Window.class WINDOW_GadgetHelp and IDCMP problem
blmara
Post by blmara »
in my program I modify some IDCMP flags in response to certain events. For example, after getting a WMHI_GADGETUP I stop receiving intuiticks with
            IIntuition->ModifyIDCMP(dobj->win,dobj->win->IDCMPFlags & (~IDCMP_INTUITICKS));
I have used WINDOW_GadgetHelp to get my window object show gadget help hints and each gadget has a GA_HintInfo string. They are shown fine until WMHI_GADGETUP handling, after which no hints are shown anymore. Could this be because of removing intuiticks?
I managed to restore gadget hints by
 IIntuition->SetAttrs(dobj->winobj,WINDOW_GadgetHelp,TRUE,TAG_DONE);
but this seems to have side effects with IDCMP messages. So, how could I use both approaches (gadget hints and to be able to modify IDCMP messages received by my proghram) at the same time?
Marko
Marko
Re: Window.class WINDOW_GadgetHelp and IDCMP problem
Post by thomasrapp »
blmara wrote:Hi,
IMHO you must not call ModifyIDCMP on a window which was created by window.class. The window is property of the class and you must not change it without telling the class.
You might try to SetAttrs(dobj->winobj,GA_IDCMP,dobj->win->IDCMPFlags & (~IDCMP_INTUITICKS),TAG_DONE); but this probably won't clear INTUITICKS because the class needs IntuiTicks for the GadgetHelp timing.
Yes, sure.
Sure. Window.class will set all IDCMP flags it needs. As it needs IntuiTicks for GadgetHelp, IntuiTicks will be enabled if you set GadgetHelp.
You can't. Set a flag in your program that you don't want IntuiTicks and when it is set, ignore the IntuiTicks you receive.
blmara
Post by blmara »
thomasrapp wrote: IMHO you must not call ModifyIDCMP on a window which was created by window.class. The window is property of the class and you must not change it without telling the class.
Thanks, I'll do like that. Hmm...this is something that should be entered to window.class autodoc as the 'Intuition time' examples use ModifyIDCMP also.
Marko
Marko
