I have released the RC2-2 of kernel 7.3.0 with improved NFTables support.
I released the RC3 of kernel 7.3 for X1000 and e5500 machines (X5000/20, X5000/40, Mirari, and QEMU VMs) today.
The RC3 of kernel 7.3 with the new B650 SouthBridge (setenv bootargs root=/dev/nvme0n1p1 pcie_ports=compat):
Hypex
Post by Hypex »
So I don't know if there was a known issue, but I had a problem with the RC5 of 7.2.0 kernel. My NetworkManager crashed and I had no network. However the following ones were fine including the final kernel.
Now onto the 7.3.0 series which is off to a promising start. The alpha1 booted fast. I'll see how the RCs go.
Hypex wrote: Wed Sep 16, 2026 5:11 pm Now onto the 7.3.0 series which is off to a promising start. The alpha1 booted fast. I'll see how the RCs go.
I have released the stable long-term kernel 5.10.270 with improved NFTables support for X1000 and e5500 machines (X5000/20, X5000/40, Mirari, and QEMU VMs).
The kernel 5.10.270 with Yellow Dog Linux 6.2 PPC 32-bit:
Have a nice weekend,
Hypex
Post by Hypex »
I'm wondering if MATE is too old to test with. I found broken network with 7.3 a2 to a3 as well. While a5 was fine. However I did get some DRM crash with a5. The system seems to work fine but Firefox is unable to download and gives an unknown error. DRM crash below in case it matters.
[    6.656196] ------------[ cut here ]------------
[    6.659522] [PLANE:45:plane-0] pixel format with alpha exposed but blend mode not setup
[    6.659557] WARNING: at drm_mode_config_validate+0x63c/0x704, CPU#0: swapper/0/1
[    6.672368] Modules linked in:
[    6.674120] CPU: 0 UID: 0 PID: 1 Comm: swapper/0 Not tainted 7.3.0-a4-powerpc64-smp #1 NONE
[    6.681267] Hardware name: pasemi,nemo PA6T 0x900102 A-EON Amigaone X1000
[    6.686756] NIP:  c000000000d5eb48 LR: c000000000d5eb44 CTR: 0000000000000000
[    6.692595] REGS: c00000000333b400 TRAP: 0700   Not tainted  (7.3.0-a4-powerpc64-smp)
[    6.699129] MSR:  9000000000029032 <SF,HV,EE,ME,IR,DR,RI>  CR: 28008242  XER: 00000000
[    6.705775] IRQMASK: 0
               GPR00: c000000000d5eb44 c00000000333b6a0 c00000000220eb00 000000000000004b
               GPR04: 3fffffffffffdfff c00000000333b410 c00000000333b408 0000000000000000
               GPR08: c0000000028f7790 0000000000000000 0000000000000000 0000000000000001
               GPR12: 0000000024008242 c000000002ccd000 c00000000000eba4 0000000000000000
               GPR16: 0000000000000000 0000000000000000 0000000000000001 c000000002037318
               GPR20: c0000000020372c0 c000000002037288 c000000002037230 c000000002037130
               GPR24: c0000000020371e8 c0000000020371a0 c000000002037350 c000000005dd0290
               GPR28: c000000005dd0008 0000000000000001 0000000000000002 c0000000035a0800
[    6.760625] NIP [c000000000d5eb48] drm_mode_config_validate+0x63c/0x704
[    6.765944] LR [c000000000d5eb44] drm_mode_config_validate+0x638/0x704
[    6.771175] Call Trace:
[    6.772314] [c00000000333b6a0] [c000000000d5eb44] drm_mode_config_validate+0x638/0x704 (unreliable)
[    6.780074] [c00000000333b780] [c000000000d42024] drm_dev_register+0x284/0x398
[    6.786007] [c00000000333b810] [c000000000dc864c] radeon_pci_probe+0x164/0x258
[    6.791938] [c00000000333b8a0] [c000000000c790c4] pci_device_probe+0xcc/0x1d8
[    6.797781] [c00000000333b920] [c000000000f24608] really_probe+0xf8/0x35c
[    6.803278] [c00000000333b9b0] [c000000000f24b10] driver_probe_device+0x60/0x10c
[    6.809383] [c00000000333ba00] [c000000000f24dd8] __driver_attach+0xb4/0x19c
[    6.815139] [c00000000333ba40] [c000000000f21078] bus_for_each_dev+0xa8/0x128
[    6.820982] [c00000000333baa0] [c000000000f23b14] driver_attach+0x34/0x48
[    6.826478] [c00000000333bac0] [c000000000f22c88] bus_add_driver+0x260/0x2f4
[    6.832234] [c00000000333bb50] [c000000000f259e4] driver_register+0x8c/0x1b8
[    6.837991] [c00000000333bbc0] [c000000000c78378] __pci_register_driver+0x68/0x7c
[    6.844185] [c00000000333bbe0] [c00000000225db4c] radeon_module_init+0x6c/0xa8
[    6.850115] [c00000000333bc40] [c00000000000e780] do_one_initcall+0x60/0x360
[    6.855872] [c00000000333bd20] [c00000000220ff1c] kernel_init_freeable+0x24c/0x4f0
[    6.862152] [c00000000333bde0] [c00000000000ebe8] kernel_init+0x4c/0x194
[    6.867560] [c00000000333be50] [c00000000000bd94] ret_from_kernel_user_thread+0x14/0x1c
[    6.874276] ---- interrupt: 0 at 0x0
[    6.876549] Code: 4bff1ac9 60000000 391e0001 89430014 791e0020 2c0a0000 4182ffd0 e8bf0018 809f0050 7f43d378 4b33f35d 60000000 <0fe00000> ebff0008 7c3bf800 3bfffff8
[    6.890001] ---[ end trace 0000000000000000 ]---
[    6.893334] ------------[ cut here ]------------
[    6.896656] [PLANE:47:plane-1] pixel format with alpha exposed but blend mode not setup
[    6.896687] WARNING: at drm_mode_config_validate+0x63c/0x704, CPU#0: swapper/0/1
[    6.909494] Modules linked in:
[    6.911245] CPU: 0 UID: 0 PID: 1 Comm: swapper/0 Tainted: G        W           7.3.0-a4-powerpc64-smp #1 NONE
[    6.919959] Tainted: [W]=WARN
[    6.921619] Hardware name: pasemi,nemo PA6T 0x900102 A-EON Amigaone X1000
[    6.927107] NIP:  c000000000d5eb48 LR: c000000000d5eb44 CTR: 0000000000000000
[    6.932945] REGS: c00000000333b400 TRAP: 0700   Tainted: G        W            (7.3.0-a4-powerpc64-smp)
[    6.941045] MSR:  9000000000029032 <SF,HV,EE,ME,IR,DR,RI>  CR: 28008242  XER: 00000000
[    6.947690] IRQMASK: 0
               GPR28: c000000005dd0008 0000000000000002 0000000000000002 c000000003e17800
[    7.002538] NIP [c000000000d5eb48] drm_mode_config_validate+0x63c/0x704
[    7.007857] LR [c000000000d5eb44] drm_mode_config_validate+0x638/0x704
[    7.013088] Call Trace:
[    7.014227] [c00000000333b6a0] [c000000000d5eb44] drm_mode_config_validate+0x638/0x704 (unreliable)
[    7.021987] [c00000000333b780] [c000000000d42024] drm_dev_register+0x284/0x398
[    7.027920] [c00000000333b810] [c000000000dc864c] radeon_pci_probe+0x164/0x258
[    7.033850] [c00000000333b8a0] [c000000000c790c4] pci_device_probe+0xcc/0x1d8
[    7.039694] [c00000000333b920] [c000000000f24608] really_probe+0xf8/0x35c
[    7.045190] [c00000000333b9b0] [c000000000f24b10] driver_probe_device+0x60/0x10c
[    7.051295] [c00000000333ba00] [c000000000f24dd8] __driver_attach+0xb4/0x19c
[    7.057052] [c00000000333ba40] [c000000000f21078] bus_for_each_dev+0xa8/0x128
[    7.062894] [c00000000333baa0] [c000000000f23b14] driver_attach+0x34/0x48
[    7.068390] [c00000000333bac0] [c000000000f22c88] bus_add_driver+0x260/0x2f4
[    7.074147] [c00000000333bb50] [c000000000f259e4] driver_register+0x8c/0x1b8
[    7.079904] [c00000000333bbc0] [c000000000c78378] __pci_register_driver+0x68/0x7c
[    7.086098] [c00000000333bbe0] [c00000000225db4c] radeon_module_init+0x6c/0xa8
[    7.092028] [c00000000333bc40] [c00000000000e780] do_one_initcall+0x60/0x360
[    7.097783] [c00000000333bd20] [c00000000220ff1c] kernel_init_freeable+0x24c/0x4f0
[    7.104063] [c00000000333bde0] [c00000000000ebe8] kernel_init+0x4c/0x194
[    7.109471] [c00000000333be50] [c00000000000bd94] ret_from_kernel_user_thread+0x14/0x1c
[    7.116188] ---- interrupt: 0 at 0x0
[    7.118460] Code: 4bff1ac9 60000000 391e0001 89430014 791e0020 2c0a0000 4182ffd0 e8bf0018 809f0050 7f43d378 4b33f35d 60000000 <0fe00000> ebff0008 7c3bf800 3bfffff8
[    7.131912] ---[ end trace 0000000000000000 ]---
Hypex wrote: Sat Sep 19, 2026 6:28 pm However I did get some DRM crash with a5. The system seems to work fine but Firefox is unable to download and gives an unknown error. DRM crash below in case it matters.
Have you tested the kernels with other Linux distributions like Void PPC and MintPPC32?
Here is the RC4 of kernel 7.3 with a lot of fixes for X1000 and e5500 machines (X5000/20, X5000/40, Mirari, and QEMU VMs).
