.
seventhwonder
Dear spectre
Do we need kernel 3.17 to enable hardware acceleration ?
Short answer is no.
Hardware acceleration on Sams just does not seem to work with the Kernels after version 3.3.x .
Virgola was able to get 2D acceleration working on his video card with a 3.3.x kernel that he compiled.
It would not work with my Radeon HD4850 card when I tried it .
Several people with way more knowledge than I have asked the kernel experts for help with this and
were not been able to get anything resolved . I also see some of the same serial debug errors that we get
in support threads for power 4x0 boards but no final solutions.
http://lists.x.org/archives/xorg-driver ... 24410.html
http://lists.freedesktop.org/archives/d ... 45050.html
seventhwonder wrote:Dear spectre
:) Thank you :)
Kernel 3.16.5 for the Sam440ep( Flex): Sam440ep-3.16.5.tar.gz
Kernel 3.16.5 for the Sam460ex( Lite): Sam460ex-3.16.5.tar.gz
Sam440ep 3.18-rc1 Kernel (Untested)
https://dl.dropboxusercontent.com/u/542 ... rc1.tar.gz
Sam460ex 3.18-rc1 Kernel (Untested)
seventhwonder
Installed 3.18-rc1 on Sam460, unfortunately it crashes
Here is the serial log:
I2C: ready
05 00 1002 6759 0300 ff
Net: ppc_4xx_eth0
SM502: found
VGA: 1
VESA: OK
[ 0.000000] Using Canyonlands machine description
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.18.0-rc1-Sam460ex (root@julian-VirtualBox) (gcc version 4.8.2 (Ubuntu 4.8.2-16ubuntu3) ) #1 PREEMPT Tue Oct 21 07:56:12 AST 2014
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00000000-0x2fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x30000000-0x7fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x7fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x7fffffff]
[ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: root=/dev/sdb2 radeon.dpm=0 console=ttyS0,115200 console=tty0
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Sorting __ex_table...
[ 0.000000] Memory: 2005624K/2097152K available (5964K kernel code, 232K rwdata, 1492K rodata, 236K init, 314K bss, 91528K reserved, 1310720K highmem)
[ 0.000000] Kernel virtual memory layout:
[ 0.000000] * 0xfffcf000..0xfffff000 : fixmap
[ 0.000000] * 0xffc00000..0xffe00000 : highmem PTEs
[ 0.000000] * 0xffa00000..0xffc00000 : consistent mem
[ 0.000000] * 0xffa00000..0xffa00000 : early ioremap
[ 0.000000] * 0xf1000000..0xffa00000 : vmalloc & ioremap
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:512 nr_irqs:512 16
[ 0.000000] UIC0 (32 IRQ sources) at DCR 0xc0
[ 0.000000] UIC1 (32 IRQ sources) at DCR 0xd0
[ 0.000000] UIC2 (32 IRQ sources) at DCR 0xe0
[ 0.000000] UIC3 (32 IRQ sources) at DCR 0xf0
[ 0.000012] clocksource: timebase mult[de9bd3] shift[24] registered
[ 0.000140] Console: colour dummy device 80x25
[ 0.000582] console [tty0] enabled
[ 0.000611] pid_max: default: 32768 minimum: 301
[ 0.000718] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000740] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002908] devtmpfs: initialized
[ 0.004209] xor: measuring software checksum speed
[ 0.014387] 8regs : 852.000 MB/sec
[ 0.024285] 8regs_prefetch: 780.000 MB/sec
[ 0.034321] 32regs : 1112.000 MB/sec
[ 0.044384] 32regs_prefetch: 992.000 MB/sec
[ 0.044415] xor: using function: 32regs (1112.000 MB/sec)
[ 0.046235] NET: Registered protocol family 16
[ 0.047985] 256k L2-cache enabled
[ 0.048103] PCIE0: Checking link...
[ 0.048116] PCIE0: Device detected, waiting for link...
[ 0.048131] PCIE0: link is up !
[ 0.150273] PCI host bridge /plb/pciex@d00000000 (primary) ranges:
[ 0.150315] MEM 0x0000000e00000000..0x0000000e7fffffff -> 0x0000000080000000
[ 0.150342] MEM 0x0000000f00000000..0x0000000f000fffff -> 0x0000000000000000
[ 0.150365] IO 0x0000000f80000000..0x0000000f8000ffff -> 0x0000000000000000
[ 0.150391] 4xx PCI DMA offset set to 0x00000000
[ 0.150404] 4xx PCI DMA window base to 0x0000000000000000
[ 0.150418] DMA window size 0x0000000080000000
[ 0.150449] PCIE0: successfully set as root-complex
[ 0.150491] PCIE1: Checking link...
[ 0.150503] PCIE1: Device detected, waiting for link...
[ 0.150517] PCIE1: link is up !
[ 0.252541] PCI host bridge /plb/pciex@d20000000 (primary) ranges:
[ 0.252574] MEM 0x0000000e80000000..0x0000000effffffff -> 0x0000000080000000
[ 0.252600] MEM 0x0000000f00100000..0x0000000f001fffff -> 0x0000000000000000
[ 0.252622] IO 0x0000000f80010000..0x0000000f8001ffff -> 0x0000000000000000
[ 0.252647] 4xx PCI DMA offset set to 0x00000000
[ 0.252660] 4xx PCI DMA window base to 0x0000000000000000
[ 0.252674] DMA window size 0x0000000080000000
[ 0.252700] PCIE1: successfully set as root-complex
[ 0.252786] PCI host bridge /plb/pci@c0ec00000 (primary) ranges:
[ 0.252808] MEM 0x0000000d80000000..0x0000000dffffffff -> 0x0000000080000000
[ 0.252834] MEM 0x0000000c0ee00000..0x0000000c0eefffff -> 0x0000000000000000
[ 0.252856] IO 0x0000000c08000000..0x0000000c0800ffff -> 0x0000000000000000
[ 0.252879] 4xx PCI DMA offset set to 0x00000000
[ 0.252892] 4xx PCI DMA window base to 0x0000000000000000
[ 0.252906] DMA window size 0x0000000080000000
[ 0.262573] PCI: Probing PCI hardware
[ 0.262913] PCI host bridge to bus 0000:40
[ 0.262949] pci_bus 0000:40: root bus resource [io 0xfffc0000-0xfffcffff] (bus address [0x0000-0xffff])
[ 0.262978] pci_bus 0000:40: root bus resource [mem 0xe00000000-0xe7fffffff] (bus address [0x80000000-0xffffffff])
[ 0.263007] pci_bus 0000:40: root bus resource [mem 0xf00000000-0xf000fffff] (bus address [0x00000000-0x000fffff])
[ 0.263036] pci_bus 0000:40: root bus resource [bus 40-ff]
[ 0.263154] PCI: Hiding 4xx host bridge resources 0000:40:00.0
[ 0.265253] pci 0000:40:00.0: PCI bridge to [bus 41-7f]
[ 0.265357] pci 0000:41:00.0: bridge configuration invalid ([bus 02-02]), reconfiguring
[ 0.265952] pci 0000:41:00.0: PCI bridge to [bus 42-ff]
[ 0.266174] PCI host bridge to bus 0001:80
[ 0.266201] pci_bus 0001:80: root bus resource [io 0xfffe0000-0xfffeffff] (bus address [0x0000-0xffff])
[ 0.266251] pci_bus 0001:80: root bus resource [mem 0xe80000000-0xeffffffff] (bus address [0x80000000-0xffffffff])
[ 0.266280] pci_bus 0001:80: root bus resource [mem 0xf00100000-0xf001fffff] (bus address [0x00000000-0x000fffff])
[ 0.266308] pci_bus 0001:80: root bus resource [bus 80-ff]
[ 0.266407] PCI: Hiding 4xx host bridge resources 0001:80:00.0
[ 0.269309] pci 0001:80:00.0: PCI bridge to [bus 81-bf]
[ 0.269603] PCI host bridge to bus 0002:00
[ 0.269628] pci_bus 0002:00: root bus resource [io 0x0000-0xffff]
[ 0.269651] pci_bus 0002:00: root bus resource [mem 0xd80000000-0xdffffffff] (bus address [0x80000000-0xffffffff])
[ 0.269680] pci_bus 0002:00: root bus resource [mem 0xc0ee00000-0xc0eefffff] (bus address [0x00000000-0x000fffff])
[ 0.269709] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 0.270489] pci 0000:40:00.0: BAR 13: assigned [io 0xfffc1000-0xfffc1fff]
[ 0.270523] pci 0000:41:00.0: BAR 13: assigned [io 0xfffc1000-0xfffc1fff]
[ 0.270547] pci 0000:42:00.0: BAR 1: assigned [io 0xfffc1000-0xfffc107f]
[ 0.270572] pci 0000:42:00.0: BAR 0: assigned [io 0xfffc1080-0xfffc109f]
[ 0.270596] pci 0000:41:00.0: PCI bridge to [bus 42]
[ 0.270616] pci 0000:41:00.0: bridge window [io 0xfffc1000-0xfffc1fff]
[ 0.270644] pci 0000:40:00.0: PCI bridge to [bus 41-7f]
[ 0.270662] pci 0000:40:00.0: bridge window [io 0xfffc1000-0xfffc1fff]
[ 0.270751] pci 0001:80:00.0: BAR 15: assigned [mem 0xe80000000-0xe8fffffff 64bit pref]
[ 0.270776] pci 0001:80:00.0: BAR 14: assigned [mem 0xe90000000-0xe900fffff]
[ 0.270798] pci 0001:80:00.0: BAR 13: assigned [io 0xfffe1000-0xfffe1fff]
[ 0.270830] pci 0001:81:00.0: BAR 0: assigned [mem 0xe80000000-0xe8fffffff 64bit pref]
[ 0.270862] pci 0001:81:00.0: BAR 2: assigned [mem 0xe90000000-0xe9001ffff 64bit]
[ 0.270892] pci 0001:81:00.0: BAR 6: assigned [mem 0xe90020000-0xe9003ffff pref]
[ 0.270918] pci 0001:81:00.1: BAR 0: assigned [mem 0xe90040000-0xe90043fff 64bit]
[ 0.270948] pci 0001:81:00.0: BAR 4: assigned [io 0xfffe1000-0xfffe10ff]
[ 0.270971] pci 0001:80:00.0: PCI bridge to [bus 81-bf]
[ 0.270990] pci 0001:80:00.0: bridge window [io 0xfffe1000-0xfffe1fff]
[ 0.271010] pci 0001:80:00.0: bridge window [mem 0xe90000000-0xe900fffff]
[ 0.271031] pci 0001:80:00.0: bridge window [mem 0xe80000000-0xe8fffffff 64bit pref]
[ 0.271117] pci 0002:00:06.0: BAR 0: assigned [mem 0xd80000000-0xd83ffffff]
[ 0.271140] pci 0002:00:06.0: BAR 1: assigned [mem 0xd84000000-0xd841fffff]
[ 0.271163] pci 0002:00:04.0: BAR 6: assigned [mem 0xd84200000-0xd8427ffff pref]
[ 0.271187] pci 0002:00:04.0: BAR 5: assigned [mem 0xd84280000-0xd842801ff]
[ 0.271209] pci 0002:00:04.0: BAR 4: assigned [io 0x1000-0x100f]
[ 0.271230] pci 0002:00:04.0: BAR 0: assigned [io 0x1010-0x1017]
[ 0.271250] pci 0002:00:04.0: BAR 2: assigned [io 0x1018-0x101f]
[ 0.271271] pci 0002:00:04.0: BAR 1: assigned [io 0x1020-0x1023]
[ 0.271292] pci 0002:00:04.0: BAR 3: assigned [io 0x1024-0x1027]
[ 0.305413] raid6: int32x1 300 MB/s
[ 0.321846] raid6: int32x2 421 MB/s
[ 0.339089] raid6: int32x4 468 MB/s
[ 0.356234] raid6: int32x8 234 MB/s
[ 0.356263] raid6: using algorithm int32x4 (468 MB/s)
[ 0.356277] raid6: using intx1 recovery algorithm
[ 0.356641] vgaarb: device added: PCI:0001:81:00.0,decodes=io+mem,owns=none,locks=none
[ 0.356673] vgaarb: loaded
[ 0.356685] vgaarb: bridge control possible 0001:81:00.0
[ 0.357042] SCSI subsystem initialized
[ 0.357713] usbcore: registered new interface driver usbfs
[ 0.357800] usbcore: registered new interface driver hub
[ 0.357874] usbcore: registered new device driver usb
[ 0.358410] Advanced Linux Sound Architecture Driver Initialized.
[ 0.359235] Switched to clocksource timebase
[ 0.369318] NET: Registered protocol family 2
[ 0.370074] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.370168] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.370313] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.370426] TCP: reno registered
[ 0.370447] UDP hash table entries: 512 (order: 1, 8192 bytes)
[ 0.370497] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[ 0.370679] NET: Registered protocol family 1
[ 0.371175] RPC: Registered named UNIX socket transport module.
[ 0.371204] RPC: Registered udp transport module.
[ 0.371217] RPC: Registered tcp transport module.
[ 0.371283] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.371957] Could not remap bcsr
[ 0.376097] genirq: Setting trigger mode 3 for irq 45 failed (uic_set_irq_type+0x0/0x184)
[ 0.383928] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.396968] ntfs: driver 2.1.31 [Flags: R/W].
[ 0.397605] fuse init (API version 7.23)
[ 0.398208] msgmni has been set to 1486
[ 0.400777] bounce: pool size: 64 pages
[ 0.400877] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.400904] io scheduler noop registered
[ 0.400942] io scheduler cfq registered (default)
[ 0.401688] aer: probe of 0000:40:00.0:pcie02 failed with error -22
[ 0.401743] aer: probe of 0001:80:00.0:pcie02 failed with error -22
[ 0.401817] pcie_pme: probe of 0000:40:00.0:pcie01 failed with error -22
[ 0.401853] pcie_pme: probe of 0001:80:00.0:pcie01 failed with error -22
[ 0.402827] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.403792] console [ttyS0] disabled
[ 0.425098] serial8250 serial8250.0: ttyS0 at MMIO 0x4ef600300 (irq = 23, base_baud = 691200) is a U6_16550A
[ 1.433833] console [ttyS0] enabled
[ 1.458046] serial8250 serial8250.0: ttyS1 at MMIO 0x4ef600400 (irq = 24, base_baud = 691200) is a U6_16550A
[ 1.468733] console [ttyS0] disabled
[ 1.472613] of_serial 4ef600300.serial: ttyS0 at MMIO 0x4ef600300 (irq = 23, base_baud = 691200) is a 16550
[ 2.492167] console [ttyS0] enabled
[ 2.496179] of_serial 4ef600400.serial: ttyS1 at MMIO 0x4ef600400 (irq = 24, base_baud = 691200) is a 16550
[ 2.506725] Generic non-volatile memory driver v1.1
[ 2.517874] brd: module loaded
[ 2.524216] loop: module loaded
[ 2.528599] sata_sil 0002:00:04.0: Applying R_ERR on DMA activate FIS errata fix
[ 2.537658] scsi host0: sata_sil
[ 2.541665] scsi host1: sata_sil
[ 2.545170] ata1: SATA max UDMA/100 mmio m512@0xd84280000 tf 0xd84280080 irq 22
[ 2.552960] ata2: SATA max UDMA/100 mmio m512@0xd84280000 tf 0xd842800c0 irq 22
[ 2.562317] PPC 4xx OCP EMAC driver, version 3.54
[ 2.567969] MAL v2 /plb/mcmal, 2 TX channels, 16 RX channels
[ 2.574206] ZMII /plb/opb/emac-zmii@ef600d00 initialized
[ 2.580012] RGMII /plb/opb/emac-rgmii@ef601500 initialized with MDIO support
[ 2.587663] TAH /plb/opb/emac-tah@ef601350 initialized
[ 2.593201] TAH /plb/opb/emac-tah@ef601450 initialized
[ 2.598951] /plb/opb/emac-rgmii@ef601500: input 0 in RGMII mode
[ 2.606673] eth0: EMAC-0 /plb/opb/ethernet@ef600e00, MAC 00:50:c2:80:d4:8e
[ 2.613908] eth0: found Generic MII PHY (0x00)
[ 2.618863] /plb/opb/emac-rgmii@ef601500: input 1 in RGMII mode
[ 2.626520] eth1: EMAC-1 /plb/opb/ethernet@ef600f00, MAC 00:00:00:00:00:00
[ 2.633823] eth1: found Generic MII PHY (0x01)
[ 2.638862] PPP generic driver version 2.4.2
[ 2.643692] PPP BSD Compression module registered
[ 2.648698] PPP Deflate Compression module registered
[ 2.654078] NET: Registered protocol family 24
[ 2.659337] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.666414] ppc-of-ehci 4bffd0400.ehci: OF EHCI
[ 2.671476] ppc-of-ehci 4bffd0400.ehci: new USB bus registered, assigned bus number 1
[ 2.679861] ppc-of-ehci 4bffd0400.ehci: irq 32, io mem 0x4bffd0400
[ 2.692254] ppc-of-ehci 4bffd0400.ehci: USB 2.0 started, EHCI 1.00
[ 2.698663] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.705507] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.712781] usb usb1: Product: OF EHCI
[ 2.716553] usb usb1: Manufacturer: Linux 3.18.0-rc1-Sam460ex ehci_hcd
[ 2.723098] usb usb1: SerialNumber: PPC-OF USB
[ 2.728059] hub 1-0:1.0: USB hub found
[ 2.732046] hub 1-0:1.0: 1 port detected
[ 2.736471] ehci-pci: EHCI PCI platform driver
[ 2.741161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.747592] ppc-of-ohci 4bffd0000.usb: OF OHCI
[ 2.752343] ppc-of-ohci 4bffd0000.usb: new USB bus registered, assigned bus number 2
[ 2.760269] ppc-of-ohci 4bffd0000.usb: irq 33, io mem 0x4bffd0000
[ 2.876263] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 2.905379] ata1.00: ATA-8: Corsair CSSD-F40GB2, 2.0, max UDMA/133
[ 2.915237] ata1.00: 78161328 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.954377] ata1.00: configured for UDMA/100
[ 2.969518] scsi 0:0:0:0: Direct-Access ATA Corsair CSSD-F40 2.0 PQ: 0 ANSI: 5
[ 2.986882] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.992433] sd 0:0:0:0: [sda] 78161328 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 3.004899] sd 0:0:0:0: [sda] Write Protect is off
[ 3.015359] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.037319] usb 1-1: new high-speed USB device number 2 using ppc-of-ehci
[ 3.044476] sda: RDSK (512) sda1 (SFS^B)(res 2 spb 2) sda2 (SFS^@)(res 2 spb 2) sda3 (SFS^@)(res 2 spb 2) sda4 (DOS^G)(res 2 spb 2)
[ 3.071495] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.176690] usb 1-1: New USB device found, idVendor=0424, idProduct=2517
[ 3.187239] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.204370] hub 1-1:1.0: USB hub found
[ 3.211259] hub 1-1:1.0: 7 ports detected
[ 3.312263] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 3.325580] ata2.00: ATA-8: TEAM A1 SSD 30GB, S5FAM030, max UDMA/100
[ 3.336237] ata2.00: 62533296 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 3.355552] ata2.00: configured for UDMA/100
[ 3.374513] scsi 1:0:0:0: Direct-Access ATA TEAM A1 SSD 30GB M030 PQ: 0 ANSI: 5
[ 3.391489] sd 1:0:0:0: [sdb] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[ 3.399381] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 3.408538] sd 1:0:0:0: [sdb] Write Protect is off
[ 3.419375] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.439340] sdb: RDSK (512) sdb1 (LNX^@)(res 2 spb 1) sdb2 (EXT^C)(res 2 spb 1) sdb3 (SWP^@)(res 2 spb 1)
[ 3.460372] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 3.501193] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.508021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.515300] usb usb2: Product: OF OHCI
[ 3.519114] usb 1-1.1: new low-speed USB device number 3 using ppc-of-ehci
[ 3.526024] usb usb2: Manufacturer: Linux 3.18.0-rc1-Sam460ex ohci_hcd
[ 3.532609] usb usb2: SerialNumber: PPC-OF USB
[ 3.537702] hub 2-0:1.0: USB hub found
[ 3.541705] hub 2-0:1.0: 1 port detected
[ 3.546138] ohci-pci: OHCI PCI platform driver
[ 3.551085] usbcore: registered new interface driver usb-storage
[ 3.557578] usbcore: registered new interface driver usbserial
[ 3.563816] usbcore: registered new interface driver usbserial_generic
[ 3.570575] usbserial: USB Serial support registered for generic
[ 3.577191] mousedev: PS/2 mouse device common for all mice
[ 3.583081] i2c /dev entries driver
[ 3.588904] rtc-m41t80 0-0068: rtc core: registered m41t80 as rtc0
[ 3.596488] ibm-iic 4ef600700.i2c: using standard (100 kHz) mode
[ 3.603021] ibm-iic 4ef600800.i2c: using standard (100 kHz) mode
[ 3.609922] device-mapper: ioctl: 4.28.0-ioctl (2014-09-17) initialised: dm-devel@redhat.com
[ 3.618991] sdhci: Secure Digital Host Controller Interface driver
[ 3.625345] sdhci: Copyright(c) Pierre Ossman
[ 3.629922] usbcore: registered new interface driver ushc
[ 3.635594] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.642075] usbcore: registered new interface driver usbhid
[ 3.648027] usbhid: USB HID core driver
[ 3.652834] no UART detected at 0x1
[ 3.657064] ipip: IPv4 over IPv4 tunneling driver
[ 3.661879] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c31d
[ 3.669613] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.677174] TCP: cubic registered
[ 3.680831] Initializing XFRM netlink socket
[ 3.685406] usb 1-1.1: Product: USB Keyboard
[ 3.690659] NET: Registered protocol family 10
[ 3.695378] usb 1-1.1: Manufacturer: Logitech
[ 3.700961] sit: IPv6 over IPv4 tunneling driver
[ 3.706920] NET: Registered protocol family 17
[ 3.711788] NET: Registered protocol family 15
[ 3.722264] Btrfs loaded
[ 3.724877] input: Logitech USB Keyboard as /devices/plb/4bffd0400.ehci/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C31D.0001/input/input0
[ 3.738328] hid-generic 0003:046D:C31D.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-PPC-OF USB-1.1/input0
[ 3.750610] rtc-m41t80 0-0068: setting system clock to 2014-10-21 13:33:49 UTC (1413898429)
[ 3.759449] ALSA device list:
[ 3.762629] No soundcards found.
[ 3.777865] input: Logitech USB Keyboard as /devices/plb/4bffd0400.ehci/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C31D.0002/input/input1
[ 3.790079] hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-PPC-OF USB-1.1/input1
[ 3.804593] EXT3-fs (sdb2): recovery required on readonly filesystem
[ 3.811047] EXT3-fs (sdb2): write access will be enabled during recovery
[ 3.879447] usb 1-1.3: new full-speed USB device number 4 using ppc-of-ehci
[ 3.888379] kjournald starting. Commit interval 5 seconds
[ 3.895214] EXT3-fs (sdb2): recovery complete
[ 3.899632] EXT3-fs (sdb2): mounted filesystem with ordered data mode
[ 3.906175] VFS: Mounted root (ext3 filesystem) readonly on device 8:18.
[ 3.913812] devtmpfs: mounted
[ 3.917408] Freeing unused kernel memory: 236K (c074b000 - c0786000)
[ 3.981311] usb 1-1.3: New USB device found, idVendor=09da, idProduct=054f
[ 3.988549] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.996156] usb 1-1.3: Product: USB Device
[ 4.001138] usb 1-1.3: Manufacturer: A4TECH
[ 4.015505] input: A4TECH USB Device as /devices/plb/4bffd0400.ehci/usb1/1-1/1-1.3/1-1.3:1.0/0003:09DA:054F.0003/input/input2
[ 4.028722] hid-generic 0003:09DA:054F.0003: input,hidraw2: USB HID v1.11 Keyboard [A4TECH USB Device] on usb-PPC-OF USB-1.3/input0
[ 4.050564] input: A4TECH USB Device as /devices/plb/4bffd0400.ehci/usb1/1-1/1-1.3/1-1.3:1.1/0003:09DA:054F.0004/input/input3
[ 4.065297] hid-generic 0003:09DA:054F.0004: input,hidraw3: USB HID v1.11 Mouse [A4TECH USB Device] on usb-PPC-OF USB-1.3/input1
[ 4.151440] usb 1-1.7: new high-speed USB device number 5 using ppc-of-ehci
[ 4.183875] random: init urandom read with 11 bits of entropy available
[ 4.251941] usb 1-1.7: New USB device found, idVendor=0424, idProduct=2240
[ 4.275550] usb 1-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.316306] usb 1-1.7: Product: Ultra Fast Media
[ 4.341319] usb 1-1.7: Manufacturer: Generic
[ 4.361141] usb 1-1.7: SerialNumber: 000000225001
[ 4.378144] usb-storage 1-1.7:1.0: USB Mass Storage device detected
[ 4.386899] init: plymouth-upstart-bridge main process (784) terminated with status 1
[ 4.400957] init: plymouth-upstart-bridge main process ended, respawning
[ 4.408035] scsi host2: usb-storage 1-1.7:1.0
[ 4.416423] init: ureadahead main process (787) terminated with status 5
[ 4.484059] init: plymouth-upstart-bridge main process (803) terminated with status 1
[ 4.493816] init: plymouth-upstart-bridge main process ended, respawning
[ 5.415622] scsi 2:0:0:0: Direct-Access Generic Ultra HS-COMBO 1.68 PQ: 0 ANSI: 0
[ 5.450803] sd 2:0:0:0: [sdc] 3911680 512-byte logical blocks: (2.00 GB/1.86 GiB)
[ 5.460274] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 5.489180] sd 2:0:0:0: [sdc] Write Protect is off
[ 5.511933] sd 2:0:0:0: [sdc] No Caching mode page found
[ 5.550938] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 5.595368] sdc: RDSK (512) sdc1 (SFS^@)(res 2 spb 2)
[ 5.613688] sd 2:0:0:0: [sdc] Attached SCSI removable disk
[ 7.996583] sm501 0002:00:06.0: incorrect device id c0000105
[ 11.693942] radeon 0001:81:00.0: ppc4xx_setup_msi_irqs: fail mapping irq
[ 11.725642] Unable to handle kernel paging request for data at address 0x0f93207c
[ 11.733171] Faulting instruction address: 0xc032a7cc
[ 13.739621] Oops: Kernel access of bad area, sig: 11 [#1]
[ 13.745033] PREEMPT Canyonlands
[ 13.748194] Modules linked in: radeon(+) cfbfillrect cfbimgblt cfbcopyarea i2c_algo_bit snd_ice1724 drm_kms_helper snd_ak4113 ttm snd_pt2258 snd_ak4114 snd_i2c snd_ice17xx_ak4xxx sm501 snd_ak4xxx_adda drm snd_ac97_codec ac97_bus agpgart
[ 13.769484] CPU: 0 PID: 1073 Comm: systemd-udevd Not tainted 3.18.0-rc1-Sam460ex #1
[ 13.777155] task: efa445e0 ti: efbfa000 task.ti: efbfa000
[ 13.782561] NIP: c032a7cc LR: c00150e4 CTR: c0043830
[ 13.787536] REGS: efbfbac0 TRAP: 0300 Not tainted (3.18.0-rc1-Sam460ex)
[ 13.794417] MSR: 00021000 <CE,ME> CR: 44248424 XER: 20000000
[ 13.800321] DEAR: 0f93207c ESR: 00000000
GPR00: c00150d4 efbfbb70 efa445e0 0f93207c fffffff5 00000001 00000001 fffffff5
GPR08: 00000015 001fffff ffefffff efbfbb70 24042482 1005504c 00020000 c07209e0
GPR16: 1004d01c c078dc90 c05e6c5c c078dc74 f9a74e84 00000000 00000124 c006b6c4
GPR24: ef842d38 00000000 c07c101c ef842800 fffffff4 ef842d38 c07c101c 00029000
[ 13.833103] NIP [c032a7cc] bitmap_clear+0x6c/0x7c
[ 13.837816] LR [c00150e4] msi_bitmap_free_hwirqs+0x3c/0x80
[ 13.843306] Call Trace:
[ 13.845759] [efbfbb70] [c00150d4] msi_bitmap_free_hwirqs+0x2c/0x80 (unreliable)
[ 13.853112] [efbfbb90] [c001b03c] ppc4xx_setup_msi_irqs+0xac/0xf4
[ 13.859231] [efbfbbd0] [c035934c] pci_enable_msi_range+0x1b8/0x254
[ 13.865575] [efbfbc10] [f9958a2c] radeon_irq_kms_init+0x150/0x17c [radeon]
[ 13.872617] [efbfbc20] [f99a8868] evergreen_startup+0x1da8/0x228c [radeon]
[ 13.879657] [efbfbc50] [f99a9050] evergreen_init+0x260/0x328 [radeon]
[ 13.886245] [efbfbc60] [f9927d78] radeon_device_init+0x8c4/0xa70 [radeon]
[ 13.893181] [efbfbc80] [f9929f20] radeon_driver_load_kms+0xa4/0x174 [radeon]
[ 13.900274] [efbfbca0] [f93480bc] drm_dev_register+0x9c/0x120 [drm]
[ 13.906578] [efbfbcc0] [f934a8b8] drm_get_pci_dev+0xf4/0x190 [drm]
[ 13.912783] [efbfbce0] [c0349edc] pci_device_probe+0x78/0xd0
[ 13.918468] [efbfbd00] [c039d08c] driver_probe_device+0xdc/0x208
[ 13.924499] [efbfbd30] [c039d294] __driver_attach+0x78/0xa0
[ 13.930098] [efbfbd50] [c039b5d4] bus_for_each_dev+0x8c/0x9c
[ 13.935784] [efbfbd80] [c039c7bc] bus_add_driver+0xf8/0x1d4
[ 13.941383] [efbfbda0] [c039d784] driver_register+0xb4/0xf8
[ 13.946982] [efbfbdc0] [c00016f0] do_one_initcall+0x114/0x198
[ 13.952757] [efbfbe30] [c006dda0] load_module+0x1500/0x1b2c
[ 13.958354] [efbfbee0] [c006e528] SyS_finit_module+0x64/0x74
[ 13.964039] [efbfbf40] [c000ad24] ret_from_syscall+0x0/0x3c
[ 13.969639] --- interrupt: c01 at 0xfe1a5b0
[ 13.969639] LR = 0xfefc08c
[ 13.976874] Instruction dump:
[ 13.979861] 3940ffff 4bffffdc 2f890000 4d9e0020 7c842a14 3920ffff 7088001f 41820010
[ 13.987741] 39200001 7d294030 3929ffff 7d2a53b8 <81230000> 7d295038 91230000 4e800020
[ 13.995802] ---[ end trace e6cc42bfd36abc14 ]---
[ 14.000425]
[ 14.001922] note: systemd-udevd[1073] exited with preempt_count 1
[ 14.009146] BUG: scheduling while atomic: systemd-udevd/1073/0x00000002
[ 14.015817] Modules linked in: radeon(+) cfbfillrect cfbimgblt cfbcopyarea i2c_algo_bit snd_ice1724 drm_kms_helper snd_ak4113 ttm snd_pt2258 snd_ak4114 snd_i2c snd_ice17xx_ak4xxx sm501 snd_ak4xxx_adda drm snd_ac97_codec ac97_bus agpgart
[ 14.037134] Preemption disabled at:[< (null)>] (null)
[ 14.042477]
[ 14.043986] CPU: 0 PID: 1073 Comm: systemd-udevd Tainted: G D 3.18.0-rc1-Sam460ex #1
[ 14.052792] Call Trace:
[ 14.055263] [efbfb7b0] [c00056c8] show_stack+0x54/0x138 (unreliable)
[ 14.061672] [efbfb7f0] [c05cd7c4] __schedule_bug+0x88/0xa0
[ 14.067182] [efbfb800] [c05c9ad0] __schedule+0x90/0x49c
[ 14.072442] [efbfb900] [c05cc56c] schedule_timeout+0x24/0x188
[ 14.078216] [efbfb940] [c05caa30] wait_for_common+0x178/0x1b4
[ 14.083994] [efbfb980] [c0052854] wait_rcu_gp+0x50/0x58
[ 14.089256] [efbfb9b0] [c0507df8] netlink_release+0x224/0x288
[ 14.095033] [efbfb9e0] [c04d548c] sock_release+0x30/0xc4
[ 14.100371] [efbfb9f0] [c04d5534] sock_close+0x14/0x28
[ 14.105534] [efbfba00] [c00c8dbc] __fput+0xf4/0x1f4
[ 14.110451] [efbfba20] [c0039340] task_work_run+0x8c/0xa8
[ 14.115894] [efbfba40] [c0023860] do_exit+0x300/0x7e8
[ 14.120977] [efbfba90] [c0007d28] die+0x1f8/0x200
[ 14.125708] [efbfbab0] [c000b258] handle_page_fault+0x7c/0x80
[ 14.131488] --- interrupt: 300 at bitmap_clear+0x6c/0x7c
[ 14.131488] LR = msi_bitmap_free_hwirqs+0x3c/0x80
[ 14.141868] [efbfbb70] [c00150d4] msi_bitmap_free_hwirqs+0x2c/0x80 (unreliable)
[ 14.149236] [efbfbb90] [c001b03c] ppc4xx_setup_msi_irqs+0xac/0xf4
[ 14.155367] [efbfbbd0] [c035934c] pci_enable_msi_range+0x1b8/0x254
[ 14.161865] [efbfbc10] [f9958a2c] radeon_irq_kms_init+0x150/0x17c [radeon]
[ 14.168929] [efbfbc20] [f99a8868] evergreen_startup+0x1da8/0x228c [radeon]
[ 14.175978] [efbfbc50] [f99a9050] evergreen_init+0x260/0x328 [radeon]
[ 14.182574] [efbfbc60] [f9927d78] radeon_device_init+0x8c4/0xa70 [radeon]
[ 14.189522] [efbfbc80] [f9929f20] radeon_driver_load_kms+0xa4/0x174 [radeon]
[ 14.196647] [efbfbca0] [f93480bc] drm_dev_register+0x9c/0x120 [drm]
[ 14.202967] [efbfbcc0] [f934a8b8] drm_get_pci_dev+0xf4/0x190 [drm]
[ 14.209186] [efbfbce0] [c0349edc] pci_device_probe+0x78/0xd0
[ 14.214887] [efbfbd00] [c039d08c] driver_probe_device+0xdc/0x208
[ 14.220933] [efbfbd30] [c039d294] __driver_attach+0x78/0xa0
[ 14.226531] [efbfbd50] [c039b5d4] bus_for_each_dev+0x8c/0x9c
[ 14.232217] [efbfbd80] [c039c7bc] bus_add_driver+0xf8/0x1d4
[ 14.237816] [efbfbda0] [c039d784] driver_register+0xb4/0xf8
[ 14.243419] [efbfbdc0] [c00016f0] do_one_initcall+0x114/0x198
[ 14.249202] [efbfbe30] [c006dda0] load_module+0x1500/0x1b2c
[ 14.254812] [efbfbee0] [c006e528] SyS_finit_module+0x64/0x74
[ 14.260498] [efbfbf40] [c000ad24] ret_from_syscall+0x0/0x3c
[ 14.266099] --- interrupt: c01 at 0xfe1a5b0
[ 14.266099] LR = 0xfefc08c
[ 16.841504] Bluetooth: Core ver 2.19
[ 16.877732] NET: Registered protocol family 31
[ 16.910217] Bluetooth: HCI device and connection manager initialized
[ 16.941497] Bluetooth: HCI socket layer initialized
[ 16.969474] Bluetooth: L2CAP socket layer initialized
[ 16.997919] Bluetooth: SCO socket layer initialized
[ 17.078934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.100113] Bluetooth: BNEP filters: protocol multicast
[ 17.123747] Bluetooth: BNEP socket layer initialized
[ 17.434534] Bluetooth: RFCOMM TTY layer initialized
[ 17.453744] Bluetooth: RFCOMM socket layer initialized
[ 17.478153] Bluetooth: RFCOMM ver 1.11
* Setting sensors limits [80G
[74G[ OK ]
* Setting up X socket directories... [80G
[74G[ OK ]
