HDAudio driver for X1000 onboard sound
Christopher Follett
AmigaKit
AmigaKit
Re: HDAudio driver for X1000 onboard sound
Post by Christopher Follett »
ggw wrote:
LyleHaze wrote:
ggw wrote:Where do I find the driver for download?
The driver is distributed by AmiUpdate.
I activated AmiUpdate and got around 20 updates. None of them seemed to have anything to do with audio.
Where do I find the existing "driver" so I can look at its install date and the version #?
I'll look into why AmiUpdate isn't running automatically. I thought I had set it up that way... recently?
ggw
If your logging in to the Amiupdate server with your user and pass. Then it means its already installed.
I cant remember of the top of my head the exact name of the Audio driver update, but it will be there.
When did you get your X1000?
Resolute and Industrious
__________________
New Products
ggw
Post by ggw »
My X1000 arrived May, 2012 and is registered both here and at a-eon.
Christopher Follett wrote:
ggw wrote: I activated AmiUpdate and got around 20 updates. None of them seemed to have anything to do with audio.
ggw
George Wyche
LyleHaze
Post by LyleHaze »
You can manually read the driver version with
version files devs:audio/hdaudio.audio
I can not tell you the current version because.. I really don't know.
AmiUpdate has NEVER updated my hdaudio driver. I suspect it's because my machine is the source and not the destination. :lol:
I'm not sure which version was the last one to go public.
Can we get a NON-BETA to tell us the current release version please??
gerograph
Post by gerograph »
My/current Version is 6.18...
ggw
Post by ggw »
Christopher Follett wrote: If your logging in to the Amiupdate server with your user and pass. Then it means its already installed.
May, 2012 and I did AmiUpdate 2 days ago.
New Shell process 10
10.Work1:2013> version devs:audio/hdaudio.audio
VERSION: object not found
10.Work1:2013>
George Wyche
sundown
Post by sundown »
10.Work1:2013>
Wrong path, try version devs:ahi/hdaudio.audio
Ken
ggw
Post by ggw »
8.Work3:wycheweb> version devs:ahi/hdaudio.audio
8.Work3:wycheweb>
George Wyche
LyleHaze
Post by LyleHaze »
Sorry about the bad path, and thanks Ken for setting it straight.
One other possibility might be a question of which AmiUpdate server(s) you are configured for. I am away from home and Amigas right now..
I believe there is an update server for applications and another for OS components.. I think.
But if you are logging in to the correct server, and your machine is identified as an X1000, the rest should be pretty automatic.
LyleHaze wrote:One other possibility might be a question of which AmiUpdate server(s) you are configured for. I am away from home and Amigas right now..
Basically, ggw, you want your server list in Prefs/Updates to look like the attached grab.
Oh, and I can confirm that the latest version of hdaudio offered publically through AmiUpdate is 6.18.
ggw
Post by ggw »
That was it.
Thanks Niels.
38 updates.
My my.
What ELSE am I missing in general?
George Wyche
