Void Linux
Re: Void Linux
Is there any point to the OctoXBPS icon on the Void desktop? I find some videos on how to set it up, but Youtube doesn't quite play.
Re: Void Linux
kilaueabart wrote: Wed Nov 10, 2021 11:26 pm Is there any point to the OctoXBPS icon on the Void desktop? I find some videos on how to set it up, but Youtube doesn't quite play.
OctoXBPS is the graphical package manager for Void. Unfortunately it doesn't work on the X5000. It only works on the X1000.
With which browser have you tested YouTube?
Amiguy
Re: Void Linux
Post by Amiguy »
Hi kilaueabart,
OctoXBPS is surely convenient, but we can very well do without it. The online commands used for package management are clearly explained on the Void site (https://docs.voidlinux.org/xbps/index.html). It's just a matter of habit. We get used to it quickly.
Re: Void Linux
xeno74 wrote: Thu Nov 11, 2021 4:55 am
I had tried Eolie only. Today I tried Interweb with the same initial result, but it turned out it was because I was clicking on the link my search engine gave me. I went to Youtube and searched "octoxbps" there and it worked just fine. So I went back to Eolie and did the same. Here the video works but I get no sound.
So video problem essentially solved. I moved the icon off the Desktop, but to Home Folder instead of Trash.
Re: Void Linux
To allow the user amigaone system access via the sudo command, you need to edit the file "/etc/sudoers" with "visudo". Uncomment this line: # %wheel ALL=(ALL) ALL.
Lets anybody in the wheel group run anything as any user.
/etc/sudoers in Void PPC:
Configuring automount with autofs on Void PPC:
Re: Void Linux
You can also provide automount via autofs for a user:
Re: Void Linux
Instructions for accessing of partitions without password for Void PPC
vi /usr/share/polkit-1/actions/org.freedesktop.UDisks2.policy
Please change the following policies
<action id="org.freedesktop.udisks2.filesystem-mount-system">
<action id="org.freedesktop.udisks2.filesystem-fstab">
<action id="org.freedesktop.udisks2.filesystem-unmount-others">
from
<allow_active>auth_admin_keep</allow_active>
to
<allow_active>yes</allow_active>
Re: Void Linux
QEMU USB Audio works great with Void PPC in a virtual e5500 QEMU KVM-HV machine! :-)
Re: Void Linux
Made and saved some screenshots in void today but I can't find them anywhere!
