I use a few string gadgets (StringGadget) that are all TAB enabled (GA_TabCycle, TRUE). I pre-select (IIntuition->ActivateGadget) the first one and it works but if I press the TAB key, it doesn't go to the next string field.
If I click elsewhere then click the first string gadget. The TAB key then works and it goes to the second string gadget.
Is it a bug ? Is there any workaround ?
Thank you.
