Kernel 5.15
Re: Kernel 5.15
Skateman wrote: Tue Sep 07, 2021 9:42 pm Kernel 5.15 Alpha 5 up and running fine on the AmigaOne X5000
Reading and Writing to and from my NTFS Formatted SSDEXT device without problems!! GREAT!
Thanks a lot for testing the alpha 5 and many thanks for testing NTFS! Did you mount your NTFS volume with “-t ntfs3“? The old NTFS-3G which uses the FUSE file system interface is still the default NTFS driver. You can check it with “mount | grep <your NTFS partition>“.
Re: Kernel 5.15
I released the alpha6 of kernel 5.15 for the X1000 and X5000 today.
Download: linux-image-5.15-alpha6-X1000_X5000.tar.gz
Screenshot of Fienix with the alpha6 of kernel 5.15 and with Void in a virtual e5500 PPC64 QEMU KVM-HV machine:
Re: Kernel 5.15
Kernel 5.15 Alpha 6 up and running fine on my AmigaOne X5000
Big picture: http://www.skateman.nl/wp-content/uploa ... 212037.png
Question... ever since the the onboard DPAA Ethernet adapter is usable, the internet speed has been capped to 100Mbps... (while my Link is 1Gbit and internal data transfers are also far above the 100mbit ) Any idea :-)
Re: Kernel 5.15
Skateman wrote: Sun Sep 12, 2021 9:36 pm Kernel 5.15 Alpha 6 up and running fine on my AmigaOne X5000
Thanks a lot for testing! How is the internet speed if you test it from another computer?
Re: Kernel 5.15
xeno74 wrote: Mon Sep 13, 2021 5:23 pm
The RC1 of kernel 5.15 is available for the X1000 and X5000.
Download: linux-image-5.15-rc1-X1000_X5000.tar.gz
Please test the RC1.
Oops! I got too busy trying to get Void going and slept through the beginning of kernel 15. Now I can say that 5.15.0-rc1 boots OK here.
Re: Kernel 5.15
kilaueabart wrote: Tue Sep 14, 2021 12:50 am Oops! I got too busy trying to get Void going and slept through the beginning of kernel 15. Now I can say that 5.15.0-rc1 boots OK here.
Re: Kernel 5.15
Skateman wrote: Sun Sep 12, 2021 9:36 pm Question... ever since the the onboard DPAA Ethernet adapter is usable, the internet speed has been capped to 100Mbps... (while my Link is 1Gbit and internal data transfers are also far above the 100mbit ) Any idea :-)
Interesting... Could this discusion be continued on it's own thread? There might be now a clue why the onboard ethernet works directly only for you, while others have to use the unplug/replug trick....
Re: Kernel 5.15
FYI:
I wrote: Hello Juergen,
Hello All,
Since the RC1 of kernel 5.13, -smp 2 and -smp 4 don't work with a
virtual e5500 QEMU KVM-HV machine anymore. [1]
I see in the serial console, that the uImage doesn't load. I use the
following QEMU command for booting:
qemu-system-ppc64 -M ppce500 -cpu e5500 -enable-kvm -m 1024 -kernel
uImage -drive format=raw,file=MintPPC32-X5000.img,index=0,if=virtio
-netdev user,id=mynet0 -device virtio-net,netdev=mynet0 -append "rw
root=/dev/vda" -device virtio-vga -device virtio-mouse-pci -device
virtio-keyboard-pci -device pci-ohci,id=newusb -device
usb-audio,bus=newusb.0 -smp 4
The kernels boot without KVM-HV.
Summary for KVM-HV:
-smp 1 -> works
-smp 2 -> doesn't work
-smp 3 -> works
-smp 4 -> doesn't work
I used -smp 4 before the RC1 of kernel 5.13 because my FSL P5040 BookE
machine [2] has 4 cores.
Does this patch solve this issue? [3]
[1] https://lists.ozlabs.org/pipermail/linu ... 29103.html
[2] http://wiki.amiga.org/index.php?title=X5000
[3] https://lists.ozlabs.org/pipermail/linu ... 34152.html
Link: [PATCH 2/2] kvm: rename KVM_MAX_VCPU_ID to, KVM_MAX_VCPU_IDS
Re: Kernel 5.15
Kernel 5.15 rc1 up and running fine on my AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 084835.png
FYI
My normal speed is around 600 / 40 Mbit (as shown in the screenshot)
With the X5000 DPAA on the CLI 300+ mbit is not a problem (see Speedtest-cli output) . Using a browser...the speed is always capped with a max of 100Mbit.
