Fienix - New PowerPC Distro
Hi Mechanic,
Thanks a lot for testing the kernels.
Which issues have you seen with the kernel 4.19 on Fienix?
HI Christian
My mate-terminal cant start . Can you help
mechanic
Post by mechanic »
Hi Christian,
On a fresh install the 4.19 works just fine. However, after doing a full upgrade when selecting the Mate Terminal it will pop the terminal window open and immediately it disappears. So pretty much it becomes unusable.
musa wrote:HI Christian
Hi Christian
I found a solution. It was kernel 4.19 that was the problem. Tried kernel 5.4 and got boot error. Tried 4.20 and booted fine and Mate terminal works.
Peter
musa wrote:Tried kernel 5.4 and got boot error.
Hi Peter,
Please post the boot error.
I compiled the latest longterm kernel 4.19.85 today. Unfortunately the issue with the MATE Terminal still exists. I can't solve it because I don't see any error messages after the crash. I tried it with gdb but without any success.
Hi Peter,
The MATE Terminal also crashes with the longterm kernel 4.14.
mechanic
Post by mechanic »
I tried 4.19 on my fresh install, and the Mate Terminal works. However, this install did not get a full upgrade, only selected programs have been installed or upgraded. So where the problem lays is anybody's guess. Chalk it up to one of Doctor Strangelove's predictions.
Hi Christian
I have installed and tested the debian64 img file caseycullen has shared in the x5000 forum. I inserted my xorg.cong file and started debian with no problems. Everything works stable.
Peter
musa wrote:Hi Christian
Peter
Hi Peter,
caseycullen wrote:I've created a new Fienix boot image that includes new updates. Please test it before I update the repo. You will need to set up a separate boot partition with kernel 5.5 and the dtb.
New Fienix Boot Image
Thanks!
-Casey
Hi Casey,
Happy New Year and many thanks for the new Fienix 2020-01 image! :-) I successfully tested it with the RC4 of kernel 5.5 on my X1000 and X5000/40 today. The good news is, that Xorg works without any problems! :-) I think my idea with only updating Mesa wasn't a good idea.
The hardware 3D acceleration works great with the new Mesa 19.3.1/LLVM 9.0.0 and with my Radeon HD6970 (Cayman XT). I tested it with SuperTuxKart, Quake-HD-Redux and with Yamagi Quake2.
I have found some small issues. The automatic network configuration doesn't work. I always had to manually configure my network cards with "dhclient" after the start of Fienix. I was able to solve this issue with installing the package "network-manager-gnome". Before I had to remove the package "rdnssd" because it isn't possible to install the package "network-manager-gnome" if the package "rdnssd" is installed.
The second issue isn't really a Fienix issue. The automatic configuration of my analog TV card Typhoon TView RDS + FM Stereo (BT878 chip) doesn't work. I had to set card=53 for the bttv kernel module.
# rmmod bttv
# modprobe bttv card=53
After that it works without any problems.
If you add the following line to /etc/modprobe.d/tv_bttv.conf then you don't need the commands above.
# nano /etc/modprobe.d/tv_bttv.conf
options bttv card=53
I wasn't able to install the package "blueman" for using my Bluetooth devices. Error message:
blueman:
Depends: gir1.2-nm-1.0 but it is not installable
Screenshot of Fienix 2020-01 on my AmigaOne X5000/40:
Screenshot of Fienix 2020-01 on my AmigaOne X1000:
Casey, Fienix is the best and most modern distribution we have currently! The games work faster with Fienix as with ubuntu MATE! Many thanks for your work! :-)
Just for info for this image:
username: fienix
password: fienixPW
root password: rootAdminPW
Please test this image.
