Here it is, the final kernel 6.2. After solving the CRC error, the DPAA issue, the reboot issue, and the linking issue, we have a stable final kernel 6.2. Many thanks to Skateman, Casey, and Musa for testing the alphas and release candidates. :-)
Download: linux-image-6.2-X1000_X5000.tar.gz
Hi
II had a lot of trouble before my USB disk was accepted by my x1000.
Only the third disk was successful.
so here is Debian bookwork 32 with vmlinux-6.2
Have a nice day
musa wrote: Mon Feb 20, 2023 8:40 pm Hi
Have a nice day
Great, that you was able to solve the issue with the USB disk. Thank you for testing!
I released the second alpha of kernel 6.3 for the X1000 and X5000 today.
Download: linux-image-6.3-alpha2-X1000_X5000.tar.gz
X5000 users: Please Note: If you use an uInitrd for example for booting with a LABEL, then load the dtb file to the address 1d00000. The kernel has grown in recent months so the address 1c00000 is used by the uImage. Before we have loaded the dtb to the address 1c00000.
X5000> bootm 1000000 2000000 1d00000
Hi
This is 6.3_alpha1 with Debian 64 booksworm
The picture shows shared drives from my main computer and from a rasberrypi400 with an amiga 1200 emulation.
I used this pretty quick samba install and it works straight away.
Install samba with share
sudo apt install samba -y
sudo caja /etc/samba/smb.conf
paste the following under the printer section
[new_share] (name can be changed)
comment = myshare
path = /home/musa/share (path to your share)
browseable = yes
read only = no
guest ok =no
valid user = musa (name of your user)
restart samba
sudo systemctl restart smbd
sudo -s (root)
smbpasswd -a musa (your username)
(follow the questions)
exit (leave root)
sudo apt install cifs-utils samba-client -y
Open a file manager and look in networks.
Have a nice day
musa wrote: Fri Feb 24, 2023 3:32 pm Hi
Great! :-) You can find more Samba examples in the thread Linux PowerPC Server Software
Thanks a lot for testing the alpha1.
Have a nice day too.
Here is the third alpha of kernel 6.3 with the first PowerPC updates for testing.
Download: linux-image-6.3-alpha3-X1000_X5000.tar.gz
I cross compiled the alpha4 of kernel 6.3 for the X1000 and X5000 on a PC with an Intel Xeon W-3223 (8 cores@3.491GHz) today.
Download: linux-image-6.3-alpha4-X1000_X5000.tar.gz
X1000 Linux kernel compiling time:
time make -j8 CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc vmlinux
3m 67s
real    220.18s
user    1381.94s
sys     189.44s
cpu     713%
For comparison: Intel Xeon D-1527 (4 cores@2.199GHz):
real    6m32.027s
user    46m31.326s
sys     2m20.941s
time make -j8 CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc modules
1m 47s
real    88.29s
user    572.72s
sys     83.55s
cpu     743%
real    2m44.396s
user    19m48.324s
sys     1m11.883s
X5000 Linux kernel compiling time:
time make -j8 CROSS_COMPILE=powerpc-linux-gnu- ARCH=powerpc uImage
3m 77s
real    226.07s
user    1324.24s
sys     195.64s
cpu     672%
real    6m17.786s
user    43m36.072s
sys     2m27.547s
2m 04s
real    122.21s
user    768.82s
sys     116.31s
cpu     724%
real    3m35.010s
user    26m3.404s
sys     1m38.056s
