RadeonHD problem
Joeled
RadeonHD problem
Post by Joeled »
I have RadeonHD 7700 card and RadeonHD v0.65 version. When i try to install newer version from Amistore it installs but after reboot i still have old version. Any idea whats wrong?
trgswe
Re: RadeonHD problem
Post by trgswe »
RadeonHD 0.65 wow!
Double check that it really Installs it, or do a manual install, i had a similar error with RadeonRX,
Also check the protection flags so that it is rwed. but the manual install should fix.
