Arctic Fox
I was able to build it but we have to test it.
.mozconfig
# This Source Code Form is subject to the terms of the Mozilla Public
# License, v. 2.0. If a copy of the MPL was not distributed with this
# file, You can obtain one at http://mozilla.org/MPL/2.0/.
export CC="gcc -m32 -flax-vector-conversions -O3 -mcpu=G3 -mtune=G3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export CXX="g++ -m32 -flax-vector-conversions -fpermissive -O3 -mcpu=G3 -mtune=G3 -falign-loops=16 -falign-functions=16 -falign-labels=16 -falign-jumps=16"
export LDFLAGS="-latomic"
mk_add_options MOZ_OBJDIR=@TOPSRCDIR@/obj-ff-dbg
ac_add_options --disable-mozril-geoloc
ac_add_options --disable-parental-controls
ac_add_options --enable-release
ac_add_options --disable-eme
ac_add_options --disable-dbus
ac_add_options --disable-gio
ac_add_options --enable-strip
ac_add_options --enable-install-strip
ac_add_options --enable-application=browser
ac_add_options --with-branding=browser/branding/arcticfox
ac_add_options --target=powerpc-pc-linux
ac_add_options --disable-js
I used these commands to build, test, and package:
./mach build
(starts the configuration and build process)
./mach run
(tests completed build with scratch profile)
./mach package
(creates the self contained archive which you'll find in Arctic-Fox-master/obj-ff-dbg/dist)
Download: arcticfox-27.9.13.linux-powerpc-without-altivec-g3.tar.bz2
Screenshot of Arctic Fox 27.9.13 on the MATE PowerPC Remix (A-EON AmigaOne X5000):
caseycullen
Post by caseycullen »
This is great news!
Did you disable javascript? Is this necessary to build?
xeno74 wrote:I was able to build it but we have to test it.
.mozconfig
./mach build
./mach run
./mach package
Casey,
I tried it. The strange thing is, that all websites work including Facebook, Google+, and LinkedIn. I thought they need javascript.
caseycullen
Nice! Do you mind if I package your binary for inclusion in Fienix?
-Casey
xeno74 wrote:Casey,
caseycullen wrote:Nice! Do you mind if I package your binary for inclusion in Fienix?
-Casey
It would be nice if you can do it.
— Christian
Well it doesn't get any sweeter than this! Works a treat and is fast and so far rock solid. Downloads work, banking sites work as do FB et al. A very big thank you and well done. Tested on Fienix, will test on UB16.04 and Remix later.
Arcticfox runs on Ubuntu 16.04, everything works as under Fienix. Funny thing is under Fienix Youtube works but with no sound (pulseaudio was not complied in) but under 16.04 Youtube with sound works fine! Sweet.
caseycullen
In order to have sound, and much better video quality, activate Greasemonkey and VLC Plugin. If you are using Fienix these are already installed and you only need to activate them from Arctic Fox: Tools > Add Ons, then then from Extensions activate Greasemonkey and from Plugins activate VLC.
You may have to re-install ViewTube from http://sebaro.pro/viewtube/?ln=en
-Casey
acefnq wrote:Arcticfox runs on Ubuntu 16.04, everything works as under Fienix. Funny thing is under Fienix Youtube works but with no sound (pulseaudio was not complied in) but under 16.04 Youtube with sound works fine! Sweet.
caseycullen
Wow! Arctic Fox is Amazing! Sites that would slow my system on Firefox speed along just fine with Arctic Fox! We are so lucky to have this browser!
-Casey
xeno74 wrote:Casey,
Thanks Casey I'll do that. Pretty sweet eh? -:)
