Arctic Fox
xeno74 wrote: Sun Jun 19, 2022 8:19 am Mario Locati has released a deb package of Arctic Fox 39.2 for Debian PPC64. :-)
Download: arcticfox-39.2-ppc64.deb
It works on the X1000. It has AltiVec support. My package doesn't have AltiVec support.
Compiling Arctic Fox 39.2 on Fedora 28 PPC64:
  1. Code: Select all
    sudo yum install gtk2-devel dbus-glib-devel autoconf213 yasm mesa-libGL-devel alsa-lib-devel libXt-devel zlib-devel openssl-devel sqlite-devel bzip2-devel pulseaudio-libs-devel nspr-devel gcc-c++ libatomic
  2. Code: Select all
    $ cp .mozconfig Arctic-Fox-39.2/
    .mozconfig for PPC64:
    # This Source Code Form is subject to the terms of the Mozilla Public
    # License, v. 2.0. If a copy of the MPL was not distributed with this
    # file, You can obtain one at http://mozilla.org/MPL/2.0/.
    export CC="gcc -flax-vector-conversions -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
    export CXX="g++ -flax-vector-conversions -fpermissive -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
    export LDFLAGS="-latomic"
    mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/obj-ff-dbg
    ac_add_options --enable-mozril-geoloc
    ac_add_options --disable-parental-controls
    ac_add_options --enable-release
    ac_add_options --disable-eme
    ac_add_options --enable-dbus
    ac_add_options --disable-gio
    ac_add_options --enable-strip
    ac_add_options --enable-install-strip
    ac_add_options --enable-application=browser
    ac_add_options --with-branding=browser/branding/arcticfox
    ac_add_options --enable-optimize="-O2 -fno-schedule-insns2 -fno-lifetime-dse -fno-delete-null-pointer-checks"
  3. Code: Select all
    cd Arctic-Fox-39.2
  4. Code: Select all
    ./mach build
  5. Code: Select all
    ./mach run
  6. Code: Select all
    ./mach package
    (Creates the self contained archive which you'll find in Arctic-Fox-39.2/obj-ff-dbg/dist)
Mario Locati has created a deb file of the non-altivec 64-bit version of Arctic Fox 39.2.
arcticfox-39.2.linux-powerpc64-noaltivec.deb
FYI: The version 40.0 has been released. The project has been moved from wicknix to rmottola, so this is now the main repository.
Link: https://github.com/rmottola/Arctic-Fox/releases/tag/v40.0
I compiled Arctic Fox 40.0 with the following mozconfig for Linux PowerPC today.
.mozconfig for 32-bit userlands with 64-bit kernels:
export CC="gcc -m32 -flax-vector-conversions -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export CXX="g++ -m32 -flax-vector-conversions -fpermissive -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
ac_add_options --disable-gstreamer
ac_add_options --target=powerpc-linux-gnu
ac_add_options --host=powerpc-linux-gnu
Download: arcticfox-40.0.linux-powerpc.tar.bz2
It works on Void PPC, MintPPC (Debian Sid), Fienix and also on an old Ubuntu 10.04.
Primax
Post by Primax »
Thanks!
Seems to work fine so far, except: the commit description of GitHub pages are blank.
Can anybody check it?
xeno74 wrote: Tue Oct 11, 2022 9:04 pm I compiled Arctic Fox 40.0 with the following mozconfig for Linux PowerPC today.
Unbelievable... The Bookmarks Toolbar works finally as it should!!! I have been waiting for this for years...
Thank you VERY, VERY MUCH! :-)
Thanks for Arctic Fox 40 !!
Big picture https://www.skateman.nl/wp-content/uplo ... -12-08.png
Wicknix wrote: Hey -
I was able to fix PM 31.2 for ppc64. However i no longer have my old ubuntu 12 dev environment to attempt 32bit builds for debian/ubuntu compatible systems.
If you'd like to give it a shot the source is here:
pale-moon-31-ppc-fix.tar.bz2
Wicknix wrote: PM build instructions here: https://developer.palemoon.org/build/linux/
Don't worry about the git section. I already have the submodules and everything in place.
However after it builds, you'll need to swap the LE/BE icu.dat files around again after packaging. I included one in the archive.
