I have managed to work around a jxfs issue but instead ran afoul of another hdd failure which again amounted to the loss of an additional system drive.
so development on my existing projects has stalled again, If anyone knows of some decently made sata cables with decently clamped 90 degree connectors and in sets of 2 or 4?
EDIT: Outstanding solution,
I managed to rework to having 2x500GB drives and repartitioned and relocated whatwas essential.
Recent issues... SOLVED
Re: Recent issues...
Not to flame against jxfs (i had it in use myself for some time), but it has been said in the not so distant past that jxfs might be a dead-end (development-wise).Belxjander wrote:I have managed to work around a jxfs issue but instead ran afoul of another hdd failure which again amounted to the loss of an additional system drive.
(Not sure if that is still the case...joerg?)
You'd be better off with using sfs/sfs2 (also because of the already available repair tools)
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
There are no tools for SFS\2.Raziel wrote:You'd be better off with using sfs/sfs2 (also because of the already available repair tools)
Oh, ok...i thought the tools that work with SFS\0 also applies to SFS\2joerg wrote:There are no tools for SFS\2.Raziel wrote:You'd be better off with using sfs/sfs2 (also because of the already available repair tools)
Too much time past since i tried...never had any problems with my SFS\0 formatted partitions
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
Re: Recent issues... SOLVED
Didn't notice this, so now i have. It's most unfortunate that it's found out JXFS is not a good file system to use at all.
I wonder if JXFS that is part of AmigaOS 4.1, actually now turns out to have been a mistake? That it should never have been made?
Another problem is that there are no recovery tools for the SFS2. SFS2 seems to be the best choice. I would like to see a SFS3 some day, unless there are other ideas.
I have now changed all my 4 partitions on my internal SSD HDD to use SFS2 only. Only my 1TB external USB 3 harddrive is using JXFS for all 4 partitions on that drive.
Helge Kvalheim, Norway
Use of JXFS would be fine for large data sets up to 400GB where dataloss is a non issue
I did have a 500GB drive that I practically filled before problems showed up.
Basically once less than 20% is freespace, before that, no problems at all
So I would say it was a decent experiment which showed possibilities
