OS 3.2 on A3000 with SuperKickstart 1.4
mrupp
Post by mrupp »
Hi there
First of all: Thank you so much for all your efforts in creating OS 3.2! It's really really great and there are so many details that let you feel the passion you guys put into it, THANKS!
I successfully installed it on my A500+ with ACA500plus and the installation procedure is really smooth and well done.
After that, I went on in creating a superkickstart disk for my A3000. I have done this before succesfully with Kickstart 3.1.4, attaching the needed bonuscode and such. Unfortunately this didn't work out with 3.2. This is what I did and maybe somebody can point out what I did wrong:
  1. I took the kickstart file from the following location: AmigaOS3.2CD:/ROM/kicka3000.rom
  2. I took the same 2.x bonuscode file I used the last time with 3.1.4
  3. I joined the two files to create the new superkickstart file
  4. I wrote the new file to a blank disk using the tool MakeSuperDisk from Aminet (http://aminet.net/package/util/misc/MakeSuperDisk)
--> After loading the kickstart from this disk with my A3000 there was a yellow screen, reboot, yellow screen, reboot, and so on...
Spot anything wrong? I retried doing exactly the same with Kickstart 3.1.4 and the procedure still worked there.
And as a suggestion for the future: maybe you could include an ADF for the A3000 superkickstart disk and the corresponding kickstart file for HD use, that would be most splendid and probably not too much additional trouble, I guess...
Keep up the good work!
Michael
Check out TAWS - The Amiga Workbench Simulation
https://taws.ch
Re: OS 3.2 on A3000 with SuperKickstart 1.4
Post by thomasrapp »
mrupp wrote: Sun Jun 20, 2021 8:45 pm [*]I took the same 2.x bonuscode file I used the last time with 3.1.4
Yes, that's a known issue. It just does not work with the 3.2 ROM. You cannot make a 3.2 SuperKickstart disk on your own. You have to wait for the official one.
In the meantime you can keep the 3.1.4 superkick and install 3.2 on top of it. It will need some more RAM to load the 3.2 modules. When the 3.2 SuperKick arrives, you can just upgrade the Devs:Kickstart file and get that memory back.
mrupp
Post by mrupp »
Very well, thanks for clarifying this.
https://taws.ch
Amirafik
Post by Amirafik »
Good day.
I can see that I am not the only one using Amiga 3000 and superkickstart. I have the same problem. So I am waiting for a solution and superkickstart ROM 3.2.
To install the system it was enough to start from rom 3.1.4 and add modules (from floppy - Modules A3000) to change to 3.2.
One note: Os 3.2 is great but in rom 3.1.4 and the system antickick flopy drivers are missing...
Greetings.
mrupp
Post by mrupp »
Any news on this, yet? ;)
https://taws.ch
Amirafik
Post by Amirafik »
Hello.
Have You managed to prepare superkickstart 3.2?
Amirafik
Post by Amirafik »
Has superkickstart 3.2 already been prepared?
Amirafik
Post by Amirafik »
Hello.
When Amiga 3000 with a superkickstart users will see a rom 3.2?
Amirafik
Post by Amirafik »
When will superkickstart 3.2 be prepared? Or only users are reading this post?
Amirafik
Post by Amirafik »
Has someone managed to do superkisckstart 3.2?
