Screen depth
Re: Screen depth
@Xenic
In tyour PPAint prefs find the option
PROMOTE = 24
and chnage it to
PROMOTE = 16
You may need to do it for both sets just to be sure.
(PS 24 refers to the colour depth of the screen not the bit depth).
Re: Screen depth
broadblues wrote: PROMOTE = 24
and chnage it to
PROMOTE = 16
That works but brings back a problem I had with the old 68k Cloanto PPaint. When I move the mouse pointer I get random junk drawn in the window. I can't remember how that got fixed for the old version. I don't remember if it was a change in PPaint or OS4.
trixie
Re: Screen depth
Post by trixie »
broadblues wrote:You probably do need to reload images if you jump from CLUT to 16/32 or vice verca
Yes you do need to do that, I've just checked.
but not if you jump from 16/32 to another 16/32 .
Correct.
The Rear Window blog
Re: Screen depth
and chnage it to
PROMOTE = 16
What OS version?
Re: Screen depth
broadblues wrote:What OS version?
I'm running OS4.1FE with a Radeon HD 5450 and all the new drivers that I bought at AmiStore. When I first got my X1000 I had lots of graphics corruption when running some programs on 16bit screens. Most of the corruption problems eventually disappeared with newer graphics drivers. I still have small vertical blue lines in some of the checkmark gadgets in the Dopus4 configuration window on a 16bit screen. Hans explained that there are some variations in the HD5450 card, so some experience graphics corruption and others don't. He also pointed out that some programs have non-aligned accesses to VRAM and that the PA6T chip doesn't like non-aligned accesses across the PCIe bus.
My point is that unless someone else can confirm my graphics corruption in PPaint on a 16bit screen, it may not be worth your time & effort to attempt a fix. I can live with OS4 PPaint on a 32bit screen.
Re: Screen depth
That's curious as the primary cause of that bug (in the wider spread ocurance of it anyway) was fixed in OS4.1 FE.
I don't think it can be remedied at Paint level, since it is / was an OS / driver bug.
