ubuntu MATE 16.04.1 LTS Live USB
Re: ubuntu MATE 16.04.1 LTS Live USB
Spectre660 wrote:I installed 16.04.4 using my ramdisk installer and have not had any problem with the upgrade to 16.04.5 .
The Live image was giving problems a while ago .
Thank you for your info! :-)
I successfully upgraded my ubuntu MATE 16.04.4 LTS to version 16.04.5 on my AmigaOne X5000 today.
Screenshot of ubuntu MATE 16.04.5 LTS PowerPC with the RC7 of kernel 4.18 and with Mesa 18.1.2 on my AmigaOne X5000 (connected via an iPhone to the internet):
Upgraded my X5000 to 16.04.5 ... no problems at all!
I also used a cheap Acer USB to LAN adapter and this worked out of the box... 10Mbps .. :-)
Skateman wrote:Upgraded my X5000 to 16.04.5 ... no problems at all!
Great! :-)
I was able to update my ubuntu MATE 16.04.5 LTS PowerPC today. Here is my sources.list:
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial main restricted
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial universe
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial-updates universe
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial multiverse
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial-updates multiverse
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial-backports main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports xenial-security main restricted
deb http://ports.ubuntu.com/ubuntu-ports xenial-security universe
deb http://ports.ubuntu.com/ubuntu-ports xenial-security multiverse
deb http://gb.ports.ubuntu.com/ubuntu-ports/ xenial-proposed universe main restricted multiverse
Several persons here have reported they updated succesfully their Ubuntu Mate to version 16.04.5... How can that update be done?!? At least in my Ubuntu 16.04.4 'Software Updater' does not offer that upgrade...
Roland,
Please try the following commands:
sudo apt-get update
sudo apt-get upgrade
xeno74 wrote: Please try the following commands:
sudo apt-get update
Both commands gave me the following error message:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Another update process is running. Please post the output of ps aux.
I think the problem was with the user privileges... I was able run the commands from an user account set to 'administrator'. The original 'amigaone' account does not have that chosen, it's type is 'custom'. The upgrade was now installed without problems. Thanks!-)
