Arctic Fox
caseycullen wrote: He's saying to scroll down to line 1439 and change it from "}, 2000);" to a higher value. Maybe try "}, 2500);". You can open and edit the script from "/home/.org.wicknix/<random-profile-name>/gm_scripts" for Arctic Fox or "/home/.wicknix/<random-profile-name>/gm_scripts" for SpiderWeb.
Yes, thanks! It can be seen I'm not a programmer...;) I had to increase it up to 6000 to get it work reliably. One type of videos already work from 'Yle', but there is another type which the author also tries to get to work (lives are of this type, too). I sincerely hope he succeeds!
BTW, I noticed ViewTube scripts can also be edited directly via the add-ons manager, from the scipt's preterences. This works with GreaseMonkey 3.31.4 but not with the 3.10.
caseycullen
Post by caseycullen »
Nice! I'm glad you were at least able to get partial success! Hopefully the other video type is worked out as well :)
caseycullen wrote: Nice! I'm glad you were at least able to get partial success! Hopefully the other video type is worked out as well :)
Sebaro is amazing...:-) He got already yesterday almost all videos working. There is still one type of videos, and the livestreams, which need a NPAPI plugin or an external player. Is there a NPAPI plugin for ArcticFox (or SpiderWeb)...?
And is VLC currently the only way in Fienix (or Unbuntu 16.04) for hardware acceleration (for videos)?
caseycullen
The VLC plugin is npapi. Do the live streams open in the VLC app? Otherwise if they open in smplayer you could try mozplugger.
caseycullen wrote: The VLC plugin is npapi. Do the live streams open in the VLC app? Otherwise if they open in smplayer you could try mozplugger.
I see... Yes, the livestreams open in the VLC player, if I have chosen it for MP4 in SpiderWeb prefs. In Arctic Fox the same did not work, do not why... I have to test also the smplayer, thanks for the tip!
Wicknix has released Arctic Fox 27.9.19. :-)
Change Log
Downloads:
Support thread: forums.macrumors.com
For Ubuntu 10.04: You need to install the GCC 4.8 and the libatomic1 via the repository 'ppa:ubuntu-toolchain-r/test'.
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update; sudo apt-get install gcc-4.8 g++-4.8
For Ubuntu 12.04: You need the libatomic1 package. Download: libatomic-ubuntu12.04-powerpc.tar.bz2
Please copy the file 'libatomic.so.1' to '/usr/lib/powerpc-linux-gnu/' with the following command:
sudo cp libatomic.so.1 /usr/lib/powerpc-linux-gnu/
Screenshot of the new Arctic Fox 27.9.19 on Ubuntu 10.04.4 LTS Lucid PowerPC (A-EON AmigaOne X5000/40):
Screenshot of the new Arctic Fox 27.9.19 on Ubuntu 10.04.4 LTS Lucid PowerPC (Apple PowerMac G4):
Screenshot of the new Arctic Fox 27.9.19 on the Ubuntu 10.04.0 Live DVD PowerPC (Apple PowerMac G3):
Happy Holidays AND Happy New Year! :-)
Here is Arctic Fox 27.9.19 for Linux PowerPC64!
Download: arcticfox-27.9.19.linux-powerpc64.tar.bz2
Enjoy the next days!
.mozconfig for PPC64:
# This Source Code Form is subject to the terms of the Mozilla Public
# License, v. 2.0. If a copy of the MPL was not distributed with this
# file, You can obtain one at http://mozilla.org/MPL/2.0/.
export CC="gcc-6.4 -flax-vector-conversions -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export CXX="g++-6.4 -flax-vector-conversions -fpermissive -O3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export LDFLAGS="-latomic"
mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/obj-ff-dbg
ac_add_options --enable-mozril-geoloc
ac_add_options --disable-parental-controls
ac_add_options --enable-release
ac_add_options --disable-eme
ac_add_options --enable-dbus
ac_add_options --disable-gio
ac_add_options --enable-strip
ac_add_options --enable-install-strip
ac_add_options --enable-application=browser
ac_add_options --with-branding=browser/branding/arcticfox
ac_add_options --enable-optimize="-O2 -fno-schedule-insns2 -fno-lifetime-dse -fno-delete-null-pointer-checks"
Wicknix has released Arctic Fox 27.10.1. :-)
Change Log
Downloads:
xeno74 wrote: Thu Mar 12, 2020 2:19 pm
How should you install that ".deb" package? Earlier Arctic Fox has been distributed in ".tar.bz2" packages, which can be unarched anywhere and do not confuse the system itself....
