Repeating this here, since it appears a little more paid attention to...
When booting without startup-sequence, doing a "List" in the first CLI triggers a requester asking to insert ENV: in any drive.
Why? What is List looking for? Nothing in release notes suggests that it should be looking for global variables. Or is this triggered by shell or console? It does not happen if I use Con-handler shim for ViNCEd.
Anyhow, as far as I can tell, this is a change from previous releases, so I suppose it is a bug.
OS 3.2.1 - List asks for ENV:
Re: OS 3.2.1 - List asks for ENV:
Update for 3.2.2:
Allthough C:List has not changed, this bug has been fixed!!
(can only speculate which kickstart component that triggered it in the first place)
