I bought a sam 440 flex board from a person he didn't have the cd to load the os can I use any cd or do I have to use the
registered copy for that board. sorry guess Im say this right to get a answer.
os
Re: os
If the seller doesn't transfer the OS4 regiatration to you then you will need to purchase OS 4.1 and register it.dhey59 wrote:I bought a sam 440 flex board from a person he didn't have the cd to load the os can I use any cd or do I have to use the registered copy for that board. sorry guess Im say this right to get a answer.
Re: os
If his board was registered, then he should have had a CD provided with it.
In any case, once your own registration is finalised, you will be able to write an email to (Hans-Joerg?) and ask him for a copy of the CD.
Re: os
You do have two copies of AmigaOS for the 440 registered in the database. The easiest way to get you a CD would be to send you a copy of the ISO to burn your own CD.dhey59 wrote:I bought a sam 440 flex board from a person he didn't have the cd to load the os can I use any cd or do I have to use the
- Christopher Follett
- AmigaKit
Re: os
Or he could login to Hyperion site and download the most current iso.ssolie wrote:You do have two copies of AmigaOS for the 440 registered in the database. The easiest way to get you a CD would be to send you a copy of the ISO to burn your own CD.dhey59 wrote:I bought a sam 440 flex board from a person he didn't have the cd to load the os can I use any cd or do I have to use the
__________________
New Products
